Jim
So what is the story on this class action suite, please send me a link or two. Thanks.
Any suggestions, tips...
Oh, we have the 100k extended warranty, does this qualify?
Thanks for any input
All these changes seen very insignificant. Are there any technical reasons why I would not be able to upgrade to this tire size? Does it damage the vehicle in any way? The ABS, the suspension, the transmission?
The 2011 Sienna actually comes with this exact size and tire. Any reason why we could not use this tire on the 2008 Sienna?
The usual industry standard is +/- 3%, and you are well within that.
The front tire tread is down to 2/32 and the back tire tread is 6/32.
Toyota Dealerships have rotated the tires twice at 12K and 16K.
We think there was actually a 3rd rotation done at 8K, but its not documented.
Dealership is willing to give us a $160 credit toward 2 new tires of our choice.
Since I am keeping the 2 rear tires, any suggestions as to what brand / model
of tire to replace the 2 front tires ? Any benefit with buying another pair of Bridgestone's
of a different model/type in terms of ride and handling ?
Has anyone else had issues with Bridgestone Turanza ?
More importantly, I think the wear rate is pretty good when you take the whole picture into account. If the tires had been properly rotated, they would have gone over 30K.
In summary, we bought (2) new Hankook Optimo tires from the dealership where we bought the car. The dealership put them on, balanced, and re-aligned. Between the coupons and the manager discount for the tires wearing so quickly, we paid about $130.
After driving the car for about 2 weeks now with the new tires, no issues, and a quiet ride. BTW We still have the Bridgestones still on the rear.
At one time, Toyota offered a kit that contained a spacesaver spare, lockdown hardware, and a cover that went into that well. The downside is that you will no longer be able to stow the left seat as the well is now full.
They haven't offered the kit in years as there apparently was no demand. If you are interested, I can dig up the part numbers for purchase individually at the parts counter, or you can check wrecking yards and e-bay. At minimum you need the 155/80-R17 tire & matching wheel, plus some hardware to hold it down. The expense matching cover is something you can fabricate from some plywood & foam.
Spare tires are disappearing in many car lines, replaced by a pump kit that contains Slime or similar waterbased product. Personally, I'm not crazy about that solution as there are reports of damaged tire pressure sensors as a result. But I suppose that the possibility of having to replace a $100 sensor is way better than being stranded without a spare.
Thank you very much!
The industry standard would allow for a variance of +/- 3%, and that's well more than 3% bigger.
You're likely to get rubbing in the front wheel well, especially at full steering lock when you hit a bump.
I think a lot depends on what wheels these will be mounted on. I too am carrying over winter wheels and tires from my old Honda Odyssey to a 2008 Sienna I bought this year. While your tire is not exactly stock, mounting them to a wheel with a slightly different offset could make it work by moving the centerline in or out very slightly to provide clearance.
As I am a 'regular' at TireRack, I appealed to them for advice. It turns out that with a different centering ring, my Honda aftermarket wheels & tires will fit. Try giving them a call.
Thx
To,
This just doesn't seem right that these parts would wear out so soon (michelin tires).
Determining the need for shocks & struts is certainly more difficult, and I strongly suggest that you get more info on why from your dealer, or better yet get a second opinion. Are they leaking? Do you have unusual tire wear patterns that suggest poor wheel damping control? Does the van continue to bounce? Either way, I agree - a year old van with under 50k should not need replacements unless you do really poor roads, carry excessive loads or tow.
After the replacement "free" set of run flats provided by Toyota due to class action suit also failed (tread separation and bubble on side wall) within 20,000 miles , I bought a set of standard Cooper tires, and a spare wheel and space saver tire from Toyota for the luggage area.
They are wearing well and the ride and handling is much smoother than the run flats. The non-Toyota tire shop (GoodYear) said there was no way to set the real wheel camber to avoid the reported inside rear tire wear. I didn't check this with the Toyota dealer yet, because with 50,000 total on my 2005 AWD Sienna I haven't had that problem yet.
All-in-all the Toyota has been the most trouble free car I've owned, and the only item (that was fortunately covered by my maintenance policy at purchase) that failed was the radar speed control sensor (which would have cost $1500), and a recalled seat belt latch. They build great minivans, they just screwed up big time with the run fats. The new Sienna's come with standard tires and a covered place for the space saver spare in the luggage area.
Good luck,
Fred
I still have my 2006 with a 102,000 miles and getting rid of the run flats is a GREAT idea as the van drives so much better without them. I currently have 11K on the 2011 and haven't had to replace the tires yet but will be going to standard tires when they wear out.
Inflating the tires to around 40K and making sure the wheels are aligned will give you the most mileage on any set of tires with these cars.
If you are concerned about winter traction, the vast majority of drivers will be much better served by a FWD van with a second set of wheels and Blizzaks for half the price of AWD. It is not Toyota's fault that they offered this design compromise and ill-informed buyers don't understand what they are trading away to get AWD. So, blame yourself.
OK, so you made a poor decision. Now what? Go to your local Firestone Complete Auto Care Center and have them rotate your Bridgestone RFTs for no charge. Then, have them check the alignment for no charge. If the alignment needs adjustment, pay them 2x for lifetime alignment an get it checked every time you rotate your tires. Check air pressure at least monthly and fill to the recommended pressure, which is 35 on my van. If you switch to non-RFTs, you must carry a spare somehow. Do not compound your mistake by subjecting your family to a vehicle that can get stranded. BTW-The Bridgestone Tire Advisor currently recommends the new Dueler H/L 422 Ecopia as its top-of-the-line for FWD Sienna. This new tire incorporates the latest LRR technology into their premium SUV/light truck tire and looks like a fantastic choice for Sienna. Just do not drive without a spare, please.
Thankfully the (full-sized) spare was good. I check pressures even on the spare.
Would have been a total nightmare without it.
My Miata has no spare, a can of fix-a-flat instead, and I refuse to drive out of town with that car.
On my 2012 Sienna XLE FWD I have Firestone FR710 tires.
I saw another 2012 Sienna XLE at a Gas station and it had some michellin tires. I asked the owner if he replaced it, he told me it just came with it. He had exactly same car as mines (no AWD)
I would like to know why tires are different.
However, Toyota seems to be the exception. They frequently multiple source tires. I suspect it is a fear of losing a supply of tires that match the specs.
Having said that, I had a similar diagnosis once. In reality, it appeared to be low-quality tires (not the worst, mind you, Yokohama Avid TRZ) prematurely wearing out at the rear in a patchy pattern imitating that of bad struts.
Sienna's eat tires for some reason
I also mentioned once that my Sienna brake pads are only good for 10-15k. This problem is now solved. It was solved when I reluctantly (and partly accidentally) switched finally from OEM to aftermarket brake pads.
The van's been from DC to Florida twice, and CT probably 3 times. Plus countless times to the Eastern Shore of MD.
Still, very happy these tires have lasted this long, brake pads as well. They owe me nothing.
The manual says that the wheel nut wrench should be used to release the spare tire. The wheel nut wrench, which came with the car, has hexagonal shape, so it does not fit the nut.
Did I miss something?
Your van came with a spare tire winch that had a standard 21 mm hex head. Problem is people torqued the hell out of this with everything from impact guns on down, and this *may* have been a factor in damaging the anti-rust coatings, severe rusting, cable breakage, loose spare tires rolling free down highways, etc.
So as part of the recall, they changed the head to something non-standard, and they should have given you the special socket in a little black pouch, and tossed it in with the jack. You hook it to the little metal bar (speed drive tool) also back there to hoist it up and down. There should also be a yellow label on the base of the pillar telling more.
Besides, Tire Rack lists 33 different tires available in that size - excluding winter tires - so why are you wondering about changing tire size when there are so many options in the correct size?
