Jeep is shipping in a new engine now. It is covered under warranty but as you can imagine, who wants a car that does this? The dealership we purchased the car from is pretty much washing their hands of us, since the jeep is at our local dealership getting the service. Wow, what to do. Before having to deal with our Texas Lemmon Law and just keeping a good eye on it. Has anyone ever had good experience with Chrysler replacing your whole car before you begin to grip about it to everyone. Well, just looking to see what someone might add at this point. Thanks for any responce. Chrysler is taking our whole engine back to "study" the problem. (2005 Jeep Liberty 4x2 auto, Rocky Mountain) :lemon: :sick:
The Transfer Case (when not in use) has a 1:1 going to the rear differential, but I don't know of any gear reducers to lower this 1:1 to maybe .8:1.
The whole idea is to lower the engine speed from a screaming 3000 rpm to a fuel efficient 2200 rpm while at highway speeds. You could change the rear end to a 3.08 (instead of the factory 3.53) and achieve amazing results. I would tend to invest in a differential modification instead of an engine chip. Since the NSG370 is gear so high, a 3.08 rear end would provide a marked improvement in MPG, but its only disadvantage are towing and acceleration up hills.
Now, does anyone have $1500, because this is what its going to cost in parts, but mostly labor. I would do it, but I would be voiding the warranty. Would even the Jeep guys go for such a common sense idea?
John
When on the motorway over here no-one really does 70 (the limit here) or lesss We tend to do about 90 mph. It got me thinking that if the Liberty has a top speed of 112 mph, how would it handle at this speed which is near to its top speed. Would it be able to travel any faster without feeling strained and as if it were being pushed quite hard? Would it be able to do it for long or wouldyou have to slow down because if struggles? Also, i know that the Liberty 3.7 has a 4 speed transmission and i was wondering what rpm the car is doing at 70 mph? '
When we went to Jeep we would of test drove one to find this out for ourselves but they wasn't any availible.
If any one can reply to the questions i would be most greatful... HEHEHE!!!
I have my timing light ready to go, and as I am lifting the hood on my new Jeep, where's the spark plugs? I am also looking for the distributor, ready to adjust it if the timing is off. But, where's the distributor?
My question is this: how can you install performance chips, electronics gadgets or what ever without establishing an accurate baseline adjustment? If the engine is not timed correctly, then any performance chip might aggravate the problem by making compensations elsewhere in the engine, like errors in fuel flow or errors in fuel mixture.
When a new car comes off the assembly line, is it timed? Quality Assurance (QA) only checks a small % of cars to see if the timing is set correctly (Maybe). Was my Jeep checked?
Tomorrow, if I ask the Jeep technician to "time" my Jeep, he'll first plug it in to the diagnostics ($180.00) He'll look for fault codes, but if none are present, then the timing is set right. My question is, has he visually checked the timing with a timing strobe light rather than listening to the stupid computer. Is the computer correct all the time? Then how does he know its done correctly?
My 1997 Jeep Cherokee ran 132,000 miles with only a water pump failure at 81,000 before I traded it in, after the rear differential decided to eat itself. I guess a common failure with Cherokee's.
I just might buy that old 1993 Jeep Grand Cherokee and fix it up, and will probably last longer and more cost effective than this 06 Liberty I just bought.
Now, I'm off to buy an '05 Jeep Liberty repair manual and find where the spark plugs, distributor and timing marks are so I can (DIY) and save $500.00.
After that a ring and pinion change to the 8.25" rear and front differential from 3.53 to 3.21. After that, the ball joint and rotor FUBAR.
John
Lexus, in one of its "adds" indicated that its axles generated 3800 ft/lbs of torque. Well the Liberty with 3.7 liter with NSG370 manual Tx with 3.53 rear end generates 3432.15 ft/lbs of torque. If you go to www.mustangsandmore.com/ubb/DanJonesTorqueVsHP.html, the writer goes though a very lengthy mathematical analysis of gears and ratios.
If you look on the "spec" graph for the 3.7liter, at 2800 RPM, generates about 218 ft/lb of torque at the flywheel and 120 horsepower. Now, as part of Jeep's victory cry for the Liberty, the 3.7 liter can generate 210 horsepower at 5200 RPM. Now unless you race cars, I can't imagine myself shifting gears at 5200 rpm.
Gears and rear end ratios are "mechanical advantage" to take 218 ft/lbs of torque at 120 horsepower and convert it over to Rear End axle Torque. In my analysis to change the 3.53 to a 3.21 shows little difference in engine or axle performance, except in savings in gas milage. At 2000 rpm, I will be going 60 mph with a 3.53 rear end, but with a 3.21 rear end, I'll be going 65 mph. The first gear's only purpose is overcoming inertia when pulling a trailer.
I have to agree about the Distributor. But if I replace an "electrical" pick-off to read engine rpm vs. dynamic function of the crankshaft at different speeds, I have to wonder - What is the life span of this electrical pickoff? What happens if this device becomes wet? How about exposed to electrical shock? Could a faulty battery cause a short in the whole electrical network of the car to cause a complete motor malfunction? This is why I hate computer controlled vehicles. Most electronics today are disposable if a problem occurs, but what about a car? What am I supposed to do if a technician just throws up his hands and says, its broken and I can't fix it. There has to be a level of liability vs technical ability the Jeep people have to incorporate into their products, or else we are just buying garbage.
So all the problems occuring out there are all "chip" related. So every wire has to be metered, all associated chips need to be changed, the motherboard needs inspection or replacing, the main computer module needs replacing. The battery needs inspection to ensure no internal short. This means alot of work for the technician. Do you think he's able to complete such a huge task? I'll let everyone out there put their service departments to the test to see if they are up to the challenge to fix their own cars.
As for me, I'll fix my own, thank you very much.
John
My 1997 Jeep Cherokee 5 spd was not fond of hills either. Downshifting was almost a way of life going across the "hills" between Virginia and West Virginia.
An automatic 3.7 liter would leave my Cherokee in the dust any day when going up a hill, or anywhere for that matter. The weight difference between the Grand Cherokee and Liberty depends on what options you have, (in particular, how many skid plates.) The Liberty is light enough to allow the 3.7 to increase its thrust to weight ratio, but I am sure the Jeep Commander 3.7 liter is a bit overburdened.
So far, I am very pleased and is very fun to drive. I looked at the CRD, but due to diesel prices and random unpredictible nature of the 2.8 liter engine, I was glad I purchased the gasoline 3.7 liter.
Give it a good workout and see what you think.
John
I think I'll keep the 3.53 gearing. Now the performance chip, if you read its claims, it only reconfigures engine performance when under loads or higher RPM. Under normal circumstances, it doesn't alter normal chip operation. For my situation, I would not have much use for it.
The Prolong and synthetic oil has brought my idle RPM to a smooth 500. I can really tell the difference between regular oil and synthetic.
I wish more people would change to a manual tx. People would be surprised at all the additional computer programming when configured with an automatic transmission. There are additional linkage problems, water in the automatic transmission fluid like the 2002 Jeep Liberty and the additional problems like bucking, RPM racing and gears which don't seem to change at the correct RPM. But, if you still want an automatic transmission . . . . . Don't say that I didn't warn you.
John
Farout.
Manual transmissions mated to diesel engines are only offered in larger trucks. Why is that? In performance cars with diesels, only automatics are offered. I like a performance vehicle with an manual 5 or 6 spd. If I attached such a manual to a diesel, I would blow the engine. Why? The diesel engine red lines at 2500-3000 RPM. The computer constantly monitors transmission to engine RPM for maximum performance while not causing the engine to eat itself. Any fatal flaws in computer programming, temperature, moisture, wiring problems, sensor or proble malfunctions will cause the whole programming to seriously degrade or crash. Yes, you might get better gas milage because the diesel engine is constructed differently. I would also like someone to bring back the old rotary engine. I like performance with a manual transmission.
The Jeep Liberty CRD seems plagued with problems, far too many problems to warrant such a purchase. Once Jeep can guarantee absolute quality, maintenance and reliability analysis on their CRD's, I'll enjoy reading those CRD complaints and glad I purchased a 3.7.
John
So, has any American politian noticed that we are the corn "cartel"? Demand to your congressmen and senators that no more corn goes overseas till we honor our biofuel supplies to ease the gas shortage. Ohio's biofuel legislation has only produced a "token" gesture, so where has all our tax dollars gone with only 2 E85 gas stations are open?
Jeep is all American and so should our biofuels!
Keep our corn here in the USA!
John
-Sting
Unless an actual jeep mechanic corrects me, I am under the impression that jeep has rolled (no pun intended ) their traction control package and anti-roll into an all-inclusive brake-computer-wheel slip sensor package. While not THE same system, the bragging of the new 4WD system on the Commander is a place to go for the overall theory of how the system works...especially when it comes to understanding what happens at the axles (not the transfer case)
As I understand it, the computer/sensors, notices abnormal wheelspeed (slip) and applies THAT break which then sends the power to the other wheel on the axle. I think/assume the same system controls the rollover protection. While Liberty owners may choose from Full to Parttime 4WD on the transfer case, the Commander with the new 4wd system can go one step further and vary the amount of torque sent to either end of the vehicle at the transfer case.
I would bet a tank full of diesel that this was done to prevent a computer and mechanical (roll-over and traction control) system from working against one another. With the computer controlling all of it, this is no longer an issue. While I have an '05 with Trac Loc, I would not consider it a downgrade (as some have) to go from an anti-slip to an anti-slip, anti-tip system. To me, it seems that DCX has put in a lot of time and effort to provide additional safety without sacrificing performance. My next CRD (10 years and 250k later ) will have that technology plus other technology upgrades as well.
There is one testimonial on the CRD forum on how well this new system worked. See post 2439 of the Jeep Liberty Diesel forum for this testimonial.
Comparing to my Liberty that has 'only' the Selec-Trac and ABS, when I decide to turn on an icy road I can feel it sliding and adapt my speed accordingly. What I fear is excessive confidence one gives to this type of system can significantly reduce the natural reflex of choosing an 'acceptable' trajectory in case of danger. We all tend to pay less attention when nothing ever happens and the driver becomes a passenger when the computer takes over...
There were 8,333 CRD Liberty's made in 2005. What you have read in the Diesel Liberty forum are a very very small percentage of CRD owners. Having has both a 2005 Limited 3.7 and the 2005 sport CRD, I can speak from genuine experience. My CRD is every bit as reliable as the 3,7. The CRD rides much smoother, and is not as jittery on the curves and stright a ways. Quality is equal, and this enging has been in use in europe for more than 11 years with a 2.5 version. I would expect when your 3.7 is just plain worn out at about 150,000 miles my CRD will be going strong for maybe 250,000 miles. (it darn well better!) Good luck, John!
Farout
Farout
Yes I would rather have the mechanical limited slip differential like I had in my Dodge Ram and my 1997 Jeep Cherokee. Putting too much reliance in computer equipment is just asking for trouble, no matter how good you are in bad weather. Once the system fails, you're pretty much done.
I would take a part-time 4 wheel drive system over a full time all wheel drive configuration.
As far as the CRD Liberty's, if Jeep's quality assurance was on the ball, none of the diesels would be experiencing problems such as they are. What doesn't makes sense, the old WWII jeeps lasted almost forever. The older jeeps are still around, yet are constructed with only mechanical parts with little computer assistance. It's almost as if the Jeep's engineers took an idiot pill to fabricate a "weak link" in its jeep line, that of the computer and all the associated sensors.
It's not the type of engine, or the type of differential, what is at stake here is the level of competence in design, construction and assembly. This is where the Japanese, South Koreans and Germans are wiping us (Americans) all over the mat. GM is finished as far as I'm concerned, Toyota is about to hammer in the last nail in GM's coffin.
Jeep is a spirit, that of adventure, reliability and to overcome any obstacle. This notion of pioneerism is about to fall to the wayside.
On this Thanksgiving, I want to be eating turkey in 20 years, not Ramen noodles, squid and kelp. So Jeep, take warning, will you be in existance in 20 years? Stop taking those idiot pills, and hire a mechanical engineer instead of an electrical engineer.
John
When you factor in only 8,333 CRD's were made for US use and that the level 2 bin 10 was reached this is a significant achievement. The CRD has a dealer lot life of 23 days. That is very excellent compared to regular Liberties.
The Transmission is also used with the Dodge "HEMI" in all the places a "HEMI" is put in. Does that not say something a little more assuring? Can you say "HEMI"? I consider the "HEMI" the most hedonistic proof of manhood anyone has ever come up with. How much more wasteful can anyone become?
Farout
I still can't believe I'm still talking about the CRD's. I have to stress that its not the engine or the type of transmission, its the quality put into the product which translates to market share. Right now, Jeep does not have market share. I have to ask why? If you look in Edmunds used cars, you find 72 CRD's (2005) for sale. Wow, 72 people who represent a very powerful force against Jeep's effort to portray reliability and durability.
Jeep's rise and fall will not depend on the CRD. Why was the Gladiator project cancelled? Was it because it had a CRD or did we absolutely need another pick-up truck. Toyota is blowing everyone out of the water with every type of pick-up and suv imaginable.
So, Jeep needs market share. I would say if Jeep would buy back those 72 CRD's, you now have 72 potential buyers who might stay with Jeep. I would have purchased a Commander if it had a manual transmission, but No, it had to stay with an automatic.
The design of the CRD Liberty might be improved by starting talks with Cummins and incorporate the 4B (3.7L) diesel (which would be rather big, considering, but an engine around the 3.0 liter size) because Cummins represents more of an American image. Market share is about Americans buying American.
The NSG370 manual transmission was designed too high (in gearing). The final 6th gear is .84, but should have been .78(.) But look at all the other SUV's out there, only the Jeep Liberty has the performance with a manual transmission - That's market share.
Jeep Liberty CRD, the only vehicle out there with a diesel engine - That's market share. This is a good thing, I am trying to tell you. But, if Jeep doesn't come to grips over these 72 people, you can just kiss those 72 people away and all chance of getting back your original market share. The CRD is rapidly becoming a "cult", and in their haste to make production quota, messed up royally. Tell that to those 72 people.
And do you think Toyota will make a diesel here in the US(because they do in Europe)? After what happening to Jeep, not a chance. Just watch. Toyota will stay away from the diesel concept like a hot potato. Especially when the new diesel environmental regulations go into effect for ultra low particulate and sulfur emissions in 2006.
Its all about market share.
John
I can't imagine if attaching the bull bar to unsupported sheet metal/grill fiberglass might do if you actually hit a deer or ran into a tree.
I would be curious where you bought it from, and I'll be sure not to use that particular vendor.
John
I'm a new member, but have been reading the forum for a few months now. I ordered a 2006 limited CRD Oct. 5th with a delivery date of 6-10 weeks. Well 10 weeks have gone by now and I'm told the Jeep is still "scheduled for build" . I'm also told the plant closes for a couple weeks in Dec. and so there is no one there to answer as to why the build hasn't started yet. I've searched the net but haven't seen anything about delays in builds. Has anyone here heard of anything that would delay this out to what now appears to be 15 weeks?
Thanks for any clues...
Michelle in New Mexico (crd4me2)
If you deal with ice at all, you will want to buy something with the snowflake "severe winter" symbol. Otherwise, quiet ride is what you're looking for. Check consumer reports for this. Many SUV tires sacrifice some ride for increased load capacity (like the Long Trail BFG).
Iridium spark plugs, vendors are Champion and that Japanese brand (MSG - whatever, I won't be buying these)
I do not know what "stock" spark plugs are used in the Liberty, whether Platinum or Copper. To save on costs, they are probably copper. The costs of changing spark plugs every 10,000 miles or only buy one set of Iridium and forget it.
The Dodge Nitro will only offer an automatic transmission. I'll bet, since its being built in Toledo, will have the same problems as the Liberty. Like rear brakes FUBAR and Parking brake AFU. Not to mention a whole assortment of computer problems and ball joint problems like the Durango. Never buy a car when its first introduced.
What's up with Liberty CRD? They stopped production?! What's up with 75,000 Liberty's sitting at the docks in Toledo? Is there any wonder why Americans are not buying American. Do you think management cares about the little guy who buys these cars, but realizes they are junk? Management doesn't care. Jeep better straighten up and get back to basics, because their future looks dim.
I care about Jeep. It's just they don't care about me.
What's wrong with this picture?
John
With manual transmissions, you eliminate all associated computer programming which "would" have been applied to the automatic transmission. You eliminate all problems with the torque converter. I can't pull 5,000 lbs, but I wouldn't use the Liberty to pull 5000 lbs anyway, primarily based of its (Liberty's) light weight.
The Liberty is the only small (American) SUV that offers a manual transmission, a strong 3.7 liter engine, great 4x4 ability and a towing package.
Manual transmissions do not exhibit braking problems associated with automatic transmissions. Hot rotors from constant braking, premature failure in U-joints, ball joints, steering knucles and grease fittings.
Steering control under slippery conditions is an acquired art. Manual transmissions put you in control during those difficult situations, but the key is, you are in control. Downshifting, light braking and proper steering wheel alignment when sliding encourages more driver input and anticipation.
So, get out there and work those sticks.
John
