Here in Wisconsin, they are offering about the same deal, but I don't like the colors that are left.
If you'd like, please e-mail if you'd prefer.
It seems to work as represented but the pucker factor is high. I can barely resist hitting the brake when the vehicle ahead brakes. ;-)
Roll
This sucks, sucks, sucks. I love this car. Love it. But I can't keep a car that causes me physical pain when I drive it for more than a half hour at a time.
And before anyone asks, I'm not morbidly obese or an NBA player. I didn't actually have my wallet in my back pocket (or anything else) and I tried every conceivable adjustment to the seat position.
I have checked mine and note an inconsistency between the analog and digital indicators.
The analog reads about 2.5 to 3 mph high but the digital reads only 1 to 1.2 mph high. I'm checking this against an independent GPS, (Garmin).
Anyone else check and what did you find?
Roll
ncvol- that's too bad. I haven't noticed any interference from the seat controls with comfort (5'10" and 160 lbs), maybe I'm small enough for it not to be an issue.
kcrudup- my 03 45 doesn't have an indicator light on the dash when in manual, only when ICC engaged. I wonder if it's burned out - I'll have it checked. Thanks.
BTW, you may want to check with some of the larger Infiniti dealers regarding your exact color and options. Examples are Grubb Infiniti in Dallas and Infiniti of Scottsdale (Az.) as they may have the exact car you want in stock.
Also, where do they place the surface-mounted exterior antenna? Is the antenna feed pre-wired at the factory, or does the head liner have to be removed?
I'd like to purchase an XM unit as a dealer-installed option when I get my FX, and am wondering how "messy" the installation is...
Several points:
- with the nav system, the XM unit will show only 10 characters of the artist or title. Sirius apparently shows entire wording. Both XM and Sirius apparently show all wording with the standard LCD, i.e. non-tech. At first we thought it was due to the dealer-installed unit, but a FX with nav and a factory-installed XM just came in and has the same quirk. Dealer is still trying to get Infiniti tech service to determine where the problem is (i.e. in the radio or in the XM receiver). Not a big deal, but some lost functionality.
- The Houston dealer says Infiniti is not supplying any additional XM wiring harnesses to them. Not sure why other than Infiniti misses some profit when the dealer does it (for $300 more than the factory install). You may want to confirm availability in CA.
- If possible, I would try to get a low profile antenna installed. The "kit" antenna is a tad "ugly" with its higher profile.
Anyone else have this done?
I'm paying $275 for the front and $40 for the rear.
Roll
- on a non-tech, both Sirius and XM display the entire artist and title in the center of the lcd. It may have to scroll through to see all the characters, but you can see all eventually.
- on a FX - tech, the artist and title are shown one item at a time on the bottom of the screen (you have to manually advance the readout from ch to artist to title, etc). Again my understanding from the dealer is that the Sirius/tech units will show the entire title or artist (not sure if it scrolls or the entire title is showing), but with the XM only 10 characters will display and no scrolling. For example, for Paul McCartney, one would see Paul McCar and that is all.
Is this how yours operates? Maybe other sat owners can give use some input.
http://www.infinitiwholesaleparts.com/en_US/
...click on the FX35/45 tab.
Thanks in advance.
On no setting does the display show more than 10 characters per line, and there is no scrolling that I have been able to find. My display will show something like this:
Top Tracks
Bruce Spri
Thunder Ro
Right now I'm thinking about going in for the free one at 3750, then coming back at 7500 and putting in synthetic at that time, and then waiting 7500 between changes from that point on.
Also, check out the boa. It allows you to lose the long unsightly wheel tray - looks better on the FX - minimalist.
Sort of a status thing?
BTW, I notice there is no FX-problems board here. Should I take this as a good sign? I see a lot of activities in the Lexus problem board though. Thanks.
Take your wife out and let her see the difference in performance in exchange for a little harder ride.
1. Airbag ECM reprogramming
2. Brake bolts to be tightened
There was another recall but it did not affect all FX vehicles:
3. Tightening of screws of propeller shaft.
There were issues with the rear hatch warping due to extreme hot weather but not all FXs seem to be affected. However, Infiniti decided to fix these instead of replacing hatches of all FXs.
BTW, these are for 2003 models. I believe the 2004 models are unaffected.
Another very annoying issue on the FX and also seems to affect quite a few of the Nissan/Infiniti vehicles is the brake squeal. It sounds like you're driving a school bus or dump truck everytime you brake. It's really annoying but it seems that it does not adversely affect the performance of the brakes as ours still stops on a dime. I've heard similar behavior from 350Zs, G35s, and Muranos.
Other than those minor issues, the FX is quite reliable and trouble-free.
