Subaru Forester Engine problems
I would like to know if anyone has experienced the endless problems that I am currently facing with my 2002 Forester L.
My engine light went on about a month ago and finally when the ride was 'bumpy', feeling like it was going to stall, I took it in to Subaru to have it checked out.
They found numerous problems.. and at only 120000km, they told me I needed a new head gasket, a new clutch, and I can't remember what else, for a grand total of $2700. Not quite what I was expecting... but no choice, had it done.
Exactly one week later, on came the engine light. I took it back in, this time I was told that I might need an oxygen sensor. They reset it, and the next day on came the light. This time the bill was $340, and the service manager also told me that they found another problem with the 'clutch cover....' part alone cost $200, but they didn't charge me... thanks.
I kid you not, one week to the day, on came the blasted engine light. This time it was a corroded wire under the gas tank... the bill, $180.
It is now two days later and my car would not start today. I had someone push it and we got it to start.
Needless to say, I'm not impressed. Is this just a nasty stroke of bad luck or am I being snowed, or is there a history of these problems.
I'd appreciate any feedback, including how to avoid losing my cool at the dealership tomorrow.
I kid you not, one week to the day, the light came on
Smoky66
Call 800-SUBARU3 whenever an issue like that creeps up that might be related to a problem you had in the past. See if they'll cover it or at least help you reduce the cost in some way.
You might be past the 3/36 warranty, but if not, consider a Subaru Gold warranty if you will keep it longer.
Having said that, I don't think your experience is typical. I have 80+k miles on my '98 and have one visited the dealer once, for a recall years ago.
-juice
-juice
Kyle
-juice
For the latter, Subaru issued a TSB and sent a letter to owners of 99-02 models asking them to take their cars into their dealer. The dealer added a coolant conditioner and put a sticker on the radiator notifying any future service tech that the coolant had this conditioner in it, so it would not be drained and filled without the stuff.
Owners that did that got a 8/100 warranty against HG failure. So Subaru address the issue pretty well. From 02 on they used revised head gasket materials.
The only other thing we truly saw a pattern of failures with was the rear wheel bearings on 02 and earlier Foresters and 01 and earlier Imprezas. Subaru switched to a more robust design with the next generation of each car, and again we have not observed failures (at least regularly) since that time.
If you read Consumer Reports, you will notice sudden improvements in the Drivetrain and Engine scores right around 02-03, so their data tends to agree with what I've observed reported here on Edmunds.
For the past few years Engine ratings are all "Much Better than Average", which ought to show that piston slap is not common, though it does exist in some circumstances.
-juice
My questions:
1) anyone else experience this?
2) can someone describe the fuel vapor capture/use system in detail for me (e.g., lines from the tank fill tube to the engine, etc.)?
3) where is the charcoal canister for capturing fuel vapors located on a 2001 Forester?
4) is the canister easy to replace?
5) canister replacement cost?
6) any other thoughts, ideas, suggestions?
I'm new to the forum and all help is appreciated.
SalemForester
Is that Salem Oregon? (I know there must be 50 Salem's out there). Just wondering if you can pump your own gas or not - no self serve in Oregon.
Do you ever fill-up with the engine running? Someone just pointed out this morning in another discussion that doing so can mess up the evap system (but usually that would also turn the check engine light on).
Sounds like this is going to be one of those animal, vegetable or mineral problems to solve. :surprise:
Thanks for the welcome.
Beautiful Blue Ridge Mountains of Virginia.
We self-serve here. Never pumped with engine running.
The reason I brought up charcoal canister is that I've heard that overfilling can saturate the canister with vapors. I'm not sure that's the problem and I don't want to prejudice any other possible explanations.
Can you direct me to post about fill-up with engine running?
Here's the fill up post:
keuper20, "Ford Freestyle Owners: Problems & Solutions" #581, 8 Apr 2006 7:40 am
http://www.drive.subaru.com/Sum03_FuelSystem.htm
If the link doesn't work I could email it to you ?
Symptoms - would happen once a month or so, no apparent pattern as to when it would happen. After a year it seemed to occur more frequently on consecutive days. When I checked into it, the dealer found a service bulletin or recall that fixed the issue. Gas would spray out at high pressure, vapors would enter the cabin via the ventilation system. Replacing a part (fitting? tubing?) within the fuel injection system fixed it.
For those who want the short answer to my smelling gasoline in the passenger compartment, here it is. (The "whole story" follows.)
The answer: disconnected crankcase blowback hose.
Here's how I understand what the mechanic said. The crankcase blowback hoses (there are two; one on the passenger side, one on the driver side in the engine compartment) recycle back into the engine gas vapors that accumulate in the oil crankcase. This saves gas and lessens emissions. If the hose(s) get disconnected then the gas vapors "blowing back" from the crankcase are released into the engine compartment where they can be sucked up by the interior ventilation system (heater) and pumped inside the passenger compartment, hence, the strong gas odor inside.
The mechanic said that whenever he gets a gas odor complaint the first thing he checks is the crankcase blowback hoses. They can be knocked loose by anyone fiddling around the engine block, especially if removing spark plugs. Anyway, the Subaru mechanic quickly and easily reattached the disconnected hose and checked the other one as well. It took 3 minutes. Graciously, no charge at all.
So, that's the short answer for anyone who smells gasoline in the passenger compartment.
Does this make sense to any technically inclined readers?
Now, a little more elaboration for those who like the "story" part.
How did I even stumble on this? Well, I was peering under the hood trying to make sense of the gas vapor control system per the diagram that lakepop referred me to. There is also a diagram pasted by Subaru on the inside of the hood which I hadn't noticed before. My primary mission was to try and locate the charcoal canister for reasons I mentioned in the previous posts.
Well, anyone whose tried tracking the maze of hoses and metal pipes on the engine knows how daunting it can be to follow everything. Making it even more challenging is the fact that many hoses and pipes disappear out of view passing here and there around the engine. So, I'm bending over and twisting this way and that to follow everything. The fact that many of the tubes drop down in the shadows and into darkness makes it even more difficult. (Obvious hint: the mechanic pulled out a pen flashlight to be able to see the hoses.)
I wasn't using a flashlight but it was a very bright sunny day. I happened to notice a tiny, bright metal shiny glint that caught my eye. I could have easily ignored it because it was difficult to see exactly where it was deep under some tubes and hoses. When I looked closer it looked only like a non-descript hole. Again, I was tempted to simply ignore it and go on tracking down the charcoal canister. But I took one more careful look and what I realized is that the shininess was from the top of a short open metal tube that had liquid around its lip causing it to glisten. Then I noticed oily liquid stains all around the tube and on the engine components. (Had it been a cloudy day or had the car been parked in the shade I would have never seen a shine!!)
Not being a mechanic, my first thought was "Am I missing some dip stick?" I thought the tube looked like a dip stick tube. I thought that it might be the front differential dip stick. I wondered if the last time I had an oil change the service agent checked my fluids and forgot to re-install a dip stick. So, seeing all this mess I went to the Subaru mechanic thinking I was going to need a replacement dip stick. In the maze of hoses around the tube top I did not notice a short piece of rubber hose hanging loose near the tube. It was covered with black oily residue. As I found out, that gunked-up rubber hose, with an attached pinch clamp, was the crankcase blowback hose that had become disconnected from the tube coming from the crankcase. The blowback contains a small amount of crankcase oil and it was that oily residue that was all over the area.
So, now you know "the rest of the story."
Feel free to supply your own moral / lesson learned!
Thanks to everyone who responded.
I hope this helps other folks.
All the Subaru forums I follow are loaded with people anxious to help...so don't ever feel bad about looking for inputs. Also THANKS for posting the solution....people tend to forget their role in the info loop.
Ellen
Since I don;t know that area, I'm sorry, I can't suggest anyone, I know here on northern NJ the dealers get from $650 to $800 just for the Timing Belt replacement. Some also replace the Water pump and other pulleys as preventive maintenance.
Ellen
-juice
This problem only happens when the engine is cold -- it starts up without hesitation if it has been driven within the last few hours.
Since it only happens when cold, I'm leaning toward thinking the battery may just be getting a little weak, but I've heard that batteries should last a lot more than 4 years.
Also, I believe but am not 100% sure that the problem started around the time that oxygenated fuel here in Philadelphia switched to 10% ethanol. I've been researching the message board archives and Googling for answers, but haven't found any mention of Ethanol causing rough starts consistently for Subaru owners, only a mention of theoretically rougher starts due to the lower vapor pressure of ethanol.
I'm also thinking about resetting my ECU, but I've been consistently getting 26 MPG inexplicably in mixed driving for the last few months, up from about 23-24, so I really don't want to mess with the ECU if I don't have to.
Anyone have any ideas?
Elliot
I neglected mine and it died prematurely.
Top off the cells with distilled water.
The OE battery is pretty weak anyway. Mine starts much better after I replaced it with a WalMart battery with nearly twice the CCAs. It was cheap too, under $60 IIRC.
-juice
My electrolyte levels were fine, but I figured that since I'd probably need a new battery in a year or two anyway, it wouldn't hurt to get a good new battery (with a full 3 yr warranty and 8 year prorated) now to hedge any risk of a dead battery this winter. So I bought the top-end Maxx-35 battery at Wal-Mart for $62.
(My dealer quoted $120 for a new OEM battery installed, so the Wal-Mart battery + easy DIY install is a steal.)
I've had the new battery in for 3 days, and it seems to be starting a little better. I still get some hesitation starting it in the morning, just not as bad as it was.
In the end, I think it was the reset of the ECU from disconnecting the battery that made the most difference. In fact, the very first time I started the car after replacing the battery, it immediately stalled! On the next try, it must have "learned" the proper fuel mixture as it then started up readily.
I am also thinking about buying some fuel injector treatment to put in my next tank of gas. I don't think this could hurt anything, and could do some good.
Any additional thoughts from anyone are appreciated.
Elliot
If this works, my next question would be if this trick is a band-aid for a larger problem. Since my problem only started a month ago, I would assume that something in the fuel system is broken or about to break, which is band-aided by pressurizing the fuel line.
Elliot
"whirrrrr"
-juice
K
Kyle
Dear xxxx:
Thank you for taking the time to contact us. We do apologize for this inconvenience. We appreciate that you brought this to our attention. The correct capacity for the engine oil for the 2004 Forester XT is 5 quarts when replacing the engine oil and filter.
The 4.2 quart capacity noted in your owner's manual is for the 2004 Forester non-turbo models when just filling up the engine oil and not replacing the filter. The capacity of the non-turbo models when replacing the filter is 4.8 quarts.
We have advised our Publications Department that this information needs to be added to future Forester owner's manuals.
Thanks for the opportunity to be of assistance. If you need any future assistance, please feel free to contact us.
Best wishes,
John J. Mergen
Subaru of America, Inc.
While this specifies 2004, note that this letter is from August '03. I'm assuming this information is true for the '05 and '06 MYs as well.
Doug
And yes, you end up using almost all of 5 quarts.
-juice
I did that to mine and put it 4.25 quarts. 1000 miles later it showed up about a half quart low. Juice, are you saying that even with prefilling the filter, it still takes 5 quarts?
-juice
Some other possibilities: Are you using synthetic oil? In an older vehicle, I had been using Mobil 1 (original formula) for some years with no problems, but on a high speed trip during hot weather, it all slipped past the rings. During a 1000 mile trip, I ended up replacing it all one quart at a time with regular 10W-30 oil and that stopped the problem.
Is there another Subaru shop nearby that you can take it to?
Is this common, or is this some kind of problem that needs checked out? I didn't notice it doing this when I first got it 3 months ago -- it had about 120 miles on it then.
John
