Buick Regal Brake Problems
countrygal5943
Member Posts: 3
in Buick
:mad: Three years ago I purchased my 94 Regal w/112K. I love the car, it runs great except for one major problem, every year I need to replace the rotors and brakes all around plus at least one of the rear calipers. In October I replaced the rear again but by the end of November I was back to grinding brakes in the rear so I did it once more but lucky for me the caliper was replaced free. I finally got fed up and wrote to GM and received a letter asking me to call them so they could assist me with my problem. I called the lady and she more or less said the letter was just a courtesy, there is nothing they can do. I asked why GM has not found a way to solve this problem and she said there has not been enough consumer complaints to issue a recall then she said since I bought the car used and it is so old that no one knows how well the car was cared for before I got it. I am so mad, despite the nice letter offering help she said there is nothing that can be done.
I want to ask all GM owners who experience this problem to write to GM demanding they fix this problem, if enough people get involved they have to do something. It is a safety issue after all.
The address is: General Motors Corporation
Customer Assistance Center
P.O. Box 33136
Detroit, Michigan 48232-5136
P.O. Box 33136
I really like my car, it is just a good size for me, easy to park, runs strong, handles good and only has 133K on it. I thought about trading it off but no one will give me what it is worth, I have only been offer $200 on a trade. I noticed other posts about rotors and someone is also having trouble with their power windows, mine is the drivers window, been out for 2 years. My AC also quit at the same time. I can handle those problems but this brake issue is getting expensive. HELP!!!! :sick:
The trick is to find the underlying cause of the brake problem. It could be a faulty proportioning valve that is giving more braking action to the rears than to the front, or maybe it is as simple as flushing the brake lines and filling with new brake fluid. Who knows?
Take it in. Before you authorize anyone to fix anything, make sure they explain what the root problem is so that YOU can understand it. Write it down if you have to. Then decide if the car is worth keeping.
According to the garage that does all my work this is a typical problem for these cars plus 4 other GM models but I have to wonder. I haven't heard anyone else complain about this exact problem and there are thousands of this model on the road, some look worse than mine. I will see if they can find the problem other than caliper next month when I take it in again for the same thing.
Thanks for the reply
I've only put around 14,000 miles on my 99 Regal LS in the two years I've owned it. The lady who previously owned vehicle(whom I called from dealership) stated she had recently paid for a $900 brake job. Which I assumed to be rotors and brakes.
Any ideas? Have these particular models had problems with rotors warping prematurely? Thanks.
For someone to pay $900 for a brake job sounds incredibly high, unless for some reason the dealer talked the customer into also replacing calipers.
The key to any good brake job is the quality of the parts. There's lots of cheap junk out there that retailers mark up to improve their bottom line.
Years ago NAPA was well known for the brake pads and rotors it sold, and to my knowledge they're still good. In fact, I just bought and installed a set on a Buick Century for one of my twin boys last weekend. He bought the car used a year and a half ago from a dealer who had installed new brakes on it. The old pads I took off were a joke. The NAPA pads had at least 25% greater braking surface area than the pads installed by the dealer.
Rotors are the same way. You get what you pay for.
Another idea: It might be wise to check the torque on the lug nuts holding the wheels onto the rotors. If they are too tight they can cause premature rotor warping. On these cars they should be tightened no more than 100 foot pounds. I always check the torque when I get the car home after having the tires rotated. On one occasion they were tightened to 125 foot pounds despite my exact instructions.
I asked if he could check the rotors. He went out and looked at them with another advisor or mechanic.They used some type of metal protractor device to check the rotor specifacations. Then called me in to show me where the rotors were worn/scratched on one part of the rotor and smooth on another part. Suggested I have front rotors turned. Which I did for $60 plus brake adjustment. Well, that seems to have done the trick as they brake fine now. It is curious though as to how a bunch of tiny microscopics scratches in a rotor can cause vibration in the brakes.
I recommend getting a good quality Raybestos rotor-top line, not the cheap line and putting on remanufactured calipers for the next time you fix it. It may be the calipers are not sliding on the bolts like they should. So they drag and heat up the rotors.
pads but its still messed up when i brake. :confuse: :sick:
I have to change the rotors on the front brakes but the backs are still perfect. I would suggest using the parking brake more to help with the rear rotors and brakes.
:confuse:
2. Raise and support vehicle.
3. Mark relationship of wheel to axle flange, then remove wheel and tire assembly.
4. Remove bolt and washer attaching cable support bracket to caliper body, Fig. 2.
5. Remove sleeve bolt and pivot caliper assembly up, Fig. 3. Do not completely remove caliper assembly body.
6. Remove outboard and inboard shoe and linings and two pad clips from caliper support.
7. Using a suitable spanner type tool in piston slots to turn piston assembly and thread it into caliper body assembly.
8. After bottoming piston, lift inner edge of boot next to piston assembly and press out any trapped air.
9. Ensure slots in end of piston are positioned as shown in Fig. 4 before pivoting caliper body assembly down over shoe and linings in caliper support. Use suitable spanner type tool to turn piston as necessary.
10. Install pad clips and outboard and inboard shoe and linings in caliper support. Ensure wear sensor is on outboard shoe positioned downward at leading edge of rotor during forward wheel rotation.
11. Pivot caliper body assembly down over shoe and lining assemblies being careful not to damage piston boot on inboard shoe.
12. After caliper body is in position, recheck installation of pad clips. If necessary, use a small screwdriver to reseat or center pad clips on support abutments.
13. Install sleeve bolt and torque to 20 ft. lbs.
14. Install cable support bracket and torque bolt to 32 ft. lbs.
15. Install wheels and tires aligning previous marks, then lower vehicle.
16. Apply approximately 175 lbs. of force to brake pedal three times to seat shoe and linings against rotor.
Can anyone help me?
Every vehicle which had problems had locked slides due to the top bolt being bent where the threads and shank of the bolt intersect. This bolt is too small to handle any lock up of the brakes and is even more fragile when the brakes are applied and the wheel hops on a rough road or pot hole. The sheer force of heavy brakeing appears to bend this top bolt which, once bent a little, becomes weaker with every braking and bends more until locking the slide.
I highly recommend replaceing all bolts when replaceing the rear pads.
experienced a bad pulsation. Rotors were removed and turned, it was ok for about
500 mi then started all over. Tech says it is the front wheel brg. is slightly loose
and this is causing the problem. He says this is a expensive job because it has
ABS. Help
