Outie I4 w CVT vs V6 Auto comparison MPG/towing
joet333
Member Posts: 5
I am considering an 08 4WD SE or an 08 XLS 4wd. I am not a huge fan of the CVT that is in the Dodge Caliber I drove, but I understand they have fewer moving parts to break and are fairly reliable. Main complaint is the calibers CVT really kept the rpms high and was noisey under hard acceleration.
wife prefers the 4 cylinder because of better mpg, though I showed her the V6 is only 1 mpg off the I4 around city and 3 mpg off on highway.
I have a 500 lb boat that gets pulled off the beach a few times per year, and I haul a pallet of pellets (#2000) about 20 or so miles 3 or 4 times per year. I know that either egine can handle the boat and the pellets would strain the I4.
So my question is two fold. What are others opinions of the CVT?
Can it handle the larger towing requirements?
What is the real world difference in mpg between an I4 CVT and V6 5Auto?
I am feeling the I4 may be the better choice to save some gas pennies if I am only towing a heavy load 4 x yearly...
The following comments are based on the 2010 Warranty and Maintenance Manual along with the Owners Manual.
The 2.4L runs on regular gas and needs less frequent inspections and adjustments for valve clearances which are recommended every 30,000miles for the 3.0L V6 versus every 60,000 miles for the 2.4L. Timing belt replacement on the V6 is recommended at 105,000miles but apparently is not an issue on the 2.4 L which has a silent chain drive for the camshafts. Premium gas is recommended for the V6.
Your towing requirements may be limiting with the 2.4L which for both FWD and AWD has a max 1500lb trailer weight with brake and 1250lb without brake. The V6 can pull 2000lb FWD with brake or 3500lb AWD with brake. Without the brake it can handle 1400lb for both FWD or AWD.
I have a '10 Outlander GT and have averaged 21.1MPG over 15K miles. For '10, the 3L V6 was revised to bump HP from 220 to 230. Highest tank average was around 25; lowest around 18. I use a mix of midgrade & premium. I live in the Chicago suburbs so I get winter weather & winter blend crappy gas part of the year.
Best between fills - last September: 27.8 MPG
Worst between fills - this February and March : 17.58 MPG
Location is Southern Ontario.
Winter use is low mileage local using AWD on snow covered roads.
Summer use is higher mileage with good portion using FWD on highway.
No towing.
I've also driven it on the highway for interstate travel numerous times. On trips I average closer to 24, which is spot on the EPA estimate though I'm usually running 70-80MPH and not 55. The absolute best economy for my car is at around 42-50 MPH.
http://www.mitsubishi-motors.com/corporate/about_us/technology/environment/e/cvt- .html
http://cars.about.com/od/thingsyouneedtoknow/a/CVT.htm
No cement mixers mentioned here!
I know the CVT has fewer moving parts to break than a transmission with separate gears and so far cvt has been proven itself on road cars. My concern is whether it will hold up to larger displacement engines and heavier vehicles & towing.
The one thing that surprises me is that with the ability of the CVT to pick the correct rpm for power and mileage there is not as much difference in MPG between the I4 & V6. I figure the CVT runs down the highway at a higher rpm and would be 4-5 mpg better but one would think there is more than just 1-2 mpg diff in real world average driving.
For a 1-2 mpg difference, I am leaning to the V6.
I've made home improvement store trips & come home with over 900 pounds of cargo in the cargo area (+ another 200+ pounds of me behind the wheel). While I didn't do any harsh takeoffs, power with a full load was still good and I could have easily driven it as if I was the only thing weighing down the cabin.
If cost is your primary concern and you don't truly require the towing capability, get the I4. It'll be a little cheaper on gas & overall cheaper on maintenance over the vehicle's lifespan. Otherwise, if you can afford a few extra bucks now and then or if you absolutely have to tow, with the V6 you'll get power that's never lacking.
If you're undecided, drive both and pick the one you think offers the more pleasant experience. You may find the I4 to be just fine & go that route. Or you may find the added grunt of the V6 to be addictive.
