Audi allroad: Electrical Problems
My '02 allroad (45k miles, I bought about 6 mos ago) won't start in the following scenarios:
1- Car is not driven for a couple days.
2- If anything is left plugged into the sockets, such as a radar detector, cell phone charger.
3- I added an iPod adaptor (connected via pre-wired cd chager) in rear cargo compartment. This seems to drain the battery as well...
These are drawing very little power and I don't have any problems using these devices in other cars...
I jump the car to start it and it is fine for a while...
I took it to the dealer and the tested the battery / alternator / electrical system and said that it is all within acceptable limits. I took it home and it continues to happen.
I'm taking back to the dealer tomorrow. I have till the end of the month till my factory warr runs out...
I love this car but don't want to have to jump start it 1/2 the time...
Has anyone else had a problem like this?
Please advise. Thanks!
BTW- Also considering whether or not to buy extended warr...
Any advice here?
Any advice here?
Brummie.
To drsp511 - Has your problem been fixed?
Did anyone every have this problem and can you direct me to the fix?
I am having the same problem with my allroad. I got a new battery and not it sat for 8 days and was dead. How did you resolve your problem? I'm off warranty so any help would be great so I don't have to waist money paying someone to figure it out.
Aug 2006
Car was parked at Philadelphia airport for 2 weeks. Battery was completely dead and I jumped it, drove 30 miles to home. I did not charge battery, but car started a couple times afterward. I think it sat overnight and was dead again next day. Local garage found starting and charging system working properly. Tested system for draw and found 353 milliamp draw after shutting engine off and 30 milliamp draw after letting car sit for 1 hour -- electrical draw within specs. Charged and tested battery -- found marginal battery (Interstate MTP-93 which I think was new when I bought). Replaced with new MTP-93 battery.
Sep 25 2006
Everything fine with new battery, but I took to dealer for checking. Dealer checked battery/starting/charging system and found "no defects present."
April/May 2007
Drove to Arizona in Feb 2007 for 6-month work assignment. Had several trips where I left allroad at Phoenix airport for 1-2 days. But later, 2 trips were 1 week, and each time the battery was dead when I returned and I had to jump start.
I plan to take to dealer in AZ. Very frustrtating!
Does anyone know where the sensor/switch is located as I can't see any around the rim of the tailgate or under the stainless plate where the catch is. Or indeed what the problem might be. Also the LED alarm light doesn't flash when the car is locked (but the trunk isn't)
Any comments would be appreciated. The Audi dealers in UK charge $190 an hour!!!
I have a 2005 Avant and this tailgate problem started yesterday.
Like you I've looked around for sensors etc, but have found nothing.
The only thing different is the car was washed on the friday, so maybe something got wet that shouldn't have?
I see 330 mA on battery.
Is there a way ti simulate close hood and closed driver door (jumpers or manipulate switch or lock)?
