Toyota Avalon - To Buy or Not to Buy?
                    I've done quite a bit of research, test driven the Avalon XLS, and believe this is car for me.  I was curious to know if there are any prominent mechanical issues with the 2004 model. I was close to buying the Lexus 330 but decided against it based on comments regarding the transmission.  Are there any similar or notable issues with the 2004 Avalon XLS?
The $30,000 price quote seems high, in the Boston area you could do much better. Good luck with your purchase and welcome to the Avalon family.
It is a little hard to see when backing up... other than that, it is a great car.
As negative I am at points with the Avalon, it is still on the top of the list of CR large cars. Nothing comes close to this car in its category. And I am as critical as anyone. That being said, the 06 or better an 07 would be a good bet. Never buy a car the first model year and possibly the second. The higher trim models elevate the price alot, pushing this car into another category, which to me, makes it a whole nother story and deal. That being said also, it is one of the most comfortable, effecient, reliable cars on the road today. If I had to buy a new one, which I would not, I would purchase the touring model. This is all my OPINION. You have to buy one to suit your needs. I have a need for towing a small utility trailer on a weekly basis. The new cars had a capacity that is reduced compared to the previous models. I drive an 02 Avalon XL that is slightly upgraded(TokicoHP struts/Energy susp. PU bushing, Slotted Rotors, PIAA driving and FOG lights and XM stereo, and well as a 04 BMW 325ci.
Bottom Line: If you need a big family car or highway cruiser, where you don't want the fufu, and you don't need to tow, this is a very excellent choice.
abfisch
Change the timing belt and have a mechanic check the car, then do it. The thing you will most likely not like is the auto temp AC control. And check the front struts for wear as they are the weak points on an otherwise good car. Also check the battery cables and the battery terminals for corrosion buildup.
Buy it right.... and enjoy it.
abfisch
If I hadn't known the company and the individual driving it, I probably wouldn't have. It was religiously maintained with oil changes every 3k miles and mostly highway miles. They just put a new set of tires on it and we agreed upon $1500. They said it has started to run hot (about 3/4 up the gauge) when in stop and go traffic and when the ambient temperature is high. I drove it yesterday, and couldn't get it about the 1/2 gauge.
My question is, has anyone had any experience with this situation on a high mileage Avalon. I haven't taken possession yet, but can only think of changing thermostat, water pump, and flushing out radiator.
Any and all input is greatly appreciated! johnms
abfisch
abfisch
I recently came across an 1999 Avalon XLS for sale that had low mileage - 90K miles. I had the car inspected by Toyota dealership for a pre-buy checkup. The following is what they reported to me.
1. The front and rear brakes need to be replaced. The rotors are warped and brake pads almost half gone.
2. The timing belt is likely to be done.
3. The fan belt is a bit frayed and should also be replaced.
4. The transmission fluid is slight dirty.
5. The valve cover gasket and engine seals show signs of leak.
6. The original battery is gone and replaced with a wrong sized battery and does not have a holding clamp.
7. The rear wheel has one lug nut missing.
8. The spark plugs need to be replaced along with the wires as they looked frayed.
I spoke to the Toyota dealership regarding the cost of repairing the aforementioned list. They quoted me $2500. I am wondering if it is worth getting this vehicle even if I spend that much amount to repair it. I would have spent about 9-10K including repairs.
My concern is the quality of vehicle, the way it was maintained. However, if people feel it could be rescued, then I would like to consider it. I love the way Avalon drives.
sincerely,
ramesh
Roland
Anticipatin'
The best protection is still to park the car a little further away and hope that no one will park next to you.
Mine came with factory installed moldings,but I was told by my dealer that they can be installed on site as well. I assume that the procedure they use must be similar as at the factory.
