Cadillac CTS Steering Problems
I bought this car in July of 2002, when it first came out. Since then I have brought it back to the dealership three times to have the steering fixed. The power actuater on the speed sensitive rack and pinon steering, the electronic module that judges the speed of the car with the relationship of more power steering or less keeps burning out. Every time that happens they have to replace the whole rack, because it is a part of the rack system. Has anybody out there have the same problem? :mad: :lemon:
I've had nothing but problems with my Goodyear tires on my 04 CTS. The tires were worn out at 10,000 miles on the outer edge. They replaced the tires and checked the allignment. Now the wheel shakes at 40-50 mph. Also, at 85 mph it REALLY shakes. I have no answers yet, but I'm going back in this week to talk with them.
Now, however, and at 100,000 km (62,000 mi) the steering developed strange noises (knocks and rumbels) and the steering wheel creeks as I turn it arround (like an old dooe squeek). Finally, the steering firminess was gone all together. Now the dealer say the whole rack and middle shaft have to be replaces, along with some fittings and brackets. Basically, the entire steering system is shot (about $2000+ fix). And the car have been our of warranty since 4 months. I have stayed clear of American cars since they converted to front wheel drive. When buying the CTS I hated the fact that it had a rack system, I know they are troublesome.
GM to the rescue. I called GM center in Dubai, and within 3 days i got approved for a good will warranty fix. For the record, I am impressed with GM Arabia's efforts, support, and promptness. They always come through.
I have my share of problems with my CTS, but I was so fond on GM Arabia professinalism that I did buy an SRX a year later. And I am planning on trading in the CTS for STS within a year time.
This was annoying enough that I was going to lemon-law the car. Fortunately I took it back to the same dealer, had the other svc mgr who drove the car and agreed that it was a problem. Cadillac sent an engineer out, who discovered that when the air intake housing was replaced from the accident it was not properly secured. Thus, over 3000 mi it worked loose and air got in after the mas-airflow sensor, resulting in a too-lean condition, since the sensor did not know that more fuel was needed.
The car now runs as it should and I am pleased, esp that Cad thought it important enough to send an engineer out to find the cause.
I never suspected that the cause could be the repair since it ran fine for 3000 mi after.
Cheers!
I lived with it till the whole steering system failed (see my previous posting). Now that lots of the steering assembly have been changed the problem is gone. Fixing my problem also included replacing engine mounts and tie links, it was a major repair.
The only problem with my advice is that by the time the system is shot (and it will) you will be out of warranty (as was in my case). In my case I contacted GM customer service and they granted my a good will waranty, the entire repare was for free
If the caster is unequal on either front wheel, you will get wander or pull toward the side with the more negative caster.
You may have experienced this with shimmying supermarket carts. That's what causes that, negative caster.
The dealer blamed tire pressure last time and I had the tires that were not OEM (bought car used) were replaced by another shop I trust. I've had the alignment and balancing done by the same shop I trust, but the issues still seem to be there. The shop acknowledges the issue, but the dealer is another matter since they like to blame the user/weather/road/anything else. I have an extended warranty, but it is useless until someone figures out the cause.
The silver lining here seems to be that others with these issues have had them fixed by the replacement of the rack. I hate going back to the Cadillac dealer because they always assault me with unwanted and superfluous services, and other places may not quite know the Cadillac as well as the dealer techs... so it's a rock and a hard place for me until I get them to find the problem.
Three questions:
1) Has anyone else experienced this same problem?
2) Any advice on how to work with GM on this assuming the Tech cannot solve the problem?
3) Any advice on working the lemon law rules under a worse case scenario?
Did you call the dealership and let them know the concern is still present? If the technician cannot figure out the problem please let me know. I will open a case and have an agent look at your situation further. Thank you,
Mariah GM Customer Service
Alignment
Control Arm Bushings
That is not a problem. What I will need from you is to have you e-mail me the following: contact information, VIN, current mileage, dealership and best time to contact you. I just want you to know the agent will probably have you take the vehicle in to have it diagnosed. You can get my e-mail by clicking on gmcustsvc. Thank you,
I have never experienced this type of attitude from any GM dealer. The service manager sent me a letter making sure I checked the boxes "Completely satisfied" or call me. I called him and never heard back. I just moved to Chicago and just chaulk it up to this area's customer service culture - which is very lacking.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I have had my 08 CTS since March 2014. It was a one owner with 30,000, so I got a great deal on it. The car drove wonderfully until I had to replace the tires last week. The car now has 40,000 miles on it and the tread on the previous tires was in the neighborhood of 3/32. I first put on Cooper RS3-A tires, a consumer digest best buy pick. As soon as I got in the car and left the tire place, a vibration started to occurr in the steering wheel at 60mph and higher. It would go in and out of intensity. I took the car back in and they rebalanced the tires and checked the alignment. Still doing it. So, we put on Cooper Ultra Touring CS-5 tires next and to my surpise, it was still doing it. Finally ,we decided that the original tire needed to go on the car (Michelin Pilot HX MXM4) and that should solve the problem because of how tight the suspension is. Guess what, still doing it. This is crazy! I have read the forum on this issue. Any suggestions other than going to a dealership or letting GM customer service know?
Thank you,
Jeff
