I have used my truck mainly in Minnesota. I've been through 8 winters, travled to Big Sky montana a couple times in the middle of winter, started the thing in -35F temperature, been through blizzards, some back-country roads of Idaho and Texas tropical storms. I currently have Michelin LTX M/S tires on there and have had no problems. They ride great, quiet, and feel rock solid on the road. No flats either, the Dunlop tires the truck came with sucked and had numerous flats(pop'd sidewalls) and lost control all the time in wet weather. I feel traction control is more of a mind safety thing. How cautious you are driving is your best bet. Don't count on 'traction control' to save you if you are spinning out at 70mph. :surprise: If you hit black ice you're screwed no matter what. Best advice is to have a good set of tires(Michelin LTX MS) and use the 4high accordingly. For the times I am on wet ground and its in spring or fall with potential of ice formation I will run on 4High if I feel the truck may slip and disengage it when I make slow sharp turns. Not having traction control for me hasn't been a problem. I have driven both versions and various other 4runner setups since I used to be a New/Used Sales rep for Fred Haas Toyota World in Texas. Traction control should't be a determining point in your purchase. Engine, transmission, 2 vs 4x4, milage, truck history, price and cosmetics would be more of a concern I should think
I do recommend getting a 1999 or newer 4Runner. There were some suppension changes after the 1998 model to solve the 'sagging' butt end of the truck and made it a lot smoother of a ride.
Good luck in 4runner hunting and lemmie know how it goes!
BTW, VSC-equipped 4Runners (on other Toyotas too) have sensors that measure yaw rates (sideways movement) at each tire and brakes the wheel(s) that are in danger of sliding, helping prevent the driver from losing control.
I'd definitely pick a '99 or later model. The dash was restyled, fenders redesigned, and some suspension tweaks made.
The '99 & '00 SR5 models are only part time 4WD, which means you can only use 4WD off-road; these models don't have TRAC or VSC. Some of these SR5 models came with a manual tranny, although its quite rare.
The '99-'00 Limited models had a first for the 4R model, a multimode 4WD system. In normal driving, select 2wd, in wet or snow, there is a selectable "full-time" 4WD mode (with a center differential) where you can drive on pavement. Fiunally, there are the traditional 4WD part-time settings for high and low-gear ranges (center diff locked), only for off-road use. Some of these models came with a rear diferential locker, which is only for serious off-road use IMO. The Limited models also are more luxurious with a leather int, auto climate ctrl, rear heater, and painted fenders.
The '01 & '02 4WD models (SR5 & Limited) all came standard with the same mutlimode transfer case, 2WD, "full-time" 4WD mode, and part-time 4WD for high and low ranges. The added bonus of VSC and TRAC makes the '01 & '02 models a bit more safe IMO. Toyota eliminated the 5-speed tranny option and rear locker for these years, much to the chagrin of the hard-core off-road set, although the off-road version of TRAC, ATRAC, actually is a nice traction goodie for off-road use as well.
The 2001 4Runner was one of the first moderately priced SUVs to make stability control standard. I would not buy a SUV without VSC unless safety is not a concern.
I was surprised how nice the cloth is on the sport seats. Very durable and breathable. It uses two different types of cloth material. It's different than the cloth in all the internet pictures I saw while looking at various models. Maybe it was a new material for 2002 or maybe it comes on the sport? I don't know, but I do like it (even though I originally had wanted leather). Also, I found that insurance is very affordable on this vehicle, even with generous coverage -- cheapest I've ever been able to get on any vehicle I've ever owned. That was a pleasant surprise. Anyhow, time to enjoy her now. Thanks again to all on this forum for the great info provided.
In time...there is another car been sold. It is 2.001 model, has a 3.4 liters engine and automatic transmition. Same mileage. In your opinion s it worthy to spend U$ 12k and trade in my 99?
Thanks a lot. In time... I`m writing from Brazil, Sao Paulo.
SUVs and Smart Shopper
Any advice, again, would be greatly appreciated.
Please about the engine "running cold" do you have any clue about that? Nice to talk to you!
It's possible that your engine is running cold because the thermostat is defective or its temperature rating is too high. I would check that out first.
Can I pull this out and install into a 2002 4Runner with the lesser powered 3 in 1 system (part# AD6803)?
Is the amp built in to this radio or is it separate and are the speakers the same type on both vehicles?
v-6 sr5 4x4
Good luck. Ben
Id be willing to swap the whole trans if it'll fit. Im just having trouble finding a trans from a 4cly and I dont wana buy one from a V6 and have it not work...
Any help?
Thanks...
Rick
Greg
I had the same problem with my truck. It's what happens when someone takes it to a place that isn't Toyota certified cause somketimes they use tools that work on other cars/trucks but not on Toyota's; resulting in stripped nuts. A good toyota dealership can air impact the old one out and put a new one in. You may have to order the part as i had to, it was a few bucks at the time and then add labor. But it's worth it to not worry about losing your transfer case. Hope this helps!
Greg
Yesterday, after a 35 mile drive, I parked my 2000 4runner facing down on a steep hill and turned the engine off. About 15 minutes later I restarted the engine and backed up the hill (about 30 feet) and reparked on level ground.
I noticed a significant spill of fresh transmission oil spill where the car had just been, and crawled under the car to see what was going on (the car was now turned off again, and parked on a flat surface).
There was transmission oil literally pouring down both sides of the transmission - not leaking from the cooler lines or from seals at the end of the transmission, but apparently from the top of the transmission (I couldn't see back far enough under the firewall to see exactly where it was coming from - but it was pouring down BOTH sides, apparently from the top of the trans - I'm guessing maybe a quart or so.
When the car cooled off, I started it again, and drove it to my home 1/4 mile away with no problems and no leaks. This morning I drove it a half mile, and again performance was normal and there were no leaks.
Anyone know what's going on? Thanks!
Also, about 6 or 7 years ago the CD decided not to work (it looks like a separate unit below the tape player). It takes in the disk, but doesn't play it, and sometimes doesn't spit it out. Is there a fuse I should be looking for to replace someplace?
Let me know.
2003 4Runner and 2005 Tacoma or later 16x7 wheels backspace at 135 mm is different and portrude inwards about half inch giving it a less robust stance, and that is not what the 4Runner is all about.
The correct factory original 16" x 7" oem styled steel wheel for 1996-2002 Toyota 4runner is part# 42601 35740 at your local Toyota dealer, suggested dealer price is suposetly over $200 bucks but if you tell them that you can get the same wheel at an independent Toyota parts store at $130 ea. they'll probably reach an agreement with you. Said rims are exactly the same stock design as the 15 inchers and are rare.
These “nice looking“ rims will lift the vehicle a little with out going to suspension mods and powder coated in black will give you a nice stealth factory look, i shod them with “expedition size” Dunlop 235/75 16 tires. Getting better gas mileage on the highway too.
You could also opt for the standard steel wheel instead of the styled steel wheel.
Cheers! JU alias WorldTour
JU alias WorldTour
Any ideas on the CD player problem?
My CD Player looks like a separate unit from the tape player above it, although it occupies the same space. It takes in a CD, spins around a little, then nothing happens. Sometimes it ejects the CD, other times it won't. Is there a fuse I could be looking for to replace, or should I just replace the whole system?
Also, I broke the the drink holder that slides out of the front console above the radio, and the kids broke the drink holder that flips down from the back of the center console. Are these easy replacements should I find a donor 4Runner, or should I just get them from the dealership parts department?
Any help is appreciated. Thanks.
As for the cup holders, check out a local junk yard. Call and see if they have your part, theyll probably even pull it out and ship it to you, but if not, pick it up. Unless that drive would cost more than the part at a local dealer. Or try online www.car-parts.com or www.automotix.com may work.
3 probs: The clock no work so I pulled the trim to find NO CONNECTOR anywhere, the clock was not connected and none to be found anywhere!
The trans kicks into D fairly hard, from say R, and it sure rides "bouncy"
my 48 year old wife no likey ride (we went from a minivan ouch). also wierd. The 4wd selector and trans gear selector "move" as I hit bumps.............
Please advise!!!!!!!!!
Thanks guys
Rich
U. S. Navy Chief Petty Officer, Retired
22 years service to my country
Wow! That works out to about 26,000 miles per year which is twice the average mileage of personal vehicles. You must have a long commute.
...Sheesh, Navy guys...
Keep on pressing yours on down the road.
