65/66 mustang the only stang worth a damn
Bri66
Thanks again
Bri66
I would like to install an 'export brace' on my '66 Mustang. But the shock towers don't quite line up with the holes. Any suggestions on how to move the shock towers?
"There but by the grace of God go I". I could easily be in your shoes.
Good luck. Perhaps you can find a buyer who may agree to sell it back should your situation change?
Hey, don't panic....maybe you can just hold off and try something else....if you really are in a death spiral financially, selling the car isn't going to help anyway, and it may be a good thing to hold onto for self-esteem until you land the next good job!
The four days includes a Pony Run, Concours Judging and Peoples Choice Show. Vendors will attend as well as the usual Corral. This is a must see and show for those in the NW USA or SW Canada. On the green campus of Bellevue Community College under blue skies and puffy white clouds. Casual dress - no bow ties.
Wrong on hemis
Wrong on 428 heads
Wrong on RWD Toronados
Wrong on modular engine sizes
Now wrong on power output of the 4.6.
Please quit while you're behind.
Just for those fractional differences, you'd have to change stuff like pistons, the crankshaft, bore/debore the cylinder heads, etc. No company in their right mind would waste money doing something like that!
Wait, I take that back. For a few years, Chrysler actually offered two different 383's. One went into Chrysler Windsors and Saratogas, and one went into Dodges, DeSotos, and Plymouths. Different bore & stroke, and the Chrysler engine actually had a smaller displacement! (by about .5 CID or so)
The 351 W shares it's design with the 302. It has a taller deck and bigger crank journals and longer stroke. The Cleveland was a different block with more performance potential in that it had smaller crank journals and incredible (for their time) canted valve heads. The C has a goofy oiling system and needs restrictors to live at high RPMS. (Pretty ironic when that's what those heads and crank were designed for.)
Like the SBC, the Windsor/302 has been around so long that the aftermarket supports it better than any motor ever(along with the chev).
Another reason while I'm thinking about it is that the displacement figure is a calculation. Maybe it's just rounding to different degrees, or over simplification. If 302 = 5.0l, that's 60.4 liters per cubic ". If 5.8l = 351, that's 60.5172413793 liters per cubic inch. Taking an average, 60.458620, multipling by 4.6 = 278.109655etc. A little less than 280/281/282(I thought it was 281??). Anybody lost now? I am...
Displacement is just the bore and stroke though, and doesn't take into account the shape or volume of the heads. I think it's the volume of the heads that determines compression ratio, though. for example, when you mill the heads, it increases it. Put on a head gasket that's too thick, and it reduces it.
Lee
And just about every part is available either NOS or repro or used.
One variant on the car project I've thought about (this assumes that you're fairly well off) is how to provide a car for a teenager. Since modern ones are a tad on the shiftless side (well, aside from pitbull breeding, spitting, and wearing bare midriff clothing), my thought for a parent, is to buy a hulk of a cool car (a really early beetle or the aformentioned early mustang) and provide the money to properly restore it (in terms of parts, not other people's labor). This is the only car ever provided to the kid.
Sorry you didn't catch that 65 michml320, but shifty is right easy cars to work on and a blast to drive. My two most important items to check for are rust and rust repairs, along with suspension issues.
Ndance, a buddy and I though about this project as well a few years ago. I've seen a couple of photo alubums that show some convertable reconstructions that almost are new builds....
bummer about the guy who puched the wrong button. I have a feeling there's more to that story though. I've ended up down the the wrong alley at work a few times by accident, if it's a random event it's always no harm no foul. But then , that's how it is here.
I have a '65 c-code Mustang convertible. The exterior is black with a white top w/ black interior. Put on slotted mags, b/c I got them for $40 for the set, but the offset is pretty horrible. Had 225/60/14s on, but downsized to 205s after putting on the mags. Anyways, I've done a few modifications to it. It has an ATK 302 with the original 289 heads, an edelbrock 4 barrel 600cfm electric choke carb, Edelbrock Performer RPM air gap manifold, true dual 3-chamber flows w/ an h-pipe and aluminized 2.25" piping front to back, stock exhaust manifolds (NO headers), stainless steel manual disc brake conversion in the front, gabriel striders in all four corners, Total Control Products upper control arms (NOT relocated), polyurethane spring perches, 700lb.in coil springs (~1 inch drop in front), 4 leaf standard eye leafs (stock rear ride height), export brace, front sway bar, K&N air filter, engine dress up (Mustang - Powered by Ford valve covers, chrome air filter housing, chrome dip stick), Pertonix ignition and coil, a Sony Active Black Panel cd player w/ 4.5" sony speakers in the doors. I have all the maintenance records dating back ten years. THe top is 3 years new, the engine 2 years and manual tranny (four speed T-10) is 1 year since rebuild. The car is an everyday driver. The interior is not bad by any means, but also not great. The decoding plate that tells everything about the car in stock form is gone. Found out it was a c-code built in Milpitas, CA from the vin number registered w/ DMV. California car still.
No, I'm not interested in selling the car. However, I am interested to find out the market value for this beautiful car. Anyone care to venture either 1) how much they'd be willing to shell out for something like this or 2) how much the "market" would price it at? The body is straight, no rust, and no cutting, flaring, bending, or "permanent" modifications.
Thanks for your speculations. Not running a test market or trying to "test the waters". I'm just curious.
Best you could do is figure the value for a daily driver Mustang convertible and presume yours would be worth less because it is modified.
it's not so much that modifying the car is bad, as you've no doubt improved it in many ways, but that modifications are like jewelry, so personal that it is hard to find a buyer who wants exactly what you've done to your car.
Just as a ballpark, I'd guess in the $8K-10K range would be where the action is for this car.
My bride was out somewhere but her '66 V8 Mustang Hardtop (w Pony interior ) was sitting in our driveway 100 feet from the road practically hidden behind some trees on our rural property. We weren't using it and had taken it off the road about 6 months before.
Suddenly a Pinto came hurtling up the driveway(if thats possible) with a smoke coming from the exhaust and a sweeter smelling smoke coming from the windows.
Young man jumped out-
" you gotta hold this car for me until tommorrow when I get back with the money "
Me-
" youll have to call my wife - she's attached to the car and isn't sure what she is going to do, besides it's been sitting ther for 6months I'm sure it will still be there tommorrow - so call her"
Essentially this exchange was repeated 5 times with this guy getting more concerned about losing out on the car and me repeating myself.
Then he progressed to insisting on giving me a deposit to "hold" the car until the next day. Despite my repeating my statement(see above).
Finally, I realized I wasn't going to get thru to this guy and took a $20 bill just so I could get back to whatever I was doing when he showed up.
Never saw or heard from him again.
Though, I thought more $10k-$12k, but I'm probably optimistic or taking into account the inherent Silicon Valley mark-up.
Guess the modifications really do hurt the resale value. Oh, well. Like I said, I'm not interested in selling, but was just curious. Upgraded the car for my own enjoyment, not to make a profit from. Thanks again for your speculation.
A guy at Mustang Fever is tricking out his 65 fastback with the best the aftermarket has to offer. He put the whole TCP coil over front suspension kit, lower controls, tie rods, and TCP manual rack and pinion. I do not know whether he has TCP frame connectors or another brand. He claims it handles better than most new cars. He does clovers off the freeway in Silicon Valley at 60+mph w/out any problems. I do clovers at about 40 - 45 mph and break a little traction. My girl's 1990 celica GT does the same clovers at 35-40 mph. She needs new tires though.
