Seth
http://www.allpar.com/cars/dodge/avenger.html
along with spy photos and such.
FWIW, no quality predictions should be made by anyone on this model since it is completely, totally new except for the V6 engine and perhaps the automatic. There will even be a six-speed automatic which is completely new. It's not made by Mitsu and it's not designed by Mitsu - it's a cross breed. Heaven only knows what that will mean especially with the Mercedes bigots in charge.
thanks,
dave
Caleb E.
I dont really know what this does to the engine, but that sounds to me like what happened.
i have a 95 avenger 2.0L 4 cyl and i recently replaced a headlight bulb. the same day, my left turn signal came on as soon as i turned the key on and the lever does nothing. im guessing theres a short somewherer but i dont know.
has anyone else had this problem?
Thank You!
You might have noticed that I've moved some of the recent posts about this over there.
I keep reading all these horror stories about 1995-2000 Avengers, about transmission failure, brakes that wear really fast, and extremely high repair cost. But then, others say that the reason they have these problems is because they never do preventative maintenance (ie regular oil changes, replacing water pump, timing belt, and tune-ups). Overall, it seems like the Avenger has lower than average reliability, but then again, the majority of people who are going to be posting reviews/rants online are going to be the ones who have had problems with the car.
Can someone reassure me about my decision to potentially buy this car? :confuse:
so only as a suggestion , be carefull of your decision.you might face less a risk in another make and model
good luck
gino
I know how to do it, if you are gonna do it you can email me. Good luck!
There is a bank of relays on the firewall, 3 to be exact. One of them is the master shut off curcuit and you will get no spark when the car will not start. $30 at the wrecking yard will get all three and you are done.
has anyone run across this with their Avenger if so what did it take to fix the problem?thanks in advance for anyone who can help me
RTH/
My girlfriend asked me to find out where the Fuel Pump is located. I beleive the filter is located under the car in front of the gas tank, but not sure about the pump. I'm sure if I go see it and dig into it I'll find it but until then, I thought I'd check into it this way. Anybody help
