Mercedes-Benz C-Class: Accessories & Modifications
hoppyeng
Member Posts: 25
I want to replace the current shift knob with an all wooden one for the C320. Does anyone know if they made one for the C320? If so, where to buy it?
Are these corner lights for real? Do they fit properly? Quality?
water in the trunk and water inside the fog lights.
While the quality of American cars is improving Mercedes is going down hill,what a shame.
This is my first Benz I traded a 1999 BMW 528i
big mistake. Thanks for listening
Or you can purchase OEM MB 6 CD Changers from the following vendors in US. One is from www.clairparts.com and the other is www.autoclass.net.
Or try ebay, but I would not recommend because the quality of the cd changer you would get is some what unknown, unless you can inspect the changer before you bid.
The only issue I see is that because it is an electrical item, it is only waranteed until installation - so if for some reason you were to get a bum unit, you would never know it. Worse, you couldn't prove it was inoperative when you received it, and couldn't return it!
For this reason I may spend the extra $ and buy from the dealer - *ouch* - but with these sites at least I have some ammo to support a better deal, if possible. ;-) Thanks!
- Paul
1) any difference between OEM CD changer, and the one that I will be getting from a MB dealer?
2) do I need to buy the mounting kit and cable in additional to the CD changer?
3) my dealer charge me $220 for installation. Can I have it installed elsewhere, or must it be a MB dealer?
mounted on the front dash (over the center speaker
woofer). I think that this way is far superior to purchasing an aftermarket version.
I would love to hear some feedback from anyone who knows how to obtain these parts. I suspect that it's a fairly simple system.
1. Is anyone aware of a bicycle carrying option for the C230 ?
2. What level of discount is available on this vehicle in Canada ? (I have read about big bucks in the US)
3. Is it worthwhile considering the "demo" units, or is this just asking for trouble ? (I'm a little concerned about reliability based on some of the other postings)
I also have a 2000 C-230 Sport but have not considered a chip. I would be intersted in your findings.
- Paul
you can find a nice upgrade that will raise hp of the mb c class for 12-17 hp at www.renntechmercedes.com they have a big line of products
Traded in the '99 C280 in Sept.'03 for a M-B C240 with 4Matic. The new car is great. But, I wish the car had the xenon lights. You will like them if you install them on your car. Guaranteed.
http://www.clearbra.net/
I am especially interested in removing the speed governor.
The original rear wheels of my C230 Sport Sedan (2004) are of 8.5 X 17 X ET34.
Due to accident, I looked for a replacement and found a wheel of 8.5 X 17 X ET30.
I'd appreciate help with answers for the following questions.
What is the meaning of ET34 versus ET30?
Is it OK to replace the ET34 with ET30 wheel, although the first two numbers (8.5 X 17) match?
Many Thanks.
So if you have a 2003 you must try the aftermarket. Try a really good sound shop or Crutchfield on line, not Circuit City or Best Buy.
Hope this helps.
Mercedes has a new rear deck ant that is much smaller than the "hump" version that goes on the trunk deck lid. You can order thru the dealer and they come pre-painted to match the car.
Has anyone tried using the AUX option. On the 2005 C I have the upgraded harmon/kardon audio system. There is an AUX cable metioned in the book and I'm wondering if this is what you use to interface an IPOD.
Also, on the 2005 C is the harmon/kardon logo only on the left rear speaker? Does the BASS response seem a little weak? Seems like our 2004 with the standard stereo has much better BASS response. Is the "surround" option only found on the upgraded stereo in the 05? The 05 has terrible radio reception. The dealer is replacing the AMP and installing the satellite radio on Monday. Maybe this is why the BASS is so weak.
Has anyone replaced the front light assemblies on a 2004. I really like the look of the clear lens on the 05.
Thanks in advance.
I can't provide you with any answers to your questions, but I was wondering if maybe you have some answers for me. I recently got a C240 4 Matic (this is my fourth C class car) and I have to say the standard stereo system is poor sub-standard compared to previous models.
Can you receommend anything for upgrading? Where do you go? To a MB dealership or outside stereo provider?
Thank you, best of luck.
Linda
NJ
I recently leased a new 2005 C240 4 Matic, which came with Sirius satellite radio. I really want to switch to XM, but is this possible and is it more trouble than its worth?
I have to say Mercedes has certainly cut corners on the quality of their standard stereo systems. I'm not happy with the quality of the one the car came with. When I switch from AM to FM or from radio to CD and back to radio the volume is inconsistant and blarring. CHEAP!
Please advise....
Linda
NJ
The dealer will be real expensive. I would go to an high end audio shop and see about adding an amp setup and some new Alpine Speakers. Try the speakers first. Also, you could call Cruthfield. Maybe they can help.
I have a 04 C240 4matic. Currently with 205/55-16 and stock rims. The dealer had the car for a week. Got it back went to have the tires replaced and found out that someone bent a rim which causes a shimmy at 60MPH. So I will replace the rims or upgrade both the tires and rims.
I have found an OE Performance rim that looks like the E class rim. It comes in 16" and 17". Has anyone had any experience with this rim product? It is the OE performance 300M E class.
I will either have the 16" with Michelin Pilot Exalto AS 225/50R - 16
or
17" with Michelin Pilot Exalto AS 225/45R - 17
Anyone got any other ideas? I do not want the car to look too extreme. I would like to stay with the 16" size.
Thanks in advance......
Check it out!
C220 Thule Roof rack, Item number: 7193512636
thx!
Did you have XM installed on another car before installing it in your Benz?
The dealership cannot help me b/c of their contract with Sirius (ugh!). I'm wondering if the BlitzSafe adapter I used to wire the XM through the radio for my BMW will work for the Benz. Since I already have the receiver and adapter, I was hoping to just use the same equipment...
Any help would be appreciated!!!
