On my little S-10 pickup with 156,000 miles on it, I use the Valvoline Maxlife. I don't know if it does any good or not, but it doesn't seem to hurt anything. I think it has reduced the oil comsumption between changes, but it never used enough oil that I had to add oil between changes anyway. The truck had 134,000 miles on it when I got it, and I was afraid to switch it to Mobil 1, the oil of my choice, because I was afraid it would cause oil leaks on such an old engine.
Tom
Have you hugged your Jeep today?
Larry
The problem is not in buying chains to fit the tires, the problem is the tires are wide enough that chains could cut your brake lines. There is not a great deal of room between the tire and the line. Until I really looked at it I thought the clearance problem was with the height, and that didn't make sense to me (and a little lift would have cured). Each year I think about getting dedicated snow tires, and each year I decide not to, since most of my winter commute is on warm highways that never see snow (only the first 10 miles is usually snowy).
stomper - you have some good suggestions, but I'm looking for something a bit smaller and definitely cheaper than those. I loved an old '76 3/4 ton Chevy pickup I used to have, but with my commute the gas mileage would kill me!
If you are talking about the beautiful mountain scenery, those are Pete's pics. He also has a white Jeep, >>>
Tsjay, Pete, my apologies to you both for the miscredit. (I'll get bigger magnifiers for those late viewings).
Tsjay, I tried to dirct a friend to an old post of yours, # 6990, the one, I believe, that has (had) info on the Jeep build sheet. It seems to have evaporated. How did that happen? (No worry on the info, I went over to help him get the right info submitted to Chrysler)) Just curious.
Likalar (Red '00 Sport)
I couldn't find post #6990 either. What made ya think that was the number of my post about how to get a build sheet?
Tom
I was think about moving to a WRX. I especially like the 300 HP in the new STI version although it is pretty wild looking with the spoiler..
Anyone else here have experience with these little beasts?
Seats - Vinyl High-Back Bucket
Convenience
Group,Heavy Duty Electrical Group
Monotone Paint
Sport Decor Group
4.0L Engine(ERH)/5Sp Man Trans(DDQ)
Alternator - 117 Amp
Battery - 600 Amp Maintenance Free
Brakes - Power Front Disc/Rear Drum
Seats - High Back Bucket
Seats - Reclining Front
Seat - Rear Folding
Air Bags - Front, Next Generation**
Air Bag On/Off Switch - Passenger
Carpet - Front Seat Area
Carpet- Rear Seat/Wheelhouse/Cargo
Cargo Tie Down Loops
Sport Bar - Rear w/Padding
Console - Full Length Floor
Transmissions - All Manual
Transmission - 5-Speed Manual
Command-Trac Part Time 4WD System
Axle - Front, Dana 30/186MM
Axle Ratio - 3.73
Axle - Rear, Dana M35/194MM
All Engines
Engine - 4.0L Power Tech I-6
Windshield Glass - Tinted
Window - Front Door Plastic
Doors - Half Metal with Locks
Mirror - Left Manual
Mirror - Right Manual
Mirrors - Swing-Away
All Vehicles W/O Power Mirrors
Air Conditioning
Instrument Cluster w/Tach
Speedometer - 100 MPH Primary
Windshield Wipers - Var Intermittent
Lighter - Cigar
Horns - Electric, Dual Note
Power Outlet - Auxiliary 12V
Glove Box - Locking
STRIPE/BADGE/MOLDING/COLOR
Warning Lamp - Shift Indicator
Lamps - Courtesy
Lamp - Underhood
Headlamps - Halogen
Lamp - Center Hi-Mount Stop
Bumper - Front Painted
Bumper - Rear Black
Bumper Extensions
Headlamp Bezels - Chrome
Front Frame Overlay - Black
Grille - Body Color
Sport Bar - Side w/Padding
Emissions - Federal
EVAP Control System
Fuel Tank - 19 Gallon w/Tethered Cap
Stone White Clear Coat
Stone White C/C
All Radio Equipped Vehicles
Radio - AM/FM
Speakers - Two
Antenna - Fixed
Steering - Power Rack and Pinion
Steering Wheel - Leather Wrapped
Suspension - Normal Duty
Stabilizer Bar - Front
Stabilizer Bar - Front and Rear
Steering Column - Tilt
Spare Tire - Full Size
Tire Carrier - Outside
Tires - P225/75R15 OWL Wrangler AT
Goodyear Brand Tires
Spice Soft Top
Wheels - 15 x 7.0 Full-Face Steel
Wheel - Matching Spare
Wheels - Steel
Upgraded OBD-II Connectors
Skid Plate Shield - Fuel Tank
Skid Plate Shield - Transfer Case
Fuel Filler Cap - Tethered
Build To U S Market Specifications
8 Additional Gallons Of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
Payload Rating - 1800#
Sorry for making such a long post.
Subaru Impreza WRX
Obviously the jeep does not have the Dana 44. The build sheet says it has a front painted bumper but the photo of it shows just a black bumper. The build sheet also indicates that it has springs on all four corners. Wow! J
Is the “Command-Trac Part Time 4WD System” a standard feature?
Texasjeep, thanks for the heads-up on Camp Jeep. Looks like I’m a year behind. I’ll keep an eye open for future years. It would be really nice to have one so close. Larry18, I’ll definitely check out www.jeepthing.com.
Did you get the black wheels for off-roading puposes? How do the BFGs TA KOs work out (I have them on my truck and would be inclined to put them on a jeep).
Thanks in advance!
You have two items that I also have. First, we both have "Upgraded OBD-II Connectors"; what are these? Second, there is an entry that the payload rating is 1800#. Is this towing capacity or overall max passenger & cargo weight?
J. Thurlow
http://makeashorterlink.com/?Y44B52003
Can someone please confirm that the wheels on it are the Canyon wheels?
eARS
As for my top, I have the hard top ONLY. It's a pain to take off an put back on, so I like to take it off and leave it off for the whole summer. I have a cover that fits over the whole Jeep, and I keep that with me when there's a chance of rain. Usually, though, I just drive my S-10 pickup when I think it might rain. I have a garage to keep Thelma Jane in and something else to drive, so it is not a big problem to leave her topless and doorless all summer.
If you happen to get caught in a big rain, it isn't a real good experience, but the Jeep will be OK. They dry out and are fine after getting pretty darn wet inside. You may experience some crazy stuff with electrical things until everything dries out, though. It's a good idea not to use your stereo after it has been wet and hasn't had a chance to dry out good.
Yes, the Command Track is the standard and only 4WD system available for the Wrangler. It is a part time system, which means it should NOT be engaged on dry, paved roads. Not in high or low range either one. Just leave it in two wheel drive on dry pavement.
The Dana 44 rear end would have been a great option, but if you don't plan on ever putting tires larger than 31" or maybe 32" or getting a locker, then you will probably be just fine with the Dana 35. If you are going to do some serious offroading, then you might want to hold out for a Jeep that has the D44. A lot of folks are wheelin' with the Dana 35 (but a lot of those folks carry spare axle shafts with them in case...).
jthurlow:
I THINK the 1800 lb pay load is the towing capacity, not the carrying capacity. Someone else better answer that one.
The OBD-II connectors are for the engine error codes (OBD = Onboard diagnostics).
I think that covers about all of the questions, and I hope others will add their opinions as well.
Tom
Tom
Tom>>
I have a Jeep brochure with "build sheet" in my writing at the top of the cover. At the bottom I had written "6990", but can't remember why. I had assumed they was related, so when I searched recently, there it wasn't. Now ya' know! LOL!
Likalar
Thanks for the info. I was just curious as to why you thought it was post 6990.
Tom
I bought Thelma Jane a set of 31 x 10.50 BFG All Terrains while she still had her Canyon wheels. The All Terrains were great highway tires, and they were fair on the trails. They just don't do very well in mud, but on rocks and dry ground, they were fine.
I decided I wanted some mud tires, and I got a set of 31 x 10.50 BFG Mud Terrain T/A KMs. These tires are great on the trails, and I don't think I gave up anything as far as ride and handling on the highway compared to the All Terrains. They make some noise, but that doesn't bother me a bit, and they probably will have a somewhat shorter tread life. But, for the difference they make in the looks of the Jeep and their performance offroad, it was a very good trade-off! Heck, a Jeep just looks more "Jeepy" with mud tires on it.
I got the AR767 wheels at the same time I got the BFG Muds. The AR767s that I got are 8" wheels with 4" backspacing. You can't get much cheaper than AR767s: they usually sell for right at $40 each, without the center caps and chrome lug nuts, which don't add too much to the cost.
Tom
I think I'll check out the '98 Sport this Saturday unless I get stuck working. I'll let you know how it goes.
eARS
I was surprised that I punctured the MT/R sidewalls to. The Goodyear shop is going to give me 1/2 off a new tire which is very nice of them. I am going to get the road hazzard warranty for all 5 tires ($17 each) so that I do not have to go through this again.
Mtngal - I had a '78 Power Wagon with full time 4wd and loved it, but the milage was horrible. Back then I did not worry about it though.
Take care all!!
I'm going to try one of the "boots" to cover my soft top when I take the hard top off. Unfortunately, the previous owner never removed the soft top from the jeep, just left it in folded in place with the hard top on. So, depending on its condition, I may be looking at the safari top as well.
hello
hello
hello
hello
http://itsajeep.org
Click on chat on the home page at the top.
Tom
Stephen
I know that there is a stong preference for the I6, but eventually it is going to be replaced.
A Honda S2000 engine in Wrangler would be horrible for example. The HP is only available at high RPMS. You'd burn your clutch up off the line!
If Chrysler put out a Diesel 6 (inline or V) that had the same or more Torque than the 4.0 it would probably weigh less and get much greater mileage.
IMOP of course... )
Looked for ya in the chat room at Gill's tonight. Thought you might be back tonight.
Tom
I will try and make one though. :-)
Stephen
After passing that one up, I checked out another that I had also found on AutoTrader.com (also located in Tulsa). The AutoTrader ad did not mention A/C for this one so I assumed that it wouldn't have it. I was pleasantly surprised to find out it did. I checked this jeep out and it was great! It had everything on my wish list. It was my exact color preference (white with a black top), was in great condition and had only 20K miles. I fell in love with it and bought it.
It’s a 5-speed sport with a soft top and half doors (I know, I know, but that’s what I wanted). It has a/c, tilt, fog lights, cloth seats, CD, and sound bar. The wheels and tires are great! The wheels are Eagle alloys (058) and the tires are BFG TA KOs, (31 X 10.5). These are the same wheels and tires I recently put on my pickup! It was destiny.
It also came with a couple of extras a trailer hitch (used twice to pull a Seadoo), a Jeep brand bikini top and a Jeep brand deck cover.
I love this Jeep! I drove it home going about 70 most of the way without any problems.
Oh, I need to mention just after we left the lot, within about a block, we crossed paths with another jeep and got the ‘wave’. My daughter thought it was cool. We were immediately part of the jeep group. The timing for this first wave couldn't have been better.
Just one question so far: The center console is locked and won’t open with the key. We only got one key so far. They are going to send us the other(s). Is the ignition key supposed to work in the console? It doesn’t appear to be seating completely down into to keyhole.
Thanks everyone for providing such valuable information on this forum it really helped!
CONGRATULATIONS
Yeeeeeeehawwwwww!!!!!!!!!WAY TO GO!!!!!
What year? Dana 44?
Pics! Need pics!
I am so happy for ya, Alan!
Tom
If the key slot is parallel with the console's length, then it is already unlocked. You will just have to push down REAL hard on the button. But, don't go crazy until you are sure it is really unlocked. You didn't say what year the Jeep is, but on my 01, the same key for the ignition does it all... console, doors, tail gate.
Man, Alan, I am SO HAPPY FOR YA! When ya gona come wheel with me???
Tom
I have never locked my console, but I only got the one key for ignition and doors. I figure that one has to be for the console also.
Glad you got the wave already.
Big question now, what is going to be your first modification that you add.
Enjoy your new vehicle, they are fun. Hope your daughter continues to think the Jeep is cool.
Still a happy camper.
Tidester, didn't intend to copy your "WTG", but I refuse to change my message:) Your post was a bit quicker than mine.
I don’t know what my first mod will be. I forgot to mention that it already has Westin nerf step bars. Maybe a new exhaust with a Flow Master??? Maybe I’ll buy some of those grab handles.
The key slot is perpendicular to the length of the console so apparently it’s in the lock position. The key does not go all the way down into the slot, only about ¾ of the way in. I’m wondering if something is stuck down inside the slot preventing the key from going in. Do you think a locksmith can fix it?
Some folks replace the factory console for something more secure. Was the Jeep purchased from an individual or from a dealer? Try to contact the previous owner and ask about a key.
Just reread your original post, and you said you drove it off the lot, so that must mean ya bought it at a dealer. They may have a key that they didn't give you, or the previous owner might have one.
Now go to bed so you can get up early and chat with me at Gills and tell me more about this Jeep!
Tom
Hey that is practically a new Jeep, if it has only 20K miles on it! Thelma Jane now has 26 K on her, and she's an 01.
Tom
Just saw your pics of the new Jeep in the gallery here. NICE JEEP! That baby is a beauty.
You are new to Jeeps, so I hope you don't mind a suggestion? Don't put that shiny stuff on the tires: you will embarrass your Jeep. It ain't macho. Maybe the dealer did that?
Congratulations, once again!
Tom
eARS
Stephen
I SPECIFICALLY told my dealer that when Thelma Jane came in and they did the dealer prep, NOT to put shiny stuff on the tires. I also said no armor all on the flares.
Hey, how's this for a possible name for your Jeep: StephenWolf? Could just call him Wolf for short. Well, it's the best I can do for now.
Tom
TJRay
We will need to upload our pics again, once Gilly has the gallery working.
I know it's agravating, but it's just a minor inconvenience for us. It's HOURS of work for Gilly.
Tom
http://itsajeep.org/digichat/chatsigned.html
Tom
eARS
