Toyota Avalon Climate Control Questions
Anyone have info. on how to change the air conditioning filter located behind the glove compartment? thanks
The first time was on October 3, 2000; parts $39.92, labor $68.00 and $2.00 tax for a total of $109.92
The second time was on August 1, 2002; parts $52.43, labor $15.00 and $2.72 tax for a total of $70.05.
Why the big difference in material (part) cost? The service manager did not have a good answer, but after I insisted that installation should be no more than 10 minutes (advice from a poster two years ago) he agreed to charge $15.00.
The big benefit for me this time was the mysterious disappearance of the rattle in the glove compartment area. The car was initially rattle-free but after changing the AC filter the first time an annoying rattle suddenly appeared. Although I had suspected that was the problem the technician thought otherwise. So please ask your service technician to be extra careful in installing the AC filter.
And avalon123 for $15.00 I would rather have the dealer do the install rather than suffer through a rattling cacophony.
Other than the compressor noise, my car is very quiet.
Have you considered checking the Alternator on your cars ? I had a similar problem with my 2000 XLS, and it turned out to be a defective Alternator! When they finally agreed to replace it, the noise disappeared. Since the Alternator and A/C are so closely linked, maybe that is your problem. Good Luck.
The dealer first balked at changing the alternator. So I logged on tothe Toyota website and wrote an inquiry about the noise. Sure enough, I got a call from the dealer in 4 days, saying that they will change the alternator without charge. All the repair manifest said was that it was "a defective alternator" but did not specify the nature of the defect. You should try the same method in getting Toyota's attention. Good luck.
1. Heavy Mold Smell in AC ducts
2. AM/FM Preset Buttons on Radio just falling off from normal use
I have had the "Evaporator" cleaned and serviced-$100. This initially removed some smell, only it came back after 2 days of AC use in muggy San Diego weather. I bought the car with the smell a year ago, never really used the AC and thought it would dry-out and dissipate over time. Now I am getting sick, physically. Any ideas on extent of problem or if work done was a farce? Does the entire duct system need to be cleaned and is this something covered in typical warranty? A year ago they just told me to use Ozium spray in the ducts. A few months ago I was told to always use "Recirculate". Then I was told I needed to have the Evap cleaned. WTF?
Radio... come-on. You mean to tell me that a 4 year old car's stock radio button are going to break and fall out of sockets when you touch them?
Other that Suspension problems, Small cosmetic flaws, and rotting stench making me very ill. I like the car. The pick-up is great. The roominess, they reliability. Maybe I was meant for a Buick?
There are several more, but start here. I am not sure I could come up with all of 'em without my svc manual???? I'll be home after Thanksgiving, if you you need more specific info. -nomad56-
If the dealer does not give you a definitive diagnoses, you will have to start troubleshooting the system, to isolate the bad component.
What "computer" did the dealer replace? Toyo HVAC is a web of sensors, switches and relays. It often requires some electronic testing equipment and skills. Let us know.
-nomad56-
I have a 1996 Avalon, Runs Great but I have encountered a problem with my fan. Many times the fan will not active by pushing the fan speed button or by the automatic climate control until until I drive the car over a speed bump at 10 mph or less. I know something elec / mech is loose but have no knowledge of where to look first except for the fuse box under the hood which seems to be fine. And it does not seem to matter if the a/c compressor is activated or not. there is no movement by the fan motor until I go over a good bump.
Any suggestions before bringing the car in for A/c fan work,$$$$???
All Help is Appreciated thanks in Advance
Michael
Thanks Mr_Shiftright HOST May 10, 2004 (4:04 pm)
Does the fan work when the heater is on?
I will give the relay thing a try, and at the last resort, I can bring the car in to a Toyota Dealership.
Michael
I suspect it is one of the relays but have no way of knowing which of the dozens it might be. Since the symptoms are so specific, does anyone know what might be the cause?
toydriver-replacement rotors are $80-$90 per/corner. Less if you shop it around. ie) eBay you can get a pair for about $100. Pads $60 to $160, depending on material. It's a "DIY'er" for me, but I think the book lists 2 hrs. -nomad56-
I'm beginning to suspect that it might be related to outside air temperature, since it seems to work when the air is cooler (I live in San Francisco where cool summer prevail but 100+F temps are a few miles inland) but am still awaiting another warm day. My wife took it to the Central Valley for the weekend so I'll hear about it if it failed again. :-)
Please let us know if you come up with a solution. I'd take it to the dealer but have had some real problems with sabotage in the past.
Anyone have suggestions?
Other possible sources of noise are worn bearings of the spinning parts in the A/C & charging system, I also had two blower motors go bad in my 84 Corolla.
If this is too late and you have already gone to the dealer, please report back with what happened & what it cost to fix. I may have to go in also.
Tomd14-still am curious as to what your problems were diagnosed as...
