Cadillac DTS Electrical Issues
Anyone having a battery drain problem with 2006 DTS Luxury III? My battery has been lasting approximately ten days prior to failure. Car has less than 500 miles on it. I agree about the lousy fuel economy.
I hope someone can help me or I will be forced into selling this gorgeous vehicle!! I just purchased a 2004 DTS with every known option and only 37000 miles. It is just beautiful....one BIG problem....my husband is 6'4" and the drivers seat does not go back far enough for him to be able to drive comfortably. His knees are literally up against the dash!! Is there any solution to getting the drivers seat to go back a few more inches?? Hope so or we are going to have to sell this super luxurious baby!! Thanks so much and hope I can get a solution!!
My 2006 DTS goes way farther back
Check with service manager before you get rid of it. Couldn't do anything on my 03
Good luck
I know that On Star wakes up and polls periodically for a specific number of hours after the car is shut off. It is, however, supposed to stop waking up after the car sits for more than X number of hours - 8 hours, if I recall.
Any chance you have a battery with a bad cell? Would not be the first time this has happened, even in a new car.
450 miles on the car. It sat for 2 weeks, while on vacation.
Upon my return the car wouldn't start. Roadside Assistance
replaced the battery. I called Cadillac customer assistance
and essentially told them what you stated about the design
problem. The response I got from the person I spoke to, Terlin, she never heard of the problem. I think the Cadillac engineers need to assess the problem. There are other problems I am having with this vehicle which I will list at another time, as I am in the resolution stage at this point.
Chris
Chris
:confuse: This car now has about 14,000 miles on it. It had been sitting in the garage for only one day. Sometimes it sits for 3 or 4 days and we've never had this problem before. The dealer said there was another DTS in at the same time with the same complaint. They said "drive it for a few more days and maybe it will happen again--then call roadside assistance" Wow--is that lousy service or what?
I recently bought a used 2006 dts and the same thing happened to me. Car dead, battery and all else fine.
There is an onstar update that fixed mine. I guess when onstar is trying to communicate with my car it takes power. For some reason onstar wasn't turning off and the battery was draining. Onstar knew of the fix and downloaded some type of software fix into my car and all has been fine ever since. Hope this helps.
If not feel free to write me.
chefcct@aol.com
I wonder if you might have left a door open enough that the interior lights stayed on? Or, perhaps the car did not shut itself down and ran the battery down. At this point the thing to do is keep on driving it as you normally would. I would check to see if the battery is run down early enough in the day so that there is time to get help if needed. I did that for a while after the SRX's battery was dead, but now I don't worry anymore.
a battery drain, even though miniscule, as dirt and moisture may act as a conductor (such as a resistor does in a radio). By making sure that the caps and covers are properly seated may help prevent some of the battery drainage.
Give this info. to your dealer. This hopefully should fix your problems.
I don't know if that had anything to do with the dead battery but we've been to Dallas twice and Denver once since then and have had absolutely no more dead battery issues.
A break in the wiring harness is a possibility but usually don't see that until the car gets much older and the insulation gets stiff...usually breaks frist occur where the harness exits the door and enters the body---you probably already know all this.
I've also seen corrosion inside a connector cause failures but usually exercising the plug fixes that, at least temporarily. You did say you checked the continuity of the in-seat element, right?
Sharon O.
car for 7 days the batter dies. I have had 3 new batteries installed, numerous visits to the dealer and each time I get the same answer, "we checked everything and we don't find any problems". After reading all the the similar complaints on line how is it that GM can't come
up with a resolution. Plus the battery is located under the rear passenger seat. Brilliant
design. Is there any reason the tax payers should loan GM any money. They need to be allowed to fail and thus survival of the fitist
an '06 DTS and went through the same episodes. I submitted my problems for arbitration under the lemon law, but GM went into bankruptcy. Now I am back where I started. GM needs to work on their QA
if they expect to survive.
Give this info. to your dealer. This hopefully should fix your problems. It fixed mine!
