Chevrolet Cavalier Window Motors
kdoggflog01
Member Posts: 1
in Chevrolet
Hi i I bought a 2001 z24 in august and i'm already having some problems with it. First my passenger side window no longer works and its stuck at half way down position. I'd assume this is the motor for the power windows? For a while it would let you put it up a little or down a little at a time but now it doesn't work at all. Secondly whenever I got to stop rapidly I get a knocking noise and the car lurches forward on occasions. I also hear the same knocking noise when I make some of my turns. What could be causing this and how expensive will it be to fix?
signed,
a concerned cavalier owner :sick: :mad:
I used to visit another forum, the problems were all listed, the cool part is, if you want to call it cool, is you knew what problems you were going to have before you had them. The good part you already know the fix and cost and instructions on the repair. The window motors were a #1 failure item. The parts put in the cavalier are to put it nicely low grade, you have to move up to get better parts. The fact that GM is going down the tube has something to do with it, but through there stupidity they are making it worse, would you buy another GM product.
Seems to me the real problems started with the new model starting 1995, complete redesign. The issues were with strut bearings, wheel bearings, blower motor resistor, head gasket leaks, not your EcoTech, window motors, CD stops working. The fix for that is pull the radio fuse for a few seconds, works on all GM radios, I found that out on the web.
Look at the bright side maybe they are making them better in 2005. From what I read the Cobalt is not much of a car either. Good Luck
Want to get this fixed. And will fix it with my dad, but would like some insite on what it may be before I go changing all the motors and that not be it. And will not get rid of the car so some logical help would be appreciated. Thanks
I'm don't know how to fix the power windows on my cav, I wish I did because this is the second cav that I've had window problems with, the first one cost me $600 and now the new car is doing the same thing, I'll never buy another Chevy, they are crap! Thanks for letting me rant, Ann
Is anyone aware of any issue with voltage regulator, alternator or weak battery that may be cause these failures ?
Thanks for the help
I guess the only way for you to diagnose this for CERTAIN would be to have a wiring diagram of the switch and a test light, and then you would test the switch one position at a time and see if current is going in and coming out at the appropriate points. You can bypass the switch by connecting the wires but without a wiring diagram I wouldn't want you doing that. If you touch two live leads together you'll blow a fuse.
Which reminds me, have you checked all the fuses? On some cars, not all the windows work off the same fuse.
It is very frustrating to think the parts could be better to start with. Just venting.
