Toyota Avalon Water Leaks
Can anyone out there shed light on possible sources other than the obvious trunk seal for a pesky water leak in trunk? Live in the northwest with lots of rain and cannot accept this problem for long. I have removed all interior mats and linings in trunk, sat inside with flashlight and had wife run hose over tailights, all around trunk seal, even checked the sunroof rail vent holes and tubes which seem to be clear and draining o.k.
Cannot figure this one out and definately cannot afford to have dealer hunt it down yet.
You mentioned the wife pouring water over the tail lihghts which reminds me of my trunk leak on a different make and model in the trunk.
After much sherlock holmes work I found that on a hard rain with wind, that the water was coming in aroung the license plaste screws. I applied silicone around and in the plastic screw holders and reinserted the screws and presto, leak gone.
A buddy had a tempo, i know not an avalon, however, where his rear quarter panel met the sill plate behind the rear window the joint sealant had crack and water was running down the edge of the rear window and along this joint and worked it way along the inner wheel well and into the trunk. Just something to think about. Water leaks can be a bugger to find as they can migrate a good distancec from their starting point.
Good luck and post again if you can be more specific as to where you might think the water is coming from after you get it all dried out.
Could be the source....it happened to me.
I'm not sure where it is coming from. Any suggestions on what I should look for would be appreciated.
Mike
On my new '03 Avalon there are two drainage hoses tucked up underneath each of the rear quarter panels behind the rear wheels.
Whether those hoses have something to do with what you are experiencing I will check into for you.
The water drains out for the a/c, and the weather stripping around the window seems to be ok. I am clueless, is there anyone out there that can reccommend what possibly might be wrong. a/c works fine, taken it thru car washes to see if by chance I could see water coming in thru the window, but nothing, help!!!
I marked the spare tire section edge with white washable marker (Kids), & I checked the trunk after a rainy day. Sure enough the water was going inside from the trunk lid bumber side. There were 3 spots which had wet white paint. Both sides close to the light section (right after spot welding), & the mddle where thruck lock is there.
Pulled the rubber linner from the trunk edge. It was wet & rusty. Then I notice body where this linner sits, & notice gap for water to enter. Take it to my garage (not the toyota) Mechanic pulled the linner around the trunk. At factory they do SPOT Welding & expect two sheet of metal to press perfectly. However, there were small gaps. He cleaned with angle grinder & put auto caulking to seal & let them dry. Clean the linner. I let it dry for a day, reseated them. No more leaks so far.
Roland
Don't know if anyone else had this issue, but would appreciate any thoughts on whether the car will give me problems in the future because of the electrical problems.
There is also water in trunk right-wheel well and spare tire well. Trunk lid and liner were replaced 3 years ago when I got rear-ended.
I have read here that shrinking plugs, bad welds, gaskets, windshields, wheel well drains, etc., can cause similar problems in both compartment and trunk.
My question: What would be the least expensive way of getting a bumper-to-bumper diagnosis? I have tried to figure it out but no luck. Shall I see auto mechanic, body-and-fender shop, etc? I would prefer not being fleeced by dealer.
(Pardon if this posted somewhere earlier. Had pw/login problems, so not sure msg posted first time around.)
Mike
How does your trunk seal look?
Its going to be really hard to tell since you have it coming in the front and back.
What I would start with first is to lock yourself in the trunk with a good flashlight. Then have a helper squirt a hose around the back of the car and look for leaks. If you find one, take appropriate action to fix and see if that cures both leaks. If you at least stop one, you can then move onto the other.
You can also do the same test in front. Take off the trim, pull back the carpet and have a helper squirt the car with water and start looking around.
2023 Mercedes EQE 350 4Matic / 2022 Ram 1500 Bighorn, Built to Serve
Should I remove the interior side linings (the ones held on with those pesky plastic plugs)? (Already removed trunk floor cover). I am also looking for simple schematics showing all drain lines (I never knew wheel wells had drains!) The owner's manual does not go into such detail.
I agree- front and back makes it doubly vexing. I will post when I have more info.
Thanks again. Mike
CAUSE: I was rear-ended two years ago. After auto body shop replaced the trunk lid and straightened the bumper, everything seemed fine. Carpeting, etc. back in place. Looking closely today, after vacuuming the water out of the spare-tire well, I closed the trunk and hit the rear car with a hose for about 4 minutes. Upon opening the trunk, I saw tiny rivulets running from the bumper side of the interior trunk into the spare-tire well. When the car was fixed, apparently the shop did not properly seal the bumper after "fixing" the dent.
The water in passenger compartment -- with a recently cleaned A.C. drain hose -- remains a mystery.
I haven't looked at all your previous posts but have you check the fresh air vent cavity under your windshield wipers (you have to remove the cowl) to see if that drain is plugged with debris?
Also sunroof drains of course.
I had no idea about the fresh air vent cavity. Can this be what I am now blaming on the A.C? Because I saw water flowing out the drain this morning after driving while using A.C., meaning it remains unblocked. Can the vent cavity drain be diverting water into passenger-side floor??
Is this just a case of removing the screen that runs across behind the wipers. Just pops out with a screwdriver, yes?
The rear light and turn signal assembly are bone dry. It's what I noted in a previous post (poor bumper repair) + bad gasket on antenna mount.
Mike
It could certainly be a bad seal on that as well. Water leaks are brutal.
Some cowls pry off, others have screws. You can test the drain by pouring say a tea cup of water in there...it should dribble down under the car, usually right about in the middle of the firewall area. You might even be able to see the rubber drain tube behind the engine.
