Yeah, everybody knows you are supposed to use your legs to push against the floor to hold you in.
(Really, I remember tooling around in the back of an early 70's Landcruiser sitting on square boat cushions on top of milk crates!)
Really got clobbered.
Drove around Worcester, MA last night with the wife, topless (the JEEP!!). It was chilly, and we had two sleeping bags to return to her parents, so they were in the back. She took one, and wrapped over her legs and lower body, and was nice and cozy.
So, here is my just started list of things to keep in your Jeep:
sunscreen
bug spray
small blanket (space blanket or thin wool/fleece blanket should do)
flashlight (always keep one in the car)
flares
towing equipment
matches (if stuck in the woods, a fire is nice)
rag (for wiping dew off the seats, or checking oil, or emergency bathroom use)
Personally, what I would like to see avoided is an initial post of "Dealer x is terrible!" with no explanation, but in your case, you had an issue, got a diagnosis, chose to get a second opinion (that countered the first opinion), had the secondd dealer do the work and up to this point are satisfied the problem was fixed. Thoughts about the appropriateness of calling out dealers based on thier service?
As far as what to carry in the Jeep, I have a page that lists items compiled from JU. It is more geared toward someone that may have to fix something to get off a trail, but it may spark some ideas for items appropriate in our individual situations.
http://www.ewylie.com/jeep/what_to_carry.htm
-twylie
Congrats. That is awesome. I hope your Jeep works out great for you.
If you are not going to do a lift I would go with 31x10.50s. Tsjay and tonka are running them.
What kind of tires do you need. If you are going to be off-roading a good amount or going through mud, I would get a mud tire. BFG muds or BFG A/T are great tires.
A 2" spacer lift runs about $200 and is a good type of lift.
crazyjpr
Glad to hear everything is going good now. Thanks for sharing the info.
Here is a link to a list of good and bad dealers if you want to share your info.
http://www.extreme-jeepin.com/jeepdealers.htm
mtngal
I guess I didn't realize they did another change on the 01. I was just thinking about the 00 or when ever they did the last change. Haven't really seen the new ones much. The flares kind of look funky is all I remember.
lookin4sahara
I think there is a difference between the full and half doors. The half doors come down a few inches farther and it makes a big difference to me.
I love going to work and then maybe that afternoon at lunch or for the way home from work taking my top down and half doors off because it is so nice out. Or just rolling up the back window, taking out the rear side windows and removing the half doors.
We went to Carolina beach and Fort Fisher. The first picture is from Carolina and the last two are at Fort Fisher.
Could someone please post pictures of the washer/spacer thing? What does that help? Does it eliminate the problem completely? If it catches while hauling butt off road, it would stink royally.
"What kind of tires do you need. If you are going to be off-roading a good amount or going through mud, I would get a mud tire. BFG muds or BFG A/T are great tires."
Probably a lot of road (obviously), but also some off road. I think the 4X4 is more important than the tires off road. Mostly, I want something taller than 225/75 for clearance, and do not really need width for mud or boulders. I am considering a second set of narrow tires for winter snow tires with studs. Opinions?
"A 2" spacer lift runs about $200 and is a good type of lift."
Yeah, but aren't decent "real" lifts like around $500 or so? Can you buy lifts with tuned springs for towing (heavier duty in the rear)?
"I love going to work and then maybe that afternoon at lunch or for the way home from work taking my top down and half doors off because it is so nice out. Or just rolling up the back window, taking out the rear side windows and removing the half doors."
Same here (only 2 work days so far!). How do you remove the half doors? I was wondering if anybody has tried a wingnut for making door removal easier. ?
legroom: My 1992 Honda Civic hatchback has more legroom than the 1997 Wrangler. Does anybody know a way to move the seat back or if there are aftermarket "seat tracks" which allow one to move the seat further back?
-twylie
I would think an American car would have more legroom than a Japanese car!
OK, different question: Do lift kits give more weight carrying capacity?
I haven't ran 31sx10.50s but I don't think you have to make any adjustments to run them.
In some cases you have to put a washer or two behind the steering stops to prevent rubbing against the lower control arms. This would just limit your turning radius slightly.
I don't know anything about snow and ice really. From what I hear A/Ts do better on ice and light snow and M/Ts are better in deep snow.
A spring spacer lift is like a hockey puck that sits on top of the spring. A suspension lift will replace the spring completely along with other suspension components.
A 2" spring spacer lift is fine for that height. If you want to go higher then you are looking at a suspension lift and $500 plus.
I don't think you need special springs for towing. Because you can't tow much weight with a Jeep, the stock springs or any other suspension springs should be fine. Procomp springs are real stiff if you want some stronger ones.
You should be able to open the door and have a hand on each side of the top half and pull up to remove the top half of a half door. Take the nut off the bottom and pull up to remove the entire door. I don't bother putting the nuts back on. You need to remove a fuse behind the glove box to keep the dome light off. I guess this is all the same for the 97.
HTH
Jeep wave
Just wave to the Jeep and if the other Jeep owner waves back at your Jeep, then it is all good. If they don't who cares
your were right about the 240sx, my wife caught it as soon as I hit Enter,,,She really liked that car. She likes anything made by nissan..
Alee..Great pics....
I've noticed that the younger ladies will not return the jeep "wave"..wonder why?..
Keep posting guys!!
Got Jeep?
Snut
Top up of course.
texasjeep: I have only experienced a jeep with full doors. I know, I haven't lived yet.....
sasquatch - I am right at the edge of leg room (I am 6'4") I was going to make a seat bracket that bolts into the stock holes, with holes set back far enough to get me more leg room. As it turns out I didn't need it, but I haven't tried driving in my hunting boots or gear yet either. If you use square stock you will lose some headroom, so choose your material wisely. As for women under 40 waving . I have had them wave at me before I waved at them, mind you at 49, I don't make a habit of waving at girls .. or women for that matter (I have a good one).
lookin4 - The only thing I can offer you is the back seat (on mine anyway) is fully equipped to lash down one of those "child seats". The crash data for the jeep is very good, look at the problems ford has been having lately? I would be perfectly comfortable putting a child in the back of mine. The seat belts in the back seat are every bit as good as the ones in the front (for when they are bigger). Not knowing what the specific fear is I donno what else to add (that wouldn't get both of us in hot water) ;o)
Wow, was there ever some posting to catch up on!!!
I did get a chance to sneak on for a while on Monday while I was at work, but that was it until this evening.
Glad we don't seem to have any ruffled feathers any more. I love the way we all get along in here. I'll bet there ain't another message board anywhere where all the folks get along as well as we do.
Let's just remember that everyone is entitled to an opinion and to express that opinion. What a boring world it would be if we all thought the same way!
I have really been giving some thought to the question of what is a "real" Jeep. I don't have a good answer, but it is a great question, because it makes you THINK!
I know my Thelma is a "real" Jeep. She is to me, anyway. Not a thing about her that I would change.
That's not a good answer, but I am still thinking about it.
It's good to be back with my buddies!
Let's keep posting!
tsjay
Have you hugged your Jeep today?
They love it..they can see better.
We did ride topless once around our neighborhood.
I rode in back with one..while the other rode in front. We had a great time.
I feel everthing is safe. But always use caution in any vehicle when children are riding.
Just common sense to me.
Got Jeep?
Snut
Drew
Did you have 30's and the wheels when you got your Jeeps or did you put them on after? I just want to get as much info as possible to be ready when that joyous moment arrives and I can send you all announcements of the newest Wrangler owner.
As far as the service goes I plan on going to the Jeep dealer that I have been visiting to check out there inventory from time to time. They have been in the Jeep business for as long as I can remember. Believe me I will be armed to the teeth with all of the information that I have gotten from the edmonds website as well as others...and most importantly from my friends in the Jeep Wrangler/Wrangler Owners chat room.
Thanks for the info and advice thus far and keep it coming.
Hug your Jeeps for me ;o)
If you havent' checked it out, I have posted pretty much everything about our Jeep purchase and experience on my site: http://www.ewylie.com/jeep.htm You may find something you can use as you make your final decision. Good luck and keep us posted.
-twylie
Now, Henderson, Ky, is not all that big of a town, so if they had 15 Jeeps, odds are that in a big city, there are going to be plenty of 2001's.
They had two black 60th anniversary models, so, Terry, even though I haven't seen Tazz, I did get a good look at a couple just like him. They were beauties!
When I was in Taylorville, Ill, the dealer there had a silver 60th plus three or four other 2001's.
Just thought I'd let everyone know, in case someone is looking for a new Wrangler.
tsjay
That Jeep concept that started all this looks to me more like a car, which was all the original Jeepster was - didnt even have 4WD. Maybe the original Jeepster is like the guy at the family reunion that no one seems to know who he is. The new Jeepster concept is more carlike, but at least it has some sort of 4WD or all-wheel drive and is supposedly able to go off-road.
For a real stretch, tsjay, what about the Jeep FC150 and 170. These look like nothing else.
As others have mentioned, government regulations will likely be the demise of the fold-down windshield, in-line six, removeable doors, etc. not DC. In fact, I think that DC *maybe* has a clearer idea of what defines a Jeep than at anytime in the past twenty years or so. The latest Wrangler is nothing but improvements, and although the Liberty is admittedly controversial, I'll bet it proves itself to be more durable off-road than the Cherokee. Is structural strength alone is far greater than previous unibody models. As far as allegations of wimpy is concerned, the KJ has the same TJ axles and carriers, A-arms similar to those found on 1-ton trucks, and weighs a whopping 3600 pounds, hundreds more than Escapes and CRVs - hardly wimpy.
Concepts are built and presented to see what "sticks". Lets take the Icon purpose one step farther: What if it is not designed to be the Wrangler replacement, but rather another model? Would that be a good Jeep to park next to your TJ for your teenager to drive? It would be safer and sportier than a TJ, and probably get better mileage for those teenagers on small budgets.
Just some thoughts while we discuss tires, rims, and axles. Speaking on axles, I've heard that the trak-lok has to be rebuilt at around 50k miles, is that true? Seems kinda pricey maintenance.
By the way, my Sahara is on the train and should be here in the next few days. Can't wait.
Your post about DC knowing what they have in the Wrangler and their intention not to mess it up made me feel much better.
Even if I didn't think I would ever buy another new Wrangler, I would sure like to see them continue to be made without any major changes. I would like to know that I could put Thelma Jane out to pasture when the time comes and get a brand new one. I can't see trading her in, if I ever did get another one: I would have to keep her.
tsjay
I'll keep you posted!
Laura
No Tsjay, I haven't come up with a name yet. Any suggestions for a white Sahara. What's a good name for a white vehicle??
Until I jeep again.
CJ owners would argue this, but this is still a "family" dispute. The jeep (and maybe the land rover) are the "benchmark" that everything else is compared too. Lose this and you lose the jeep.
The jeep, IMHO, represents freedom of choice. If you want all the suburban comforts AC, CD, leather, carpets, automatic transmission, ABS and so on you can have them. Even more important, if you don't want them you don't have to have them. I like having the choice of a hard top or a soft top, for example.
When I go hunting, the last thing I want is to spend all day in the woods and then (after getting covered with mud) climb into a vehicle that looks like my living room, and is just as hard to clean. The jeep (so far) fills that bill. I do not begrudge anyone for wanting the "comforts of home" in their jeep, but don't throw the baby out with the bath water.
If you order one to your own specifications, can you still get the price you want or do you need to go through a service to deal for you?
Oh yeah I almost forgot. I looked at the photo gallery again and saw some great pictures. Why did some of the postings have "sorry" messages instead of a photo?
I don't have a digital camera, so I'll have to scan a photo and put it on or get a good digital camera that isn't too expensive. Give some detailed instructions to put photos in the gallery.
I may be back on later, but it's 1:30pm here and I'm starving. Have a great and safe 4th!
Hug your Jeeps for me today! ;o)
dwrangler
I think that we are going to have to agree to disagree. As wheelshigh and others have said, the definition of a real Jeep is going to be different for different people.
Try to define a real Jeep by the build specifications for the different models, and someone will have a reasonable rebuttal.
I know what is imporatant to me, but that doesn't mean that I should expect everyone to agree with me.
Way up at the top of the list in my book is the looks of a Jeep. Like nkelly has said, it has to look like a Jeep to be a real Jeep to me. If the only thing that changed was the looks and everything else was exactly the same as now, I wouldn't want one!
I know virtually nothing about the very earliest Jeeps, but I do know that the looks have remained almost completely unchanged from the CJ's until now, and that covers all the years since the end of WWII. I think that is GREAT!
If Jeeps had undergone substantial changes in appearance every few years, like almost any other vehicle has, then looks would not be such an important factor in my definition of a "real" Jeep.
I am very pleased with the evolution of the Jeeps to this point, as I stated in an earlier post near the beginning of this discussion. I would NOT trade my Thelma Jane for ANY of her predecessors. She's a "real" Jeep to me in every sense of the word! SHE IS PERFECT!
Ok, maybe not perfect, but close enough. I guess I wouldn't mind a little quieter throw out bearing and maybe a little smoother shifting. A modular hard top would be nice too.
See, I'm not totally against change, but I just don't want anyone messing with the basics!
tsjay
You ain't the Lone Ranger. I thought I was gonna die for about six months wanting a Jeep so bad and not knowing how in the world I was going to get one. I stayed in here and kept up with all the posts and did quite a bit of posting myself.
Old Saharanut hung in here with us, not thinking he was ever gonna get his Jeep. His waiting period was about as long as mine, or maybe even a little longer.
Dwrangler is going through it now.
So, just stay here and be part of us! We will all help you celebrate when you do get that Jeep, and you WILL, if you hang on to that dream!
tsjay
This wrangler is the first new vehicle I have ever had. I ususaly just buy old one I like fixed it up and run the hell out of it (haven't seen much in the way of new vehicles I really wanted to own). There is always an other way.
When you order from the factory, the dealer gets invoiced when the Jeep gets shipped, and when you pick up your Jeep, the dealer gets his money from your bank. I don't know how long the factory gives the dealer to pay for the Jeep once it has been invoiced, but I'm guessing the dealer would have the money from your bank in time for him to pay the factory for that same Jeep.
This saves the dealer from having some of his money tied up in that Jeep just sitting there on his lot waiting for someone to come along and buy it.
I would love to know how much money and how much interest is reprensented by a dealer's inventory of vehicles. I'm sure it must be one of the greatest expenses that a dealer has to pay.
tsjay
Hope you got moved and settled in by now. I'm wondering if you got hooked back up to the 'Net since your move? I'll bet you're getting online somewhere and keeping up on the posting.
Just thought I'd say hi and tell you to hurry up and get started posting again!
tsjay
Sasquatch....glad to hear you finally bought one!
JEEP101?? I received an invitation to a Jeep101 about 2 hours from here. It is about a month away and I was wondering if anyone has participated in one of these yet? Is it worth the time?
Been a busy week for me...I manage a BBQ restaurant..WOW!! busy day today....But now I am on VACATION!!
Lots of great comments on what makes a jeep a JEEP>> I agree with its the "Owner" we are a particular bunch. Trufully i really dont believe DC will do a drastic change to our wranglers..
The Jeep is an American icon.
Glad to see you back Tom..we missed ya dude..
will not make it to Gills tonight..taking my kids to see a fireworks show (in TAZZ of course)
JEEPBOY...hey man NEVER give up..I know what you are going through..the waiting..the researching..
I was there myself..We all all behind you ..its worth the wait!
Keep posting all!!
GOT JEEP?
Snut..BamaTazz
Enjoy the fireworks if you can :-)
Drew
Vans, SUVs, and Aftermarket & Accesories message boards
Did you guys have to whip the limeys too, or did they just let you go peacefully?
tsjay
http://www.starway.net.au/~ijcossor/jeepmil.html
I like the part where ..
"In 1942 Ford built a limited number of amphibious Jeeps, known as the Seep. This little vehicle was basically an MB with a boat tub on the bottom(with cutouts for the wheels) and a PTO propeller.Seeps were not the most seaworthy things in the world, but one highly modified Seep, called "Half-Safe," did manage cross the Atlantic in 1950 and then continued on to circumnavigate the globe."
http://www.jeepin.com/history1.html
http://www.off-road.com/~early/history.html
OK, I finally got around to pulling off our half doors. I didn't have any problems getting them off and I'm estimating they weigh somewhere between 15-20 lbs each. While the ease of getting in and out in fantastic, and the feeling of being more "open" to the earth is nice, the feeling with the half doors on is about 70% of what it feels like to ride around without any doors. I can see where doorless would be great at the beach or in the woods. I need to check GA law to find out if one mirror is enough. Once again, a testament to the versatility of Jeeps.
I guess that has to go on "my" list of what a "real" Jeep is.
- Ability to go anywhere the owner wants to take it (at least anywhere any other 4wd truck/car/SUV can go). This includes mud, rocks, snow, sand, 2' of water...
- durable (able to take reasonable off road punishment without breakage)
- customizable/configurable through factory options and aftermarket to make the vehicle personal and unique.
- has the rugged Jeep "look". Kind of like pornography to the govt... you know it when you see it.
- ability to remove the top
- fun to drive (probably a function of short wheel base, small turning radius, high visibility for us)
- 7 slots in the grille
Other than that, I'm good. I may not like the future styling directions, but fundamentally, those are my criteria. I'm not a complete purist. I like the I6 but understand the need to be able to use a 4 speed auto, so the 3.7 V6 will see its time soon. I think solid axles offer better durabilty, clearance, and flex, but if the engineers can figure out a way to get IFS/IRS to achieve my requirements of "go anywhere I want to", and "durable", I'm good.
-twylie
-twylie
I guess we don't know much about your history, but we do know that you guys are cool and that you are our buddies. We also know that you have a huge, beautiful country.
Join us in the wrangler chat tonight at 8:00 PM CDST.
So glad you are posting again!
tsjay
Top up of course."
Honest opinion? I think you should keep the top down, just use sunscreen. I see a Dad and his boy tooling up and down my road all the time. Two bald heads in a red Wrangler having the time of their lives! Just do it!
I just got a good deal (arguably) on a 1997 Wrangler TJ Sport.
If you can't do it new, go used. Get an older model (CJ?) and work with it from there.
Hang in there.
-twylie
