Toyota Camry Service Experiences
I recently had the most horrific experience I have ever had with regard to automobile repair.
I'll try to make this posting as quick and to the point as possible.
I went to the Toyota dealer where I purchased my 2003 Solara SLEv6 almost a year ago. This is
my first time owning a NEW vehicle and so I'm being extra careful in the early years and am
willing to pay the extra bucks to go to the dealer for maintenance. I know a lot about cars and
repairs and I have relatives/friends that are just as smart as the pros. I've been going to them for the
routine oil changes and tire rotations since I bought the car.
I went in for this dealerships own 15k service and I nearly fell on the floor when first told the cost
was going to be $285, but I was even willing to swallow it. The service included: oil/filter, check/service
battery, top off fluids, air filter, check wipers, etc.
The day after, I discovered that:
1) There were still remains of leaves inside the air filter canister.
2) Several battery cells were very low on water.
3) They never said or did anything about the passenger wiper blade which was obviously in need of
replacement.
4) Cooling system overflow was (still) closer to the MIN mark, as opposed to MAX mark.
5) Brake fluid container was also (still) closer to the MIN mark.
6) Windshield washer fluid container was nowhere near full.
When I went back to the dealer I learned that the mechanic had been working there for several years. I suggested
they fire him.
The service manager of the dealership really acted very calm about this whole thing. He didn't seem very
apologetic or concerned at all. He didn't indicated to me that any steps would be taken to prevent this
from happening again, or that he would take any steps to find out WHY this happened to beging with.
He gave me a fraction of the money back, but I still wouldn't feel comfortable going back there. How do I really
know that ANY of the items/checks on their list were done at all ? How do I know they even changed the oil.
I'm going to try another dealership near me and hope for the best.
I was thinking of writing to the OWNER of the dealership OR the President of TOYOTA, but I'm not sure I want
any more aggravation. There is a part of me, though, that is so infuriated by this, and now that I've
remembered this website, I've decided to post this and see if anyone else has any ideas as to what other options
I might have and/or find out if other's have had any horrific experiences with DEALER (dis)service.
Is this typical of DEALER SERVICE ? Have you experienced anything as horrific as this ?
replacement.
they fire him.
If you don't make him aware of your dissatisfaction, he doesn't know what's going on. I'd be curious to see what the ultimate outcome is.
You might also call Toyota's customer service and let then know about the shoddy service. They want to sell more vehicles and they'll most likely look into your complaint. Just remember to keep it civil....
Just my $.02
Deke
Because if they don't respond in two weeks, you should nuke them in the best possible way - Contact Toyota!
Toyota takes customer service Very seriously, and I have heard of owners making personal phone calls within minutes after someone contacted the manufacturer. Try the following:
Ask Toyota <toyota_cares@toyota.com>
call 800-GO-TOYOTA
-Hank2
I've owned 3 new cars (a Camry included) and dealer service always left me with a bad taste in my mouth. I once found a banana peel in my Camry's engine right after service. Another dealer overflowed the engine with oil.
I'd call Toyota and follow with a letter, and a copy to the dealer. I wouldn't return to the dealer ever. I no longer take my car to the dealer for schedule maintenance. Instead, I have my trusty shop do the work. If warranty repair needs to be done, then that's when I go to the dealer. I'd risk voiding the manufacturer's warranty by not servicing the car at the dealer during scheduled maintenance. I'll go to court if I have to but I refuse to leave my car at dealer service departments.
The key is to have a shop that you trust to do the work. In the almost 8 years that I owned by Camry I never needed warranty repairs. I took it to the dealer the first year because I didn't know better until I wised up and found a private shop.
My next experience is when the airconditioning failed. After repeated trips to the dealership from 50 miles away, I contacted Toyota USA, THEN the service manager called me. He had never spoken to me or returned phone calls when I called repeatedly to tell them the A/c wasn't working. It required a new compressor, motor, and other components. I wonder what is next?
Also, on a sidenote, they recommended a bunch of other stuff too:
-Fuel Filter replacement (Which after scanning newsgroups and this forum, I decided against replacing until 120k along w/ the PCV valve. No noticeable problems while driving)
-Fuel injector cleaning (I'll just add STP Complete System Cleaner in my next tank. No noticeable problems while driving)
-Replace Spark plugs (I'm doing this myself with the NGK double-platinum OEM plugs)
-Tranny full flush (quoted at $149.99, that a good price? I need it, the fluid is very dark)
-Coolant full flush (don't know if I need this, but at 70k I figure it can't hurt. Is $89.95 good?)
When in doubt about maintenance needs, refer to the owner's manual recommendations for your driving style.
The only items you list that are recommended in the owner's manual (for 60K miles actually) are spark plug and coolant changes. I'm not sure if Toyota has a set period for transmission fluid changes for cars in normal service. Also, if the air filter wasn't replaced in the last 30K miles, you should have that done also.
You can flush the coolant, but I'd just drain and refill the transmission. Granted, that way, you only get about half the dirty fluid out, but if you do it again in say 10K-15K miles, you'd refresh it with another shot of fresh fluid.
It's not a bad idea to replace the coolant hoses, but not absolutely necessary. Get the Toyota OEM replacements if you do so.
tranny flush @ 100k for $139.00
Spark plugs @ 60K (I know it costs additional $40 for this set while doing my 60k service)
Fuel unjector cleaning (I used Chervon's fuel system cleaner every time I have my oil change)
Fuel Filter? I asked the service manager and he told me the fuel filter supposed to last the life time unless I am having problem (which I don't)
Coolant flush, $59.00 (I have it done about every 30-40k)
PCV valve, I replaced it once myself @ 60k ($5.00)
All the jobs were done at TOYOTA dealer.
I see some people suggest to just do a drain and refill for the tranny. A service like that costs about $59 around the Seattle area but I whether have a power flush that will suck out almost all fluid) that way I am certain the fluild will be flesh instead of mixing with dirty fluid (if you just drain and refill).
I think the price you got from your Goodyear mechanic is too high because I had the same job done in the dealer and it costs less.
BTW, I have never replaced any coolant hoses yet but I did have my air filter replaced 3 times (toyota part)
I have a 2000 camry with about 59.5K miles on it. I am planning to do a 60K maintenance. A toyota dealer in my area quoted $445.00 for doing the inspections and checks. Is that reasonable. I live in the washington dc - northern va metro area. That is the lowest quote I got.
Any advise in this regard is appreciated.
SK
Question is to all the Toyota owners arnd Seattle.
1) What place do you think is good and least priced for getting the 60K service.
2) Also, I dont have a owners manual. Can I find it somewhere online.
3)Can someone lead me to a document that specifies what needs to be changes at the 60K servicing, so that the mechanics can stop cheating me.
Any inputs will be highly appreciated.
Amit
To get an owner's manual, try eBay. But for Toyota, you also need the separate maintenance manual, which lists in detail the items that require servicing, and when. So if you buy from eBay, make sure you get both booklets (the other booklets like warranty coverage, lemon law information, and tire warranty aren't needed).
Basically, at 60K miles, you should have the air filter, spark plugs, coolant, oil and oil filter replaced. It's also a good idea to drain and refill the automatic transmission fluid (no flush needed). Also the tires should be rotated, brakes inspected, underbody fuel and brake lines visually inspected, and exhaust, steering, and suspension systems inspected. This is from memory, so I may have left out a couple minor items. One item not to get is fuel injection cleaning, unless your engine is not running smoothly. The timing belt can wait till 90K miles for replacement.
Have you tried getting quotes from reputable independent shops, and instead of asking for a 60K service, try asking for the specific items I've mentioned above? If you ask for a 60K service, you're likely to get any number of items that aren't required by Toyota, as you've already found out by the wide range of quotes given.
In general, a 60K service quotes is different from place to place, I own a Camry and Highlander. I notice that the same service costs less in Everett than in Kirkland. And I like the service department better in Everett, reasonable quote and only perform necessary service.
Back to the cost for 60K service, it should not be more than $350.00 for a 4 cyl camry. However, keep in mind, most of the stuffs they do is check and inspect certain items and if I remember correctly, they will only replace air filter, oil change, flush cooling system and there will be a ($40-$60 addition) for the spark plug.
When my carmy hit 60k, I did have the job done in the dealer. SInce you only have your car for a few k miles and I don't know how much you know about your car's maintaince record. You should take it to the dealer at least once so you can set a baseline from then. Next time, you might not need to take it there for a 90K service because you can do most of the job yourself or do only the one that is necessary.
your mpg is kind of low even you are doing most city driving. Hopefully a tune up can get you better number
I request all of you hard working people who pays their entire one week pay check for oil change DON'T. Try to do stuff for your self if you are old tell your grand children or friends but DO NOT trust these delears. Do you know they charge $70/$90 per hour for nothing? This is 21st century do you think they do everything what is say on the paper that paper is for advertising. If you have extra money doesn’t know where to put please donate but don't make these dealers rich....
Who say's you can't change oil, Tran oil, coolant, breaks, spark plugs, tires and many more, check out techguys.ca or search Google for things you need... you will be fine . I have learned everything from these smart people who share their experience on the web so good luck....don't work hard you don't have to...
For those who don't want to do their own maintenance (and let's face it, changing oil can be very messy and difficult to do especially if you don't have ramps or even a garage), I'd recommend an independent shop (not a dealer, or one of the tire store or muffler chains, or "iffy lube"). Ask your friends, relatives, co-workers, or neighbors for recommendations.
I do believe some dealers provide better service than the others. The service manager will let me know what need to be done instead of asking me to do this or that for my car. There are couple times I wonder if I need new plugs and other stuffs and he told me NO, 'unless I am having problem'. He seems pretty honest to me and their quote are reasonable.
So far both of my cars are free of problem and I have not spend anything more than regular maintaine.
In your case, $250 for an oil change is a lot and you shouldn't have paid them that much. It costs me only $40.00 for an oil change from a toyota dealer (syntec oil for 5000 miles)
That maintenance schedule in the book is designed by car manufacturers to help the dealership maintain profitability. It intends to offset the rebates and discounts and all sort of price cuts the manufacturers give away in luring car buyers. So the rip-off continues in the maintenance side.
Coolant drain and flush costs $39.00 in Orlando cheap enough that I don't have to do it. (I do it every 30k I had a corolla that had a rusted radiator and don't want a repeat of that)
Transmission drain (not flush never do a flush) $59.00 so far every 35k
I switched to mobil 1 synthetic at around 60k. I get the extended run mobil 1 oil filter (up to 7,500 miles) so pay a little more then normal. Walmart price around $45.00. But I run it till about 7k.
I change out my air filter 2 times a year. They say they last 20k but they are cheap enough to change twice a year. $13.00
Changed my front rotors at around 50k because they cost like 22 bucks each instead of having them turned, I figured why turn them?) I also put in ceramic brake pads. (total cost was about $100.00 I did it myself)
At 105,000 Had timing belt, drive belt seals and water pump changed out for $700.00 by dealer. Just maintence didn't have a problem. Wasn't sure I should have had the water pump replaced, or seals but did them.
At 105,000 I replaced the spark plugs myself put in non-oem platium plugs. I think it cost me like $12 bucks. No problem but figured at 100k give the car a treat.
At 110,000 I plan on having the brake fluid flushed and filled for the first time. I think it runs about $59.00
At around 110,000 thinking about having power steering fluid replaced as well but not sure.
How easy or difficult is it to replace the brake pads and rotors on a 2007 camry ?
I feel the dealer is asking too much for the same. Can I do it myself ? and what special equipment will I require ?
TIA
How much are they asking?
