At least I now know there are two of us.
A slight bump in the roadbed, steel plate, even a "plastic" roadway marking, can cause this effect.
Thank you for your response. Sounds a little technical but I think I understand. In any event, it sounds like I need not be worried about the "little surge". I had read about major surges and was concerned that my problem might be exacerbated. NMRK
I was thankful to get your message about your surging problem when braking. I also have not been aable to establish a "pattern of behavior" and am paranoid when I come to a stop. My surge led me into a brick wall and was a very costly incident-today I received a new insurance bill that tripled my insurance rate. The dealership checked it out and said it could not have happened the way I described it. I checked my floor mat and of course it was not the problem. I don't know if it will take a terribly unfortunate accident for Lexus to solve this problem, but I am thinking of getting rid of my car, which I love otherwise. I am sure there are not just "the two of us" who have experienced this event.
These are FWD vehicles, so it is EXTREMELY important not to allow braking of ANY kind, engine, regen, or actual frictional braking, to result in wheelskid/slip and therefore raise the potential for an accident due to loss of directional control.
To that end VW has just introduced a new engine RPM control design that will automatically up-rev the engine should the driver inadvertently downshift to a level wherein the rotation decline of the front driven wheels is so rapid lockup will soon result.
So we may now see a resurgence of FWD amd F/awd vehicles with stick shifting.
"..rolling through a toll booth...."
Hmmmm....
Metal expansion joint, slightly WET metal expansion joint.....??
Or "plastic" road striping, WET "plastic" road striping...??
Most modern Anti-lock systems are desired to pre-empt wheelskid/lockup by sensing that the wheel(s) rotation rate is decling so rapidly the lockup will soon result. With light to moderate braking and with the hybrid battery SOC being fairly low you may very well be relying on regen braking ENTIRELY.
If ABS activation is required then regen must first be INSTANTLY cancelled in favor of frictional braking ONLY. For a programmer there is no simple nor easy solution to this problem. The best solution, given the situation, need for ABS due to impending wheel lockup, it seems to me that it would be better/best to bring the frictional braking on line in a moderate way. Previous regen braking level was heading toward wheelskid/lockup, best to bring frictional braking on line at a slightly lower braking level.
So the driver feels a "lurch" forward.....
As I have said before, why not disable ABS altogether unless VSC indicates maintenance of directional control, directional correction, is required..?
The most of those brief instances of low traction due to expansion joints, plastic striping, and "bumps", would be transparent, "non-events".
Thanks for your attempt to educate me--but now I am confused.
NMRK
A true SURGE forward, actual forward acceleration, would indicate other problems.
My Lexus is resting this week--however, when I next drive it, I will try to ascertain whether I am sensing a "surge" versus, as you suggest, a "loosening of braking." You may be correct that what I am experiencing is loosening of braking. I would never take my foot off the brake to coast into a parking place so should not smash into anything. I had the car checked again at the Lexus dealer and nothing appeared to be abnormal.
Thank you for replying.
I have a 2006 400h and I notice when going down a steep hill, especially when the engine is cold, (but perhaps that is when I hit the first steep hill) that as I am gently braking the regen is putting a nice amount of power back in the battery and the meter is well into the blue, then after a few seconds the braking lifts off for a fraction of a second, the car runs away and the charging stops but the friction brakes kick in.
However, I think that is because I subconsciously press the pedal slightly harder and all is well again. Then I release the pedal and press gently and regen kicks in again and drops out after a few seconds and the process continues as described above till I get to the bottom of the hill.
I thought that was normal and happening because the regen wasn't able to provide enough braking but perhaps not....
I am used to it now and it's no problem to me.
Enjoy your car.. I do I have no intention of changing it for another 10 + years!!
Billy
If your "H" has the same EBD feature then it is likely that regen would have to be disabled when it activates.
My car has not been resting all of this time, my mind is.
It is a surge. I can feel the forward jerk and, so can my sister. She had this problem with her Grand Am.
I have not been in a situation where I had to brake at high speeds. I should check it out just out of curiosity. I have not established a pattern for this behavior and it is totally intermittent.
Lexus no longer responds to my emails. I guess they have enough problems. I now have 20,000 miles on the car and must replace the tires.
Thanks for your help.
With light to moderate braking this SUDDEN transition from regen braking, maybe ONLY regen braking, to SOLELY frictional braking might be somewhat JARRING.
You're body's seat-of-the-pants" sensors cannot easily distinguish between a lessening of the braking force and an actual surge forward. If you were in a flight simulator I could give you the same effect as a surge by suddenly tilting the front of the simulator upward.
"You're body's seat-of-the-pants" sensors cannot easily distinguish....."
Are you saying that the problem is my insensitive rear end? And all the while I thought it was the rear end of the Lexus. I won't even ask why the batteries on my Lexus, Prius and Ford truck go dead if not "walked" regularly. I'd hate to think I have other malfunctioning body parts.
Regarding the question of ABS pre-activation, it's possible, but I have another theory: it could be to maximize the life of the power inverters. Toyota may have programmed the regen braking to shut off if it detects any unexpected variation in the current/frequency of the electricity coming from the regen motors. If a wheel were to slip-and-catch, then presumably the voltage/current that are hitting the inverters are varying wildly. This could put a substantial stress on the electric components in the inverter, and shorten their expected lifespan. Hence, Toyota may have programmed the system to shut off if a significant-enough bump is encountered.
1) Fuel (Plugs are wet with fuel and noid tester shows Injector Pulse) and fuel at both side of fuel rail.
2) Spark @ 1.mm with tester and correct timing on spark.
3) Compression 150-160
4) New Crank Sensor
5) timing belt intact and did not jump timing.
I have done everything I know To do and to check but this is puzzling me? any Lexus or any other techs know what I may have missed.
Please help
2) Spark 1.mm with tester and correct timing on spark.
4) New Crank Sensor
Please help
