Chevy Silverado/GMC Sierra - Owners hangout
12425272930184
  • ryanbabryanbab Posts: 7,240
    Sounds like a good price. Guy quoted me for $725 installed
  • 87lion87lion Posts: 166
    That would be x-cab. I don't remember seeing many regular cabs on the lots either. Almost all x-cab shortbeds.
    I kind of like the Chevy grill, although I think the billet grills look good too.
  • obyoneobyone Posts: 8,054
    Stock chevy grill reminds me of a checker board.
    Interesting to note that two people here have ext cab LB trucks. Sometimes, I think I need a long bed too....then I empty the junk out of the truck and no longer need it.
  • txyank1txyank1 Posts: 1,010
    Maybe the 2500 Suburban grille is diif. than the 1500. Every Sub. and Tahoe I've looked at the grille is black with chrome surround. Just the opposite of the trucks.
  • jaguar0027jaguar0027 Posts: 387
    You are right about painting it black! Would save me some $$$ but the billets.... ohhhhhhh they look sooooooooooooooooo nice. LOL
    Ryan - I may be getting the ARE cover soon. I will let you know how it goes. Just need to save up a little more $$$$ if you know what I mean.
    Also.. what all does the HPIII do for ya? Are they super expensive???
    Jim
    P.S. Got a Duraliner drop in bedliner in my truck last week for my birthday! WOOHOO! :)
    cost me $279.99 most places have them around 300-330
    I have mine for the different tire size and shift firmness all i use it for
    Ryan
  • mgdvhmanmgdvhman Posts: 4,162
    For the longest time on my 2K 2500 Ex.cab 6.0 4:10 245's...I always got 12.5 MPG.....city or highway. Around 30K miles I started checking it again and noticed tanks were in the 14 Plus range. Truck turned 36K last on Friday before a trip I took.
    On the highway now...75-80 MPH with the AC on Max and fan on high almost all the time....outside temp of 92-97 degrees...it got 15.2 and 16.8...for an average of 15.89
    Not bad for such a gas pig at first..
    wonder what an 8.1 will do after 30K?
    - Tim
  • minikinminikin Posts: 389
    I think I paid $340 0r $350 for the HPIII from Summit Racing. I've never seen them as cheap as what Ryan got his for; wish I'd thought to ask where he got his before I bought. If you go over 265x75 on the tire size, they're essential because GM can't reprogram for the larger tire sizes. It's not just a matter of speedo/odo readings, shift points and abs settings are also computer controlled and noticeably adversely affected if the correction isn't made. I use mine for tire size, shift firmness, top speed limiter, and fuel grade/timing curve optimization settings/corrections. If you live in a warm climate and want to drop the thermostat opening point, it can optimize for that, too; as well as WOT shift points and some other stuff. Well thought out product and more than worth it to me.
    -- Don
    Got mine at a local autoparts place thought id be paying at least $350. When he said $279 my jaw hot the floor. I had to ask him to repeat the price hehe
    I don't know; figure higher empty weight and bigger motor -- maybe 10.5 to 12? Too bad they don't put that motor in a 1/2 ton, stick. They could call it the SS 4x4 8.1 Z71. 'Cept you'd need a long bed to get all those decal letters on there.
    -- Don
    Like one of those deals where the guy might be reading off the wrong column on the price sheet, and you suspect that could be what he's doing, but after you ask him to repeat it you aren't about to argue with him anymore?
    -- Don
    today. Went pretty smooth. About 15 min. I didn't have any burnt out, but the plastic housing was sure black and burned looking on both, where the bulb goes into the housing.
    ...Now Ryan is gonna be asking about Amber DRL's!
    LOL
    ..Don,....some people say they get 12.5 or so in the 8.1...(same as I used to get in the 6.0).....so who knows?
    - Tim
    dont worry i wont
  • dmnsmith2dmnsmith2 Posts: 21
    Can anyone tell me what this option is, detailed? TIA!
    do have that Passenger DRL that has been out for some time....I gotta replace that....but then I'd have to keep the truck for a while.....and I really should install that filter and get use out of that as well...
    hmmmmm
    gets good MPG now...warranty over....can go to the places I really want to fix it when needed....maybe keep it 5 more years!
    hmmm
    - Tim
  • geowpowgeowpow Posts: 3
    I have a new 01 Rado x-cab 4.8 3.73 locker with 1800 mi on the odometer. Took a 300 mi trip today (Orlando to Sarasota and back) and averaged 21.93 MPG @ 75MPH with AC. Granted, this was all flat country, but I was so impressed I just had to share. BTW, I have no front wheel or front end shaking and no dreaded cold start knocking, tapping or pinging. So far, everything as advertised.
    In AutoTrac the system senses rear wheel slippage and, through a servo in the transfer case, engages the front axle for the duration. As a practical matter (assuming you want/need full time or quasi-full time 4wd) it's a hell of a lot better than the old, open diff NP203 system Chevy used in the '70s, but not as good as Jeep's full time proportioning differential, Quadratrac. If you leave Autotrac on it engages the front hubs full time and will quickly react to any differential slippage of the rear wheels (like tight turns at an intersection). It will cost maybe 1+ mpg, plus whatever added front end wear. Most(?)folks use the 2WD option in high traction conditions, Autotrac when the roads get sloppy (I just leave it on most of the winter in Denver), and 4Hi or 4Lo when you need it for whatever pass you're driving/crawling over. For what it's worth, while I liked my Jeep Grand Cherokee's drive system better for it's totally seamless and unobtrusive operation, overall I wouldn't ever go back. The Chevy Silverado/Tahoe/Suburbans (& GMC variants) clearly outclass the Jeeps.
    -- Don
    After all that about a 2500HD you're going to keep your current truck??? Your wife got to you, huh?
    -- Don
  • gmc2500hdgmc2500hd Posts: 2
    Hello all;
    I've enjoyed the comradeship amongst truck owners. I have a '01 2500HD-8.1L 4x4 Crew cab, with 4.10 diff.
    I've enjoyed every minute driving this truck. I even find places to go just to drive it. I'm getting about 9mpg city and 12mpg highway. I've just installed a Flow master on it with dual in/out that they just came out with for the 8.1, and it sounds great and is even performing better.
    The reason I'm posting is to solicit the comments of anyone that is having problems with heavy vibrations on the concrete highways with vertical rain groves. It also rides much rougher than my '99 2500.
    This is the only problem I've had with my truck other than on one occasion where the transmission seem to downshift to a lower gear at the wrong speed. I am taking it to the service kept tomorrow to have it checked out. Any comments would be greatly appreciated.
    Thank
    maybe because its a 2500HD and its built stiffer?
    gettin' to me......I think my bar project has made me lose interest for a bit about an HD?
    I have wanted an HD for a year or so...wanted the bar for 22 years...
    gonna be too cool when I am done with it...
    - Tim
  • 4x4man4x4man Posts: 222
    My 4x4 2500HD doesn't have any vibrations on most concrete highways, but when hitting an expansion joint, it will buck...the nature of the HD beast. Also if the hired help (read: cheap labor) wasn't quite rested from the night before's drinking, the surface of the highway is not smooth and level. In that case it starts getting a bit rough and bounces you up and down....another nature of the beast with the stiffer suspension of the HD.
    I "upgraded" from a 97 4x4 1500 so my new truck hands down rides better than that thing did, not sure what a 99 2500 rode like..sorry can't help there..
    Bob
    Yes you do!
    LOL
    - Tim
    I am a proud new owner of a Silverado. There is a wiring harness in the glove box that is supposed to be used for modifying the connection that I have at the bumper, or something. Can someone shed some light on what this is for?
    TIA
    thats for a trailer brake.
    TIA
  • ricschricsch Posts: 540
    Seen in a fleet catalog that GM is putting in sunvisors with extensions, I would assume similar to the Tahoe and Subs? Now hopefully they will fit the existing Silverado and Sierra trucks.
