Lexus ES 350 and Bluetooth
I just picked up my ES350 today (so far everything is GREAT) and tried to connect my old Nokia 3650 Cingular phone. I have been holding off replacing it til I saw what worked with the car, but it is bluetooth compatible and I have linked it to several computers so I thought I'd try it. The phone indicates it has paired with the car, but the car display never acknowleges that. It still shows no phone connected and it is still trying to connect. Has anyone tried and been successful with this model?
Apparently some of these systems needs an actual call to be made to complete the process. Hope this helps.
The phone is showing that it connects, but the car is clearly telling me "mobile phone not connected".
Has anyone else fixed this problem?
1. Make sure the transmitter is not being blocked by your phone case. Remove the phone from any case you have it in and see if that works.
2. Try a reset of the phone; that sometimes clears up problems. Use the stylus to press in the hole on the back of the phone under the battery cover on the left side.
3. From the main phone screen, click on the top left corner to show the menu, choose "Options">"Phone Preferences", then try turning on or off "Enable Voice Privacy" and see which way works better.
Let us know if any of these help.
Others don't seem to be having the trouble so I am sure that it is a setting on my phone but I can't find anything. Does anyone have any suggestions.
http://reviews.cnet.com/4520-10895_7-6550017.html?tag=nl.e501
However, whenever I am using the bluetooth and recieve a 2nd call on call waiting, both lines disconnect when either caller hangs up. Yesterday, I took my phone to the store I bought it from and was told that this was a software issue and they needed to load a different operating system on my phone. They asked me to call Lexus to learn which operating system works with the Lexus. I spent almost 2 hours being bounced around between Lexus, the Lexus bluetooth specialists and Motorola. Finally, a Lexus customer service representative told me that the Lexus bluetooth does not support call waiting and that I needed to disable call waiting on my cell phone when making a call to keep from having call waiting disconnect the original call. She said that this is true for all Lexus vehicles and all phones.
I'd like to know if all other ES 350 owners experience this problem or if I got some misinformation. Please post and let me know if a second cell phone call makes your phone disconnect when using bluetooth.
I noticed just today that Sprint has introduced a new bluetooth enabled cell phone (Samsung A640) that MAY be compatible with the Lexus ES350. Does anyone know about the compatibility of this phone? I would also be interested in ANY Sprint PCS phone that would work with the ES350 as long as it is NOT a PDA-style phone .Thanks
I'm on the Sprint PCS network and don't really want to change mobile phone providers. I am, however, willing to upgrade my current phone to take advantage of the bluetooth capabilities of the ES350.
and another unrelated question... it used to be that you could cycle through mpg etc and set how long you were driving.. from the point you started to destination...if you stoped the clock stopped. the nav projects time and mileage but doesnt tell you how long you acturallly drove on the route.. did they take out the time calulation?
As far as your other question--I could be wrong but I think the ES 350 nav is not capable of displaying total elapsed travel time...at least not w/ the 5.1 nav disc revision.
1. Unpair your current connection with the car on your phone.
2. On your car's blue tooth setup, give the car's blue tooth device a name; do not use the default "Hand free...". For example, I use "freddylexuses" for my car.
3. Re-do the pairing again on both the car and the phone.
It should connect this time.
Many of the US cellphones are either "locked" so that they can support one service provider only, or use outdated operating system/software because Americans don't care. If you want to be safe, buy a phone from a US company like MOTO. You are more likely to get the latest operating system installed. Or, you may buy a phone in Hong Kong, where there are most advanced, unlocked phones in the world.
I was told Bluetooth is not available as an option without the navigation - is that true?
Phone book transfer is a different issue. Most phones don't do that.
I had the same problem with my microphone. I called the service consultant and was told I had to bring it in to get it adjusted. No charge. One of the engineers accessed the service menu through the nav system, selected bluetooth and increased the volume. The volume is between 0 and 5. I think the default setting is 0. The tech set my volume to 4 and it works fine. Everyone I call can hear me much better. Don't let them tell you it can't be done. It can. I actually sat in the car with him and watched him do it. He was very helpful and told me to contact him if I have any more problems. I am not sure how they adjust it for non-nav systems.
He also told me that there were microphone problems in some of the RX models that had to be replaced. If I have any other problems, he suggested that they may have to replace it for me. So far, so good.
I hope this helps. Good luck. Please let me know if you get it adjusted and if it works better.
See if that doesn't help with the problem........
i programmed a wait and have to hit the send button and manually have it send each tone.
pause and wait do not seem to work well
