I agree with you other systems are better than OEM. Only reason I was looking at JBL because I was looking at Solara Navigation systems.
The 06 redesign went to a non-standard size, like yours. 07 is the same way.
So you may want to go to your dealer, or a Toyota wholesaler, and get the surround from a 2004 model. You could also try a junk yard, but good luck finding a Sienna that new.
Call these guys up, maybe they sell it (though it's not listed):
http://www.trdparts4u.com/
Their e-mail is:
info@trdparts4u.com
You're going to have to do a little homework on this project, but good luck, and please share your progress with us.
Does anyone know of a solution to this?
Brad
I'd like to add an in-dash DVD/GPS/Stereo with a couple of drop down LCD's and a back-up camera.
I'd rate them only about Average, though.
Why? They were a little messy - I found some wire fragments so they didn't vacuum the interior as well as they should have.
Also, they hooked up the dome light to the driver's door rather than to the switch on the dash.
It has worked perfectly and the fit is good, so I still rate them OK.
I do have couple of issues, one I spotted while I was driving out of there and they fixed that.
I still have one issue. One of the outputs are connected to AUX on the radio. I was told that I can turn it off from DVD so that I can use AUX for Ipod while DVD is being played. I have not figured out how to do that. Does anyone knows how to do that?
I also have them installed two output jacks on the sides of third row so that wired headphones can be connected. With those two, I can have splitters and can use multiple head phones if needed.
This unit is capable of transmitting FM but the sound was little statically on the Car Radio... I have not tried different frequencies. It might be better if you're sitting on the back seat with radio. I might use MP3 player's radio if extra head sets are needed. But there are head sets available on Ebay for less than $40.
To be honest it's not a big deal to me, there was no center dome light before, and everything works, so I don't want to risk them splicing more wires and messing up the interior again.
So that was simply by choice.
They did not wire to the Aux on mine, so I can't answer your question.
Changing FM frequency is easy - just hit the FM button, it goes up 0.4 Mhz on the FM dial each time you press. I think there are 4-5 frequencies it can use, I'm always able to find a clear one. Though on a long trip, you may have to change it once or twice.
There is one headphone plug on the front of the Jenson, so with a splitter you could add 2 headphones easily.
I have a factory DVD player, and folks listen to the audio through the sound system. When at destination, we stop the DVD, close the screen and switch off the ignition. Now, whenever the ignition is switched back on, the DVD starts playing, and I have to reach back with the remote to stop it. Is there a way to stop the player (or not start it) every time I start the car?
Dealer says the only way is to eject the DVD. This is not a good solution, since when I would like to restart the DVD, I want it to start from its current location. This is lost with the DVD eject. Thanks for your help, - M.S.
Mine does, but it's aftermarket.
After some careful Internet research, I opted for a hard disk-based navigation/DVD/music head unit with a 7" LCD. The hard disk-based units keep all the navigation information on a hard disk or solid state flash memory for fast performance and no need to swap DVD's or use your DVD slot for navigation. These units are generally more expensive than DVD based units, but they perform operations much more quickly.
I went with the Kenwood DNX7100 because it had reasonable reviews and great features plus expansion options. I also added the following;
-Kenwood Bluetooth Interface, KCA-BT100
-Boyo Vision Plate Frame Backup Camera, VTL300
-Eonon 14.1" Widescreen Flip Down LCD Monitor, Model 683 (from www.eonon.com)
-Generic Sienna Fit Kit
-Generic Steering Wheel Controls Interface
I had the entire system installed at Tweeter, etc. in Rockville, MD. I did not buy any of the equipment at Tweeter. They did a fabulous job in one day.
The system looks factory installed and the plate frame with integrated backup camera is just perfect. The flip down screen was very inexpensive ($250) and plays DVD's or other video input from the head unit. The steering wheel controls work and can do quite a bit, like change music folders on a USB memory stick.
A real bonus with the DNX7100 is a USB input cable that permits you to plug in any memory stick and play MP3 songs. It has a folder menu on the 7" touch screen. This works great. You hardly need an iPod. For an iPod, you have two options, a $20 accessory permits you to control some of the modern iPods via the touch screen or you can plug the audio input into the Video (a.k.a. AUX) connector. I had a hole cut into the top of the upper glove box and had the cables dropped into it for ease of use and to keep everything hidden.
Everything works very well. You can use the built-in Garmin nav system on the fron screen and watch a DVD on the flip-down LCD. When the nav system speaks, it only mutes the front speakers but keeps playing the DVD in the rear of the van. When an incoming call rings on a Bluetooth associated phone, the entire system is muted. Caller ID is shown on the 7" LCD and you can press a button to bypass answering an incoming call if you wish (otherwise, it answers on the second ring).
All in all, very slick. The Garmin nav system is great. The only downside is the kludgy Kenwood source selector interface. It works, but it's just awful. It seems like a grade school programmer wrote it and then implemented it without ever testing it. It's OK to use but frustrating to think of how good it could have been. Maybe Kenwood will provide an update - apparently this can be performed quickly and simply via the USB interface.
The back up camera is so nice, it should be standard on vans. As soon as you put the van in reverse, the screen changes to the backup camera, instantly.
Bottom line, hold your breath, $1500 for the equipment and $1000 for installation. However, this is a much better system than Toyota offers in any Sienna.
According to some websites like crutchfiled.com circuitcity.com, double DIN navs will not fit Sienna. I think 2007 and 2008 Sienna's have same opening for stereos.
Perhaps Crutchfield means they won't fit without a kit that they do not carry?
You can call them if you need more information. The installer did say that the 2007 and 2008 Sienna fit kits were the same.
The fit kit is made of a dark gray platic that looks good. I can assure you that double DIN head units fit quite well. The OEM Toyota unit is double DIN. Additionally, the Bluetooth electronics module and the GPS antenna were both mounted under the dashboard, too. Only the microphone, which is very small, is visible above the driver's side sun visor.
• iPod USB Direct Control KCA-iP300V
• Bluetooth Hands-Free Ready: KCA-BT100
• Sirius Satellite Ready: SIR-KEN1
• HD Radio Ready: KTC-HR100TR
• TV Tuner Ready: KTC-V300N
• CD Changer Ready
The factory DVD player forces you into the JBL audio package and adds about what you paid to the price. And that's just for the DVD player, no NAV.
FOURTEEN inch screen! You da man!
I thought mine was huge, at 12.1", but you win! That's sweet! :shades:
Anyway, the cost between the 13.3, 14.1 and 15.4" widescreens was negligable. However, at some point the entire rear view is blocked when the LCD is open. I opted for the 14.1 because it was in the same physical frame as the 13.3, meaning when it was open, the 14.1 blocked no more rear view than the 13.3.
With the 14.1, about 75% of the rear view is blocked. I had to draw the line somewhere. If you don't feel the need to draw lines, Eonon also offers a 17" widescreen flipdown which is only $320 shipped to the U.S. I'm pretty sure this would guarantee 100% rear view blockage!
My 12.1" screen blocks the top half of the rear view. I know what you mean by that.
It's OK, the bottom half shows the road, and who cares? I can always look over my shoulder and/or use the side mirrors.
1) expensive
2) People in third row can't enjoy it.
I'm looking at a solution installing just installing LCD screen and install DVD somewhere else. The screen alone would be lighter.
Yes, this is after I loaded a DVD into the player and opened the screen. The DVD player takes the DVD and the light comes on, but nothing appears on the DVD screen at all. I'm suspecting the drive itself is the problem as the audio system doesn't sense anything and the other functions (remote locater, eject, etc) work on the DVD panel itself.
1) Does anyone have a hint on what the problem could be?
and/or
2) If this DVD player needs to be replaced, can I replace it with an aftermarket unit and use the same connector/cable? If so I would opt for a larger screen unit, but aside from the connection I'm concerned about the mounting interior appearance after removing the "older" one.
Frustrating!
Can they be installed after?
I would appreciate any help you can provide.
Thank you,
We tried changing the fuses #5, #23, and #25 but the DISC button still responds with "NO CD" and does nothing on the second press. The rear DVD video screen is jet black and my kids are bummed out!
I noticed our previous owner replaced the battery with a non-Toyota part. We found another Post saying that once their battery was changed their DVD player stopped working... curious.
Anyways, we are out of ideas for now. Our used Sienna 2004 XLE AWD Limited came with everything but the RES remote; is the remote required for successful DVD operation?
I very much would like to add the XM adaptor with full factory control and add an iPod adapter. Can both be done? I got a quote of $500-600 from the dealership for the XM adapter and antenna installed. the local aftermarket place wants $400.
The JBL audio/NAV system has an XM input and an AUX, but the AUX seems to be for an analog miniport on the dash (not good for the iPod). I have an USA Spec adapter for my MDX which works great, but I do not have NAV in that system.
Does anyone know if I can achieve my goals? If so, product recommendations would be appreciated.
I posted on sienna club too. I am hoping to avoid the analog connection if I can.
Would love any input!!
Yes, the battery we were referring to is the main van battery under the hood. Our van had to be boosted twice during transport - once to get it on the carrier, and once to get it off. It was obvious the battery was drained completely when we took possession of the vehicle. We've had it for about a month now and everything is working fabulous - except the DVD seems not to be recognized by the system.
Our DVD player also has power to it, but it consistantly receives and ejects the DVDs no problem. It just has a completely black screen, and of course no audio to boot.
We have a Toyota RES remote control on order. We are waiting for a response from a Toyota dealer who put in a service call to a Toyota service tech regarding our issue.
My 2000 Toyota Sienna with 6 CD Changer quitted few months ago. I removed the unit but lost it. (TOYOTA 6-DISC AM-FM A56811 86120-0C040)
I installed a same unit from my friend's Tundra. The unit is working fine. My friend was going to install a satellite radio and no longer needs it.
When I plugged in the connectors to the radio/cd, I could hear some noice from the cd changer first (there is power), but their is no power to the radio panel.
I have also checked the fuses, they were fine.
Please help.
David
B2
They had an 8 or 9" model for $600 installed.
Mine came with 2 wireless headphones. We love it. Kids are happy, everyone's happy. No more "are we there yet?".
Came in handy last night, actually. :shades:
Please let me if you resolved your problem and maybe clue me in. I also saw the cd players listed on ebay.
The unit must have the capability since whenever a phone call comes in (through bluetooth) the radio mutes until you get off the phone.
I have the 2006 Sienna and my nav voice which I call "Little Bit" when she is right is controllable on the setup menu so you can make it louder than your usual volume on the radio. The nav voice comes out of the left front speaker. My radio voice isnot lowered or muted when the nav voice activates. Tanker5
