I drove a FX35 AWD Sports Package before deciding on the Premium Package, I couldn't tell much of a difference in the two.
I have been searching all over the internet for the 0-60 times on the FX35 AWD, anybody find anything?
Congrats on the new ride!
Here is one of the tests:
I put my G-tech Pro in my FX35 AWD Sport and got the following figures on 3 different runs:
Numbers are 0-60 (sec.), 1/4 mile time (sec.) @ speed (mph)
7.11, 15.55 @ 91.9
7.08, 15.34 @ 93.4
7.18, 15.60 @ 92.0
Pretty consistent numbers. So 0 - 60 averaged about 7.12 sec. ... a little faster than i expected.
This was done with a little bit of power-braking and leaving the trans. in auto so it shifted itself.
For those of you wondering "what is a G-Tech Pro?", see:
G-Tech Pro Website
Nice times!
How many miles did these FX35's have when then did these obviously full throttle runs?
Is there no break in procedure for Infiniti's?
Just enjoy your rides, guys...
My dealer quoted me $70 labor to install the splash guards because according to them the wheels need to be removed to install the splash guards?
did you need to remove the wheels to install the splash guards?
The vehicle was outstanding, and I didn't think the vehicle's ride was too harsh at all. I felt like I should be driving it like a sports car. The sound of the FX 35 exhaust was really nice.
In the end though, it didn't have enough rear seat legroom and the hatch area was REALLY small. We went down the street to the Lexus dealer and when my wife saw the new RX330, that was it! Since the ride was for her, I agreed.
We ended up with a 330 with the performance package and my wife could not be more pleased. The ride was a whole lot more luxurious and it had more room in the back.
Thank you for all the info on the FX and all you guys enjoy your vehicles!
They also have approximately 50 coupes in stock now and my local dealer has zero.
Obviosly the FX is more primal in it's aspirations, and more desperate to make an impact! It seems like it is built with wealthy men in mind (vs the X5).
I find the FX ads are more canted toward women than the Lexus RX ads!! Very....... romantic?
Kind of make Aviators and ML500's look tired and weak.
P.S. The fact that you have a RWD FX should not make any difference for towing. If it was FWD (like a basic RX300) then it could be an issue. Also, just FYI, my dealer has already installed several of the hitches (which just became available) on other FX's, and he says the labor is taking about 3 hours to put them on, so he's raising the charge to $790 which includes the hitch, the wiring harness and the labor. Originally he was charging $590, then $690 and now $790. Glad I negotiated a charge of $500 when I bought the vehicle!
--a good number of women, including my wife, do love the fx and think it's quite gorgeous
--the firm ride is an irritant at times. Had a 94 Montero with the same ride and, after slightly deflating the tires, it was much improved--only a few pounds of pressure less. I may try this with the fx, unless someone tells me that I'll ruin my tires
-- the radio reception is quite weak. The Audi Bose was much better and our 01" GTI VR6 Monsoon is much better as well. Is the short antenna the issue?
A question--does the hitch ruin the look of the rear end?
Second, which I think might be more of a concern, is that the black molding on the top of the rear hatch seems to warp/buckle in high temperatures. It seems that the adhesive that was used to secure the molding is not too tolerant of high temperatures. When the molding warps, it impedes the opening of the rear hatch. For the few cases reported, Infiniti is replacing the whole rear hatch, not just the molding.
So, as much as possible, try to park the FX under a shady area if your part of the world is experiencing high temperatures. It may prevent the issue.
Our FX35 has been pretty trouble-free...no squeaky seats either.
For those who wonder about mileage, 85/15 hwy/city I get a consistant 19.5-20.5mpg.
I have the Tech Pkg., so my FX has the Tire Pressure indicator. This morning the "alarms" went off, and after scanning to that screen, it showed me that one tire had very, very low tire pressure (evil screw in the tire routine). You know, I never could figure out why it doesn't correspond what tire it is to the tire pressure on the screen. When they took the tire off of the wheel to patch it, I saw the pressure gauge on the inside of the wheel. It must send a signal with a reading, so then if you rotated tires suddenly it would be on the front vs. rear, or visa versa. So, they can't label it. Make sense?
My seat creaks TERRIBLY. I took it to the dealer and they told me "it's normal." Although, my dealer's service department has always sucked. All I have to say is that it's getting worse (it rocks in it's track, too) and it certainly didn't do it when new. I guess I'll have to go back. There is also some bizarre really loud creek noise by my left ear when I go through a bump that causes the vehicle to "flex." The open sunroof visor makes noises, too, so I just leave it closed mostly.
The transmission recall is interesting. I noticed when going over abrupt bumps (even at slow speeds) like a speed bump that the transmission shifter moves around quite a lot. I've never seen anything like that happen before on another car. Could that be related to the recall?
Otherwise, it's perfect! No problem with the hatch, but I park in a garage almost all of the time.
Someone had complained about the Bose stereo; my reception is excellent and the sound quality is fabulous.
Speaking of the Bose I agree that it sounds really good. Easily the best Bose system I've heard personally - much better than in either of my two Audi's. I think the center speaker up front helps give the soundstage added presence, and the subwoofers in the rear give it all the bass I need. This was a pleasant surprise after hearing the system was made by Bose. When testing it out I also took a couple of my homemade CD's that wouldn't play in my allroad Bose system, or in my main DVD player at home, and they played fine and sounded great on the FX Bose system.
Observations after 600 miles--ride is quite harsh from the BACK seat, whcih ususally will be unoccupied. Also, the back doors have restricted swings and the cut outs make entering and exiting inconvenient. Otherwise--car is perfect.
Yeah, which is why we got the FX35 AWD with Premium Package only since our back seat has residents. It'll be too hard for them.
I actually find that the doors open up quite nicely since it's almost perpendicular to the vehicle when full opened, i.e. opens 90 degrees.
Yeah, I agree. Try putting toddlers in car seats.
Try Vinylex (from the makers of Lexol) for the black trim:
Ours look great after one application. For more info, see Vinylex. It's available at your local Pepboys.
I was looking for the 303 Protectant but could not find it without ordering online.
