Chevy S10/GMC S15-Sonoma: Problems & Solutions
I know it's been a long time since your post, but I appreciate your post. I'm paranoid of breaking something and the info that the panel just pops off is a great relief. Thanks again for the details.
Thank you Ed
My gas mileage started declining about 15k miles ago. But there is more to it than that. I've had this intermittent miss that iI've been trying to track down for a long time, replaced everything but the coil in the ignition. It finally wouldnt start one day and i found out it was a bad distributor cap. (Those are a bad design - im on my fourth or fifth one since ive had the truck and two of them have failed completely) I replaced it with an expensive one and the miss went away. Did i mention the miss stayed there through three different caps? And then shortly after, the catalytic converter went bad. I just took it off and banged everything out of it. Now my light stays on all the time and I dont know if there is another sensor out or if it is because i dont have a converter.
And to get the middle spark plug out... Jack up the front end and take the tire off. Then you'll need a spark plug socket that has a nut like thin on the end where the socket wrench plugs in. put your socket on the plug and then put and open end or box wrench on the socket and prepare to spend the next 30 minutes removing it about 1/16 of a turn at a time - if you're fortunate enough not to have much corrosion on it.
I know this is old stuff, but this question needs to be addressed because it is going to be a ongoing issue. richp2, posted the best remedy to the cable replacement issue. NAPA has the cables with a new pin and e-clip. You simply grind the rivet off and replace it with the new pin and clip. Bought a set today ($10.50 ea) and about an hour later my cables were as new again.
The next morning after I brought it home, when I first started it up, it sounded as if I’d just changed the oil: it clattered for a second or two, then sounded normal.
Next morning, same thing. So, I changed the oil and filter, even though the dealer had done that as part of the intake manifold gasket job.
Next morning, same thing. And every morning thereafter.
A couple days later, the engine started making very bad sounds while driving at normal operating temperature. I took it back to the dealer (having driven it 300 miles since the gasket job), and they said it sounds as if I have a bearing in the bottom end going out. They offered to put a used engine in it and to split the cost with me. (“Without admitting any fault,” they said.)
I think that they know they did something wrong. Does anyone have any ideas about what may have happened?
Thank you very much!
kcram - Pickups Host
sorry for the duplicate posting..hit enter accidentally.
The problem we have is that we have lost our low wiper speed. (we do not have the intermittent feature)The question is, do we replace the switch, or is it the wiper motor? anyone else have this problem?
We also are experiencing the chirping noise that others have mentioned. It can be annoying, is it the throw out bearing,?? is that hard to grease? My husband is able to fix most things, so we don't like taking the truck to a repair shop.
We also are experiencing the chirping noise that others have mentioned. It can be annoying, is it the throuw out bearing,?? is that hard to grease? My husband is able to fix most things, so we don't like taking the truck to a repair shop.
We would like to add that we are very happy with our little truck!
Any ideas? The hitch is a Type 3. 750-500 tounge weight.
It may just be to big. I checked reese. All they showed were diagrams on assembly. Hope there's help. Thanks Crabs.
" My garage mechanic says that the problem is inferior American quality in the cars they build"
Is that another way of saying he has no idea how to fix it.
