Chevy Silverado/GMC Sierra - Owners hangout
Phil
Well to make a long story short, reset the meter and the truck started right up.
Since no one actually mentioned to you how to reset the oil light, I thought I'd tell ya. I had my brother do my last oil change and I reset the light myself, so it's no big deal.
Turn the key on - but not enough to start the engine, Press the gas pedal down and up quickly 3 times within 5 seconds. You should see the oil light flash. Then bring the key to normal 'off' position and try to see if you reset the light. It's a little tricky getting the pedal down 3 times in such a sort timeframe.
Good Luck!
Truckchic
I bought my springs, pump, and controller through Les Schwab and had them do the install. They installed the pump on the fan shroud, near the battery, and ran the controller lines through the firewall right next to the steering shaft. I have pictures and will post them when I get the chance.
try http://www.kbb.com
Ryan
Peter
Blackmax did a nice review of a test drive of a Dmax/Allison equipped 2500. I agree with him on the length issue.
Peter
My understanding is that the computer takes into account your driving habits and conditions and actually informs you when to change the oil.
Go figure.
DC
As for miles between.....there is no sensor that won't let the engine run if it's not changed. I have over 8000 miles on this Mobil 1...and she starts fine...(light has been on for about 3200 miles)
- Tim
One Mobil 1 M1-206 oil filter: $9.99
Lift rental/oil disposal: $8.00
Oil change and lube done right: Priceless
This may cost a few bucks more than one of those oil change shops, but at least I know it was done right plus I have the added benefit of a synthetic oil and lube. I had to replace the hose on my lube gun so I also added a 360° swivel to the coupler and what a difference it made! I would seriously recommend doing the same if you have your own grease gun. It makes it much easier to keep pressure on the coupler plus you have the added benefit of being able to more easily line up the coupler.
I dont even need to jack up my truck to change the oil
FILTER 9.99? DAMNNNNNNN i paid 50 cents each for my AC Delco's (which is recommended by gm)
Is this something to be concerned about or is this normal?
Thanks for any info...
My oil pressure has always been the same...60 lbs while driving, a little over 40 lbs at idle. I have yet to see a PF-59 here in town. PF-58s are available, but I understand there is a difference. I'm sure the dealer has a PF-59, but it wouldn't be much cheaper than the Mobil 1. As much as my truck cost, I'll not squabble about the price of the Mobil 1.
(1) Sturdy 1" wrench nut makes removal quick and easy.
(2) Drilled safety wire holes for racing.
(3) Metal leaf spring provides a positive seal between element and lid.
(4) Heavy-Duty construction provides over 550 PSI hydrostatic burst strength.
(5) Resin-impregnated filter media provides maximum filtering surface for contaminant removal.
(6) Inner core provides extra structural support to prevent filter collapse.
(7) Anti-drainback valve eliminates dry starts, prevents oil from draining back into crankcase during engine shutdown.
(8) Rolled threads provide extra protection against stripping.
(9) Leak-Proof double roll stream.
(10) Internally lubricated gasket provides seal while allowing easy on and off of filter.
1-There were no PF 59 around.
2-Like that nut shape on the bottom for easy removal
3-Due to its cost, its always available at Checkers...people tend to by that el cheapo fram.
Course on the Denali, I run the cheapest oil filter which is Fram and regular dino...Chevron brand 10W-30 from Costco....$9.99 a case of 12. One of the advantages of leasing I guess.
The locking mechanism is easy defeated and the bezel is cast wrong, can pull it out with one finger nail, not tight at all. The manufacturer stated that when the bezel is installed it is there to stay, what a joke. I threw mine in the garbage. I'll consider this a $26 lesson. Does anybody know of a quality tailgate lock? Is the power tailgate lock worth the price? Thanks.
Conrad
Anyone else have this issue?
Truckchic
Seems like there was a defect in the sealer they used when the truck was manufactured. Why else would they be issuing new bumpers from a new supplier with a new sealer?
Look at your bumper really close. The other part I found it was just along the top step on the back bumper. Where the chrome meats the skid proof step. (I'll try to get a picture of where I'm talking about)
Truckchic
Now I know each of you has tested your security systems. You roll down the window, close the door, arm the system, reach in unlock and open the door. The horn and lights go off. You then close the door and the horn and lights still continue to operate. This will still occur with the tailgate set-up. 15-30 seconds is plenty to get the security system going.
What I do need is a wiring diagram to see which wires are which. Maybe Obyone can help me there. I'm going to go ahead and get the parts together and make everything water tight. I already have an idea where to put the switch, where it is out of the way and operable. I would appreciate any feedback. Thanks
Valky
Erik,
The R&D Acc. lock is a power lock. I believe the Pop Lock is key operated. The R&D set-up is $60 plus shipping. The job took me about 2 hours because I had to do some modifying to thier bracket, the holes did not line up exactly. Not to mention the guy that did my LineX liner stripped one of my handle bolts. After you mount the unit and run the wires in the tailgate the next step is to run the wires to the front of the truck and into the cab. Their instructions are lacking, they are not complete and you have to guess somethings. They state that you have to drill a 1/2 inch hole into the bottom of the cab. No way was I going to do this, so I pushed the wires through the rubber plug on the firewall under the windshield wiper motor. I took a razor blade and cut an X into the rubber and pushed the wires through, then sealed the hole with black silicone. The wires hook into two wires at the fuse block, easy to get to. So far works great.
Valky
My reasoning here is that I have always been told one key to engine longevity is good oil pressure and low coolant temp. Any thoughts or advice would be appreciated. Thanks! 01 4.8 3.73 locker.
-- Don
The truck is only 4 months old when I noticed the rust, and it wasn't in any type of winter weather, so that's why I couldn't understand it. Then when I took it to the dealer and they gave me hassels, then when I called back about it they had ordered me new ones from a new supplier and a new sealer applied, I knew there was something up.
Watch those bumpers!
Truckchic
you can't buy too much truck......but you can buy too little..
you can buy extra and not use it...but it's kinda hard to buy less and try to "find" more....
I'd go with a 5.3/3:73
- Tim
