Cadillac STS/STS-V: Real World MPG
Can anyone who drives one give a real world report on the mpg that the new STS is getting? We have a 00 Eldo [32K miles] and just finished a 2400 mile trip to Houston and back with some in and around mileage [300] included. Running on Regular, we got an average mpg for the entire trip of 29.3 mpg [generally not running faster than 65-70 mph on the highway]. It was actually up to 29.5 mpg at one point on the way home, but I had to do some [a lot of] lead foot exercises the last 140 miles to avoid all the trucks on I-65 from Nashville north in a pouring rain. The Northstar engine is great. I would be interested to see what the real mpg reports are on the new STS. :shades:
I think that in another year or so a six speed automatic will be standard. I also think the packages will change in time too.
The dealer told me to bring it in to look at the filter. Anybody else had this problem after the STS purchase?
If mileage was the all important criteria, you would have been shopping Chevys or Toyotas. But I think you - like me - wanted upscale American power and luxury.
You've got a great car. Great looks. Great power. Great control and ride.
Sit back, drive and enjoy.
1SE = 2.73 / and 1SF = 3.23 = 18+% more rpm at any same cruise velocity. (Tire radius = essentially identical and additional equipment on 1SF/1SG-s would mean further detriment to fuel economy.) This means approx. 18% more fuel would be required to maintain the same mph. Assuming 26 mpg for the 1SE = a reasonable cruise mpg, then 1SF or 1SG could be expected to return something like 82% of 26 = 21.3. A significant difference, to me.
Now the difference in acceleration (‘liveliness’) I noticed on my 2 test drives last Fall (1SE driven first felt somewhat sluggish to me, 1SF acceleration felt much more like what I’d expected from 4.6L and 300+ HP/TQ) may be worth an incremental loss in real world MPG. To you.
I am just (still) surprised that Caddy has somehow found a legal (I presume) way to publish exactly the same EPA ratings for STS V8-s with such widely different final drive ratios.
[[Note: The V8 AWD version, with a couple hundred extra pounds, and (I believe) the same final drive ratio as the 1SF is rated at 22 mpg highway.]]
- Ray
MPG being not the only reason I decided against a 1SF . . .
If I get 21 mpg, per your figures, that would be OK except that I am getting about 14 mpg on the highway. I filled up with 87 Octane gas and I will see how the second gas tank mpg figure comes out after the break-in period. I do not know what kind of gas the dealer put in the STS when I bought it. I guess I will have to use premium to get the best mileage but I would be interested in the trade-off between cheaper gas or better mileage.
Thanks for your responses.
Wouldn’t it be nice if GM actually provided comprehensive technical information for potential purchasers? (Rhetorical question.)
I don’t know if any changes were made for 2006, but in 2005s, here is the ratio information:
On a 1SE it's 2.73, and on a 1SF and it's 3.23, and on a 1SG and it's 3.42.
Here is what this means TO ME:
- Ray
Not an Engineer – and not playing one here . .
As far as the EPA rules go, the STS is one model/series, whereas the old Seville was two models (SLS and STS), so different numbers were published. The AWD STS has a different number. I think that it would be easy to rate each axle ratio that is available, but this does not seem to be done. The 2005 Corvette offered a high performance gears for both the automatic and manual transmissions, yet there is only one set of EPA numbers for each transmission...
I have a book on the 84 Corvette that shows the fuel consumption in different gears at various speeds. At 70 in third gear (1:1), the MPG is just under 20 (~19+), while in 4th (0.7:1), the MPG is just over 25 MPG. The engine is running 2000 RPMs in 4th@70 MPH, and about 2800 in 3rd. The engine speed is more than 40% more, but fuel consumption is about 25% greater.
2006 was \ is: 17 / 26
Oh, well.....
- Ray
Hoping for a bigger 'bump' in highway mpg
( sigh )
