Repair manual
Hi everyone. I just bought an 03 Echo and was looking for a repair manual, though I couldn't find one. Did Haynes or Chilton ever publish one for this car?
Took a quick look just now & didn't see an '03 there, but the '00-'02 one may be useful. The site's not the most organized, so there may actually be an '03 there somewhere.
I was in the hospital with a Multiple Sclerosis Flare and was hospitalized for nearly a year off and on. During all of that time, no one started my car. I know that at this point, the fuel in my tank is no good and has turned to varnish which will destroy my car. PLEASE hep if you can. I own a 2002 Toyota Echo and I am wondering if anyone can tell me if there is a simple drain plug on the fuel tank from underneath the car that I may just easily drain the fluid from? I know that siphoning will not work because of anti-siphoning measures toyota probably has on the 2002 toyota echo? PLEASE PLEASE PLEASE help me. It's all I can do to beg. I really need this car running so I can go back to work. PLEASE I beg anyone who reads this to please help me. For a 2002 Toyota Echo. Thank you God Bless you all.
Fuel tanks do not have drain plugs - to drain the tank it has to be removed and drained by suction.
I would change the oil and air up the tires and just crank it up! (might need a new battery or a trickle charge on the battery that is in it)
Was the tank full? When you went into the hospital? That is the best way to store gas. If it wasnt fill it up as soon as possible. Maybe even with a 1 gallon cgas can you can buy at the hardware store one gallon at a time.
Dont worry about your car. Yes change the oil and charge the battery. If you have AAA they can tow it to a garage and they will take care of everything.
Good luck and I wish you the best getting on with your life.
Tell us what happens. If you need more help we are here for you.
Yeah you dont want to blindly replace things one after another trying to solve a problem.
Thats whay shops do to you to get as much money as possible before you die.
Danny-
Do you hear the pump run when you turn on the ingition?
I would wire the fuel pump on if possible and look for fuel like you did at the injectors.
I have to believe the problem resulted from low fuel, not bad components.
I would be doing everything I could to get fuel to the injectors before I spent money replacing what most likely are good parts.
Good luck and tell us what happens!
I think one part is the pump and one part is the filter.
The filter isnt normally replaced as I understand it.
Danny-
You said the car ran low on gas I think. Got to believe the problem is related to that. But how I dont have a clue.
Oh I know!
Have someone crank the engine while you spray ether or even gas into the intake. Maybe remove the air filter first? If it fires at leaast you know its gas. It might be encouraged to keep running.
Thanks. Danny-
Danny-
But you didnt have any evidence of fuel at the injectors so if the pump was good it should have got fuel to the injectors.
Maybe they are right?
I hope you get the car going again! Tell us when you do!
No idea about the corolla vs ECHO fuel pump compatibility.
That would explain no fuel at the injectors.
If you had diesel at the injectirs I would think you would smell it when you tried to fill the can.
I will enquirer further.
Dont hang the shop yet!
Unlikely a new one such as you installed would be harmed.
HOWEVER no one would catagorically say "Diesel will ruin a fuel pump" or had the experience of it happening.
