I am having the same problem and would like to give your tip above a try. Problem is I dont know where the parts you are talking about are. In your mail you are talking about a site that shows how to do all this stuff with pics. Can you tell me what site it is. That will be very helpful.
As far as I'm concerned, Camry's are the best cars in the world! However, I notice that mine sometimes "surges" when going up a hill or driving slow. When this happens the rpms stay constant and doesn't shift gears (its an automatic by the way). Just curious if anyone else has had this happen or may know what is causing it. Also, when the car is stopped at a stop sign for example, it runs rough, but when shifted into neutral it runs fine? Thanks for you help.
-Alex
Any assistance will be greatly appreciated.
Perhaps if you provided more specific info, maybe we could help you better. Or, I'd recommend a reputable, competent repair shop to diagose your car. You don't have to go to the Toyota dealer. Get recommendations for good shops from friends, relatives, or co-workers. Personally, I like independent shops, not those connected with national chains like Sears, Goodyear, Midas, etc.
Rob
I would certainly have it checked out by a mechanic before consumating the deal.
I did not realize the problem extended back to 1994. The sludge policy/warranty started with the 1997 MY. It did end with 2001 for the 4 cyl., but I believe on the V-6, it extended part way into 2002, until Toyota implemented the design modifications.
Another sign of sludge would be smoke in the exhaust.
That was not at all the case, nor is it why the SPA (Special Policy Announcement) came out in 2002. It was a public relations decision because of wrongful negative publicity, not an extended warranty for engine problems.
The cause of sludged engines was found to be a direct result of lack of reasonable maintenance--specifically lack of or insufficient oil and filter changes.
Many such occurrences were because owners had done no oil changes at all, and others had only done them sporadically--not frequently enough to avoid sludge development.
The issue became a cause celebre for a few self anointed activists who blanketed the internet with anti Toyota rhetoric about it for several months.(They actually got banned from Edmunds and a couple of other car sites because of their disruptive tactics) The issue died as quickly as it began, a few years ago.
In response to the bad publicity campaign by the vocal ones, Toyota decided to indemnify anyone with a sludge problem regardless of what cause was invoved--free repairs provided proof of only one oil change per year.
It is now no longer an issue, but a few of the badly neglected vehicles are probably still around.
Before buying any used vehicle(Toyota or otherwise), buyers should try to get a maintenance history, and/or get a thorough pre buy inspection before laying cash on the line.
With the more recent advent of leased vehicles, more and more fairly new but neglected vehicles are showing up in the used car marketplace. So it's buyer beware.
It is wrong to suggest the SPA was a 'warranty' of any sort. It was a special policy, clearly and publicly identified as such, issued as a goodwill gesture to show that Toyota stood behind its products. Nothing was ever said about warranty. That's a fact too.
It is wrong to suggest that sludge was caused only by engine design, and completely ignore any influence of inadequate maintenance, and that inadequate maintenance was found to be by far the most prevailent cause of sludge.
It is wrong to suggest Toyota made changes in engine design as a result of any problem, or to correct a problem with their engines.
Toyota clearly stated that a minor change was made to the PCV system so that engines to provide 'greater tolerance to haphazard owner maintenance'. That's another fact.
It is also true that Toyota publicly announced a reduced mileage interval to focus more attention on the need for regular oil changes, mainly because owners were exceeding the old mileage interval and causing damage to engines.
All of the above is clearly documented in any number of public announcements by Toyota officials on this subject.
Most folks would tend to accept statements by those making these public announcements over alarmist claims by anonymous posters dealing in rhetoric and spin, and who have obviously attempted to place blame where it doesn't belong.
I would advise any newcomer to this issue to bear in mind that there are individuals around who are bent on painting a misleading picture of the sludge controversy.
One can only wonder what the motive for doing that might be.
It was another method Toyota adopted for oil change reminders. They wanted proper maintenance to be an "idiot proof" function, so tried to make it as "no brainer" as possible for owners.
Here's a a typical sludge story FYI.
The other day I took our new HL in for its first service, and the service manager showed me an '03 Sienna in the shop.
It had 46000 miles on it and the engine was toast-completely siezed up. They were taking pictures of it when I was there.
They had opened up both top and bottom ends of the engine. The entire centre section was packed with black jelly-like and well cooked crud. Valve train on each bank of cylinders was the same.
The original oil filter was still on, and packed solid with crud. Oil pan had about 1/2 quart of black liquid (oil?) and was full of crud. There was no evidence of oil ever being changed since the van was new. Oil sump drain plug had the original factory crush washer on it.
Service manager said it was like a few others they had seen over the years. People just didn't bother changing oil, then insisted there was something wrong with the engine and demanded warranty. Typical scenario, and really sums up the sludge fiasco.
The service manager just shook his head and said he couldn't understand why some people never learn.
This way, if you cry "Sludge!" at 20K miles or more, the dealer can readily determine if the original factory filter is still on the car.
Pretty clever, if true.
Your on the right track, maybe next time remove the throttle body (3 bolts and a couple coolant hoses - wait til engine is cool and plug these hoses). Then find the IAC valve and clean it really well too, alot of times it gets gummed up too.
www.toyotanation.com/forums has camry manuals on line for download in adobe will tell you a lot more on how to do this relatively easy task
VEnky
The camshaft(s) have to come out to do it. What they normally do is hook a fitting up to the spark plug hole and pump in air to hold the valves closed. (You can also stuff in nylon cord as an alternate method but use care.)
The object is so that the valves dont fall inside the engine when you remove the spring and keepers to change the seals. And the valve seals themselves are relatively cheap but they are not easy to get to, so thats where a high labor cost comes in.
I had a similar experience several years back. After a heavy rain my automatic windows could not be opened and my engine thermometer showed erroneous readings (reading high temp even though the engine ran at normal temp). All problems disappeared after a few days basking in strong sunshine without help from any mechanical shop.
Could someone give some hints about possible causes for the above problems?
We also have a 2004 Sienna XLE. Should we expect the same issue with it? If so, how do we go about preventing it?
Thank you for your time and your help!!
All the Best,
Shoshana
