Lexus LS XM and Sirius
                    I purchased Sirius radio with my '06 LS430.  Two concerns I would appreciate input on:
1. satellite connection is lost rather regularly when driving around the Wash,DC metro area.
2. antenna box is mounted on front windshield to right of rear view mirror. I can best describe the box as "ugly." Black plastic, triangle shaped, 5" at top tapering to 2" at bottom. Dealer says that antenna cable is too short to mount on rear window. Sirious radio has no suggestions. It seems to me that there should be some cable that will run from radio to rear window. Unfortunately, I have been unable to locate same. Will appreciate any suggestions!
1) It's cheaper to mount and less wire to run.
2) It's a retrofit as Lexus/Toyota radios are designed to work with XM, not Sirius. If you don't believe me, go to either XM or Siuris's website and see which manufactuer's are authorized.
It is truly a "cheap" fix and an inside antenna will never deliver the quality signal that you will receive from an outside mounted antenna.
Also, note that both Sirius and XM have a built in buffer memory that delays the programming for four seconds. When you lose the signal by going under an overpass, you it will kick in and you won't notice the loss in signal. With the interior antenna, you will notice constant dropouts.
Shame on you LEXUS!
I dreaded the thought of taking my car apart to install Sirius, but thanks to the folks at VAIS Technology, they have a plug-n-play interface that works with the factory head unit. They even had a converter for the shark fin antenna, so a seperate antenna was not necessary either! So if there are any Sirius folks out there, it's pretty easy to make the switch. I have not had any reception issues that Lexus claims to be a problem for them to not offer Sirius as an option.
I am a VERY happy camper once again.
KB
