Thanks and God Bless,
KT
Thanks for your reply, however in your message you stated it as a 6 cyl. My car is a 1998 Toyota Camry LE 2.2 ltr 4 cyl. Are you sure this is a non-interference motor? Also, would I just need the belt replaced and water pump. Mechanic said I would have to have the whole "kit" for the belt - I think the part was about $127.00/ it included all belts and pullys? Or maybe they were talking about the water pump?
Any info would be appreciated - I can't afford a whole new engine repair. And if only the belt and water pump is to be replaced that would save me a bunch of $$$. Thanks so much. Hope you are correct about the non-interference motor I have.
KT
Do I really need to change the timing belt and water pump on this car?
Has anyone had timing belt fail on this model?
Has anyone had water pump fail on this model?
Does anyone have more miles on original timing belt\water pump on the same type of car (v6 2002-)?
I know this engine won't break if belt breaks, so it's more of a safety issue for me. But at the same time, I have seen timing belts changed on other cars and they didn't look like they had to be changed - they were tight and looked new.
Please advise. thanks
I am recieving my Moms 95 camry. I will be driving it from Florida to New York in July. The camry has 39,500 miles on. Given its age I have concerns about the timing belt. Without seeing it do you think it needs to be changed with the long distance trip ? The car is in good shape with new tires.
Maintainenced with oil changes, over the years,@ jiffy lube.
Reviewing her bills and concerns last Feb, I wonder if work done , was needed. At that mileage no one would concern with a timing belt.
She is not knoledgeable about cars and agrees. I went to get an oil change in Feb & they cautioned me to the valve on the AC compressor. I declined @ they seemed defensive. I dont care about thwere feelings , but am looking for a mechanic in the south florida ave to flush the engine & change hoses. It probably is better to be safe than sorry about the timing belt. any useful info would be helpful , plus roughly what it would cost.
Thank you very kindly
Bart27
Labor to replace it is about 3.2 hours and the belt itself maybe $40 bucks. I presume this is the 4 cylinder engine. The V-6 would be a bit more.
If you don't know where it is (I don't either), you're probably not in the best position to evaluate its condition. Your best bet is to get recommendations for an honest, independent shop that will inspect it. If there's no indication that it's been replaced, I would definitely replace it - it's probably deteriorated from age. That would be a rather nasty surprise if it broke on a trip.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
At the same time, they suggested me to change timing belt and water pump, which is a little over $1000. I have not changed it before since I bought in 2005. Is the price reasonable ?
If you don't know it already, the 3.0 V6 was known for having oil sludge, so regular oil changes are a must.
Does anyone personally know anyone who had it break?
Same for water pump?
Every time I had timing belt replaced it looked like new and sometimes even brand new. I even shown a honda belt with 110k miles on it to another mechanic and he was questioning whether the belt I was showing him was brand new....
wonder if it *really* has to be changed and at what millage.
And the same for water pump. If it's working, why change it? What are the chances it'll break and at what millage? I don't think the manual mentions water pump replacement
3.0 Camry 1mz-fe is non interference engine. If the timing belt breaks no engine damage occurs. It just won't run.
Honda says to change a timing belt at 105,000 miles OR every seven years.
Even on a non intereference engine, when they break you will be stranded wherever you happen to be.
