Parking Lights wont turn off
kjzippykjzippy Posts: 1
edited October 2014 in Oldsmobile
I drove home from work in extremely heavy rain. When I exited my 98 aurora the parking lights were still on and the ding-dong alarm when the door was open let me know they were on. The problem is I have adjusted the light switches and turned off and restarted the car, but the lights are still on and draining my battery. How can I get the turned off?
  • I think this problem was solved and also documented really well with a procedure and photos at the website:
    http://65.39.242.200/~aghl/Aurora/index.html
    The problem is caused by a small amount of grease inside the turn signal lever slowly flowing over time between the electrical contacts inside the turn signal - intermittently shorts-out the headlights or parking light switches.
