How do I convert R-12 AC system refrigerent to R134a?
1. When you release the R12, the hole in the ozone will get bigger. More people will get skin cancer... Any R12 needs to be captured and the work can only be done by a licensed technician.
2. R12 and R134a are not compatible. R134a requires a much higher pressure to work. Putting R134a in your A/C will likely damage your compressor.
Yes, the system is required to be recovered by a certified, not licensed technician.
Yes, R-12 and R-134a are not compatible and yes they run at higher pressures.
But no, it will not harm the compressor, as it is the same compressor used, but the condensor and some other parts will need to be changed out and the entire system thoroughly flushed and evacuated. The cheapy conversion kits usually end in catastrophe anda $1,000+ bill.
Check my Profile for the AC experts.
if it works, don't mess with it.
if it doesn't, have it cut to R134a as part of the repair... a practical shop may refuse the work if you don't have the conversion done, even if equipped for full service of R12.
Since you mentioned purging the remaining R12, I guess there could be no leak. If so, it may be a good idea to recharge when R12 is still available. On my car, I have it leak tested and they found nothing. They put in 1 pound and it now works fine. Since the 626/MX6 only takes slightly more than 1.5 pounds, recharging shouldn't cost a lot. I paid $70 per pound.
If you have a leaky system, it must be repaired in any case. Conversion is NOT a solution because the smaller molecule size and higher pressure will only exacerbate whatever leaks there may be. Once repaired and recharged, the R-12 system should not need attention for many years. R-134a is a significantly less effective working fluid than R-12 and it has a higher pressure vs temp characteristic which requires that a converted system be only partially refilled to maintain pressure within system capability. The result is diminished cooling capacity.
It still contains small amounts of CFC's, but it is approved for the conversions.
I can see the point. I would not add R606, propane, or whatever is NOT R12 into an R12 system without a full purge and preparation cycle, and then only as a full charge.
if you're going to do that, shoot, make the move to R134a and be done with it.
lots of ways to put tape over a problem, often only one or two ways to fix it.
Believe me, it will work. I figured for $25 bucks even if it worked for a year I would be happy and it has been over a year. If alittle leaks out, just top it off. I even had some left over. Go do it and good luck.
If the R-12 system is still working without leaks, it has been cheaper to recharge every few years.
