Pontiac GTO
I think I'm going to be sick.
if you are actually the 1 kid out of a million who is responsible enough for a car like this, ok, more power & torque to you - you go, it's your birthday. woo hoo!
but i hope your post is a joke and that no actual parent is so irresponsible as you jest!. if you were responsible enough to have a GTO you'd also know to trade it for the slowest volvo available to increase chances of making it to age 21 ! and your dad might learn a thing or two from you if you were to do that! best regards & wishes, and forget about the speakers, pay attention to the road, you need to concentrate. look at me when i'm talkin to ya, son!
just kidding, having rich parents is a blast im sure. have fun driving richie rich.
anyone remember that cartoon?
I'm presently in Valencia, CA and thus a bit behind in replying to posts, sorry...
--Robert
--Robert
Search back a few posts for the proper alignment specs. Have your dealer check and then align per those specs (got them from a dealer who got them from TAC - tell them to call TAC and ask for the revised GTO alignment specs to help prevent strut rub, should they not believe you).
Hope this helps,
--Robert
--Robert
DMS (Dublin Motor Sports, in Dublin, CA) was breaking up the 2005 SAP packages and selling front, rear, and/or side fascias separately. I know they come in three colors (black, red, ???) as well as unpainted - not sure what color you are looking for.
--Robert
You should also replace the rear panel speakers. I used Kenwood Excelons for both, 6 1/2"ers, and they work and sound great. The stockers were just such absolute junk.
Getting at the rear panel speakers involves taking out your entire rear seat, as well as trim going up to the sill plates. It's about 5 more minutes of work to get at the subwoofers on the rear deck - by all means, take this time, and replace those, too (need a free-air 6 1/2" design - I got a pair of Goldwoods from parts-express.com for something ridiculous like $27 shipped - they sound AMAZING compared to the crap that Holden installed).
Hope this helps,
--Robert
Next time it happens, lift off the brake lightly to see if the car surges forward. If it does, then your problem probably lies in one of those two areas. What's your idle speed when it's in Park? I'm sort of leaning toward the torque converter.
Haven't settled on a color yet, most likely black.
I've been watching this forum for a while, and i've learned a lot about the GTO that the road tests don't tell you. You've always been very informative and helpful. Thanks again.
Joe
BTW, the car is just short of 5,000 miles.....
That's a pretty low idle, but I don't know if that's normal for an LSx engine or not. Most cars idle in Park between 750 and 850 RPM. Personally, I would think your idle speed is too low and, from the sounds you describe, it seems like the engine is nearing stall speed when you're on the brake.
Next test; apply the brake while in gear and slowly press the gas. How high does your RPM go before the car feels like its pushing against the brakes?
I would say ask the folks in the GTO Problems & Solutions board what their idle speeds are. Maybe your ECU needs to be programmed to bump the idle speed up by a couple hundred RPM.
What has your service department said?
white6, keep taking it back and keep pushing them on it. There is so little dealer support for these cars it is ridiculous.
of any nature.
Remember the old opera singer wine glass thing - you let something vibrate near enough to its natural frequency and it could shake it self to pieces. A little above or below, and its enough to be annoying. But once you are significantly far from the natural frequency everyting should be "smooth as silk".
My 04 m6 idles around 600 once warmed up.
Some other things to note when you go back to the dealer - Does the A/C being on have any effect? is the engine at normal operating temp? Is it when you are in D or N? If you let the car roll while in D and idling does it still make a vibration?
Thanks for the info. I'll check it out.
Simply because new engines sometimes do funny things, in the NVH, power, and mileage department.
And such jealousy from the peanut gallery! Wish my dad had bought me a GTO-equivalent for my first car - I only got a 1.0 litre Datsun, but hey....
Got a 2005 cyclone gray 6 speed in April with 80 miles on it, had the car over 100mph on the test drive, pretty much followed the break in to a tee (Minus the test drive of course). It has been my daily driver and I have over 7,500 miles on it and had no problems, until...
I've had the oil changed twice but the oil life meter never got reset properly and it went off a couple of hundred miles ago. I tried to follow the instructions in the manual to reset the oil meter: with engine off, turn key to ON, slowly push the throttle to the floor twice within five seconds, turn key to lock and you are reset. How hard is that? plenty, I tried many times but could not reset the meter....
this was literally 4 days after my last oil change and saw the mechanic follow the instructions in the book to reset the meter, unfortunately there is no indication that it has been reset other than it is not on any more but if it's not on to begin with...
Anyway, I was out of town and was trying to wait until I got to my local dealer but kept trying to reset the meter. Apparently, I confused the computer into "safety mode, reduced performance." Unfortunately, I was on my way back to a meeting so couldn't do anything about until later, and let me tell you, you do NOT want your car to go into "reduced performance" mode, it should be called "no performance" mode
After my meeting, I was on my way to the closest Pontiac dealer to fix my car. When I re started it, it was no longer in "safety mode" (thank God) but the "check engine" light was on and the oil life meter still hadn't been reset
The service manager at the dealership heard my story and explained to me as we walked to my GTO that in every other GM car, you have to press the gas pedal 3 times in 10 seconds. He didn't even do it slowly, and boop, reset. I showed him the manual and he said he was going to notify GM about the misprint, whatever....my car was reset
The "check engine" light was still on and I was told that the computer will "hang on" to the fault code for approx. 10 engine cycles (warm up- cool down) even if the condition that caused the fault is no longer there. The next morning, the check engine light did not come on and it has been fine ever since.
So human error can be blamed for that problem although confirmation of a successful reset would be wonderful.
As far as the throttle response being sluggish? You bet I've noticed! My car seems to be inconsistent from the line. There has been a time or two when I've taken off and haven't hardly been able to keep my head off the head rest while other times it's like "come on baby, you can go" When the car is cold, it feels most sluggish. It seems the computer program needs some tweaking.
It's all starting to make sense. One thing I have noticed and even told my friends about is that turning off traction control is like unleashing the beast. It felt as though a brake had been released. My assumption now is that the computer reads the acceleration table differently as it behaves as sputterguy described in his test drive, "would chirp the tires when I tapped the throttle."
gas mileage for me has been 14.1mpg at the lowest and 25.5mpg at the highest. A 1500 mile trip that took me through the mountains of WV had an average of 21.9mpg (and believe me, I at least maintained the 70mph speed limit, even up the steepest 5-7% grades)
By the way gxpgtodanman, how do you like your GXP my wife loves hers. Turn off the traction control and that car will smoke the tires almost as much as my GTO.
Steve...
It's kind of funny burning the front tires. You better have the windows up otherwise the smoke will come in. I have already stunned quite a few Mustang driver with GXP. I beat one 2 lights in a row and the guy asked what I had done. Nothing, stock from the factory. Don't forget, GXP insurance is lower then Mustang too.
I assume that is the prescribed oil to be used in this car and also assume
that it came with this oil. I know that Mobil 1 is more costly than regular oil
and my question is: How often and at what milage should one change the oil under normal driving conditions?
I have been told that this type oil is superior and used in most high performance cars such as the Corvette and is the choice of NASCAR.
I have 5700 miles on my '04 since April 1 (and 3100 on since my last oil change). I kind of wonder at what point I should change as well. I guess I'll be driving the car another 2 1/2 months, so I will probably change it myself sometime soon, and then again before putting it into storage. I bought the 5 gallon jug for around $20 from Wal-Mart, then bought an additional quart for $5 or so. For filters, I would use either the AC Delco or a Wix-based one (i.e. NAPA - a GTO buddy of mine works there so I get his discount :-). I've planned on doing my own changes, but haven't yet due to time issues (I have a huge project at work wrapping up in two weeks... can't wait to have some free time again, other than the 10-minute breaks I take to visit Edmunds :-)
When it comes to motor oils, everyone's got an opinion of what is the best, and how long before changes. Getting a used oil analysis may not be a bad idea. A site I've seen recommended forever, but haven't spent a lot of time exploring, is http://www.bobistheoilguy.com/ - might want to check that out.
Hope this helps,
--Robert
Just to clarify: M1 makes a 0W-40, the "truck-grade" oil I was referring to was M1 Truck & SUV 5W-40 and the 30 weight I recommended was Castrol Syntec Made in Germany 0W-30.
and this z28 vibe did go away with the car in neutral, so i surmised it did involve the transmission somehow. i don't think it was a resonant frequency / standing wave , but who knows. i just got used to it. also the M6 Z28s had a problem with driveshaft resonant frequency that resulted in a standing wave / vibe at about 70 mph with periodicity of about 1 second. the fix for that was the 1LE aluminum driveshaft, tradeoff was that driveshaft transmitted much more rear gear noise into the cabin.
well ,that's a bunch of info that maybe has no relevance to your car.
my current M6 GTO does not exactly give a silky smooth honda-civic-like idle. again the cam profile is not set for smooth idle. but from the sounds of your posts, your car is doing something funky. any way you & the service manager can compare your car with another a4 gto from the same year ? i recommend taking it slow on the lemon law deal - from what i know of lemon law in some states, you might not have much of a claim - might be tough to prove a rough/loping idle is a driveability problem - some lemon laws require it be all about a 'driveability problem'. i'm no expert on that though, just tellin ya what i've heard & read. well, i hope some of this info could be helpful to you - best wishes.
in other news, more smiles & shouts from other drivers. this time one from a mustang guy who didn't sound real positive! then he accelerated wildly from the traffic signal while i entered the store. lucky for him no cops around. i consider this a downside of the GTO - on multiple occasions other drivers see my car and then drive dangerously - showing off. i do not appreciate that !
I was thinking about maybe taking some - figured it'd be a great way to experience aspects of my GTO that I don't see under normal driving conditions, get a chance to drive on a race course, and to improve my driving skills overall.
Anyone out there done this?
What are others thoughts, advice, etc. on this?
Input appreciated.
Cathy
now, how about the GTO plastic thing on the center/top of the dash. what is that thing for? maybe a nav-system goes there on that half of the planet where the water drains counterclockwise? here in the US all that plastic thing does is make for an obnoxious reflection in the windshield. if there were some lower-contrast way to cover it, i'd think about doing that. at first i wondered if there is a storage bin under there and tried to gently pry it up.
Mark
Its the August 11 GMtv
http://gmtv.feedroom.com/iframeset.jsp?ord=605697
Also www.pontiac.com/testdrive or http://speedtv.com/pontiac/
Have they checked the transmission mounts?
Has the dealer tried dropping the engine and tranny and re-aligning them?
I have the GTO Brand Quality Manager's contact info... drop me an email (address in my profile) and I'll pass it on to you. This would be your best option for getting this resolved, as he will put a bunch of resources on the case... I would not tell him up front that you've filed with the BBB, however.
You know, I think Holden builds a quality car, I just think it's your typical Pontiac/GM service department that doesn't know the car, and won't take the time to learn about it, even though components like the LS1/LS2 and the auto and manual trannies, were used on the F-bodies as well...
--Robert
Thanks for the input. I'll be sure to continue using Mobil 1 in the car.
I'd like to let you boys know that in my neck of the woods (Northern Ohio)
that the GTO really turns heads. Have had nothing but compliments so far.
Even among Mustang GT nuts. The Mopar boys are impressed by the GTO but are cooing about how the new Hemi Dodge Charger will take care of the GTO in the 1/4 mile...Don't know much about that one yet.
The mopar boys are wrong. The GTO will beat the Hemi Dodge Charger in the 1/4 mile, 0-60, top end and skidpad grip. Stock vs Stock. I believe the Hemi charger only has a .78 skidpad.
Car and driver had the GTO at 4.8 seconds 0-60 and 13.3 1/4mile
Car and driver had Charger at 5.6 seconds 0-60 and 14.2 1/4 mile
Now the SRT8 edition of the Charger if they have one, well then it should be about the same or slight edge to mopar.
