:confuse:
The factory nav and factory uconnect audio go directly to the amplifier, not the head unit. The trick is how to contol the volume of them whith the factory system generating a PCI buss signal for the volume level. Best bet is to bite the bullet and replace nav, bluetooth, etc with a new double din head unit. You could get this all to work with the factory amp. I put a double din Kenwood in my 2008 along with sirius, bluetooth, ipod, nav, and backup camera, and provision for future rear seat DVD. The car had the intermezzo 385 watt system, no nav, no uconnect, no rear seat dvd, had sirius, had 6 disc changer. Removed factory sirius and 6 disc changer.
I bought a used pacifica 2004. It has rear video panel. I tried the wireless headphones which we used in the Honda Odessy van ( I think they operate on infra red signal) and they did not work.
First, can we use a wireless headphones for the rear video in this car? if yes, Is there specific ones?
Any help is appreciated.
gwadih
You need the 900mhz radio headphones with a scan button on them
They are wireless but not infrared
Your problem is you dealer gave you infrared not the 900 mhz model of wireless headphones
E-bay is a great place to find them
just make sure they are the "scan button model"
look for and e-bayer with over 700 feedbacks and a score of 99% or better
That way you will know they will be able to give you good advice and sell you the correct headphones.
Richard
I have a 2004 Pacifica and I have been told by the dealer that I need a new amp. I want to try to save some money so can anyone tell me where the amp is located in the 2004 Pacifica and what watt I will need for the new amp??
Thank you for your help!!
You would need to slide the changer out far enough to see the label. I've been searching the net, and haven't found one yet.
hope this helps.
just wondering have you found a cable for the dvd player? And where?
Feel free to email me.
Any leads here would be much appreciated!!!!
I want to install overhead monitor in my 2004 pacifica. Did you ever do it? How did it go? Also do you havethat wiring diagram? Any information would be great!!!
Thx.
Chad
send me directions on what you did. the big issue i have is Are there any aftermarket headunits that will control the 6 disc dvd/cd changer that came with the 2007 pacifica.
Thank you for you help
Is possible Connect SIRIUS and 6 DVD Player to Original Radio?
If somebody can help Me I really appreciate!
Cell: (501) 442-1491
Please help me.
I have a 2007 Pacifica and I want to install a 2005 6 disc dvd changer and monitor. Do you think you could help me with the harness es that I need? Chrysler wants a fortune for them.
24trojan
Could you please assist me in contacting your source for the dvd equipment.
Thank's
24trojan
The mode button toggles between DVD and Sirius radio in my Pacifica. Put a DVD in the drive and then let it play, then hit play on your ipod. The system will detect voltage from your ipod's audio output and switch automatically to it. It's certainly not ideal. I would have prefered a dedicated button. If you do a search you'll find people complaining about the system switching between ipod and dvd when there's a break (silence) between songs playing from the ipod.
I have a question about this - is voltage being sent *to* whatever is plugged in to the RCA inputs? I ask because I've blown 2 Soundgate Zune Core units plugged in to this interface. Doesn't take long, usually a day or two of use and I lose audio capability from the unit. It's still charging my Zune, but no audio or video. I plugged the zCore unit into my other car and it is dead there too (while my other zCore unit is working fine), so it isn't that the inputs aren't detecting the audio, the zCore is dead. I have concerns about plugging *anything* in to the A/V inputs in the Pacifica unless there is something I can add inline to protect against a surge from the RCA inputs
Any thoughts?
I am trying to installa double din on a 2004 Pacifica. I am interested in buying a mounting kit, if you have one. Please let me know. Thanks!
