Chrysler Pacifica Suspension Problems
Our Pacifica has 8500 mi. Since service at 6K, we have had a noise (pop and/or clunk) in the front end somewhere. We have had it in 2 times, and techs have heard but cannot isolate. They think rust from the stabilizers getting into some gasket is the culprit. Sound occurs just after hitting brake or slowing. Any TSB's anyone knows of?
Now about that stalling problem. Ecicero1 stated that it was a problem with the "turbo drive"? I know that my Pacifica did not come with a turbo so what is the turbo drive.
I do really wish it had a flux capacitor with a dilithium crystal matrix for power since the fuel mileage still sucks. It should have had a bigger engine but not for lack of power. The bigger engine would work less around town and not need to stay at such high revs. A small V8 would have done it or a supercharger.
Attention to detail is still a problem with these guys at Chrysler. The dealer body shop had to buff off the "wet sanding" agent after I returned it too them, again. I still need to give it back to them because they did not get the passenger rear door skin mounted properly and there in now a 1/4" gap between the skin and the glass. Crazy how little they care about their quality of work.
I will not fault my mechanic though since he has been very interested in the Pacifica and getting it fixed right.
I really need to know about that stalling problem though since this is my wife's car and she has the kids with her almost all the time. Safety was the reason we bought this car. Stalling in traffic is not a safe thing. It has only happened to me once but that is enough.
did you have a clanking noise from the front end when driving? or are you talking the clank from the transmission when going from drive to reverse or vice versa?
We keep getting a 4 door Sebring for a loaner so other than the inconvenience of having to bring it too them and move 2 car seats each time, it's not that bad. I just want it to go 1 month without problems.
Are you having the same noise?
double-clunk like a loose shock or sway bar-dealer has replaced rack and pinion, removed sway bar links-checked with electronic noise pickups, etc. etc.- still can not solve problem after 4 tips @ 10 days total in service
my pac is the AWD version but still has the rattling noise. (to describe the sound = it sounds to me like someone put a heavy solid metal ball in a padded wooden box and shakes it) a muffled sound like that ... I hear it only when going over small to med bumps (a lot in succession) ...
good chatting with you and thanks so much for your perseverance in tracking the source of the problem down... saved having me drive a loaner vehicle for 10 days :-) while they tried all the stuff you got done.
aviate
I too am experiencing a noise from the front of the vehicle. Noise is predominant when traveling at a speed of less than 30 miles per hour or when turning. The service department also hears the noise but after 8 attempts to fix....the problem still remains. The following have been replaced...left and right sway bar links (have been replaced twice), Right front Strut, Rubber gasket from Technical Service Bulletin in September, Engine Cradle, and rack-n-pinion steering system.....
It did not fix my problem. still have a lose rattle in the front like the shock is lose going at medium speeds over bumps.
but after trying this fix and the TSB before that changed the antisway bushings. I give up trying to fix it and live with the rattle. Its annoying but after 3 years going trade in anyways. I try and get a new car every three years anyway. sorry to say but it wont be another Chrysler. Back to Japanese (Honda/Toyota) for me...
oh again: does anyone have the exact part number from your invoice that shows what module I need to have daytime running lights?
also how much if you had to pay for the module
Phil
So, now what? I assume when you mentioned the transfer case, Commofficer, you meant the AWD transfer case. My car is FWD, so I don't have one! Help!
Sounds like the same thing we had- they replaced the break pads but that did ntohing- they have no idea what to do and are waiting to hear from CHry. Round 6 at the dealership in 2 months begins tomm. I am driving rentals more than I am driving my pac.
My 2 year old calls it mommy's clunky car. Otherwise love the car.
my went bad @ 10000miles =/-
it clunked only when starting after long parking o/nite !
I too have a 'clunky' front end, actually mine was more like a thumping noise. The dealer has replaced the sway bar links (there is a tsb for this) and the transfer unit (tsb for this as well), That solved the thumping noise but not the popping noise that I also have. The dealer says the popping is caused by the lower control arm. That part is currently on order for us. We shall see!
Thanks for your advice on the clunking noise. I took the car in today and they replaced the sway bar links; so far, so good -- no clunks on the way home at least. Service guy thinks it's probably 50/50 that the sway bars are the main culprit -- he was kind of stumped by the noise. So we will see!
Also are you sure they "tightened bolts on Lower Control Arm" ?! They were supposed to be tighten at the factory ... I never heard such a thing !
I always thought that it sounded like a loose SHOCK bushing (both front and rear wheels). You are the 1st one to mention the word "shocks".
The TSB 02-007-04 (Lower Control Arm bushings) applies to Pacs built before September 28, 2004, so it doesn't apply to my Pac (built Jan 13, 2005). Also TSB 02-001-05 (Front Sway Bar Links) applies to Pacs built before August 15, 2003, so doesn't apply to my Pac.
I sent a letter to the Cyrville Chrysler dealership in Ottawa, Canada, asking them to bug Chrysler to find out why an American luxury car suspension reminds me the cars built 20 yrs ago in the Communist Eastern Europe, where I was born. Damn ... I forgot to add this analogy ...
I also asked them to find the problem before touching my car (I am really jealous about somebody touching my car). I test drove one of their brand new Pacificas on the lot, and it had exactly the same muffled rattle noise. They better experiment first with their own car, then touch mine.
Sometimes I think we will have to live with this rattle as being a Pacifica "feature". If you drive it everyday, all the time, you could stop noticing it. My problem is that I switch cars. So during the week I drive my rattle free 2001 Honda Accord, and during the weekend I drive my wife's 2005 Pacifica, so I suddenly notice the change (rattle). I agree it's muffled.
Here is the link to look up all the TSBs: link title
Service Bulletin Num : 0200403 is the one I just had done. Feb 2005 was the posting date on the TSB.
Good luck ... hope they will do the TSB for you even if it doesn't apply. if that is the sound you are hearing
Cluelesspa, what ... what ... what did you say ? Was it a new "TSB on the front suspension that was put out on this issue about 2 months ago" ??? Can you please copy it and paste it here ? Or at least give me the TSB number ?
When I picked the car up, I was now experiencing a new squealing noise when turning right and left. This squeal was like if you walked on a wood board that squealed. I knew I had to bring the car in the following week as there were other repairs that needed to be done and parts were on order.
When I brought the car back last week, I took the foreman out with me on a test drive. He said there were two problems going on with the front suspension. They ended up replacing the power transfer unit per a TSB. As for the squeal, they traced that to the front struts jounce bumpers. They replaced both bumpers and said it was ok. Well it is not. I picked up the car and the popping noise is still there. Does anyone have any suggestions or TSB numbers that I can reference when I go back to the dealership?
As for the rear end noise. The dealership found over running clutch to be the source of the pop noise. They indicated that the assembly was low on fluid and the separation seal was leaking internally. So they replaced the seal and I am still having a popping noise.
I have noticed that I get the popping now more so when I am coming to a stop and the weight of the car lunges forward. I am at my wits end. If you have any suggestions, please let me know.
I really like the Pacifica, but the last three weeks the car has been in for the above problems, the breaks squealing, the memory 1 position not returning the mirrors back the the set position, an engine surge, the cooling fan coming on when the defrost is not on nor the AC, and the seal in the hatch handle to be replaced for the second time. This is just the list for the last three weeks. This does not include the fender flapping on all four fender wells, the serpentine belt being replaced, to miscelaneus cracking noises in the dash and other places. Oh did I mention the moulding on the A pillar arm & roof rack coming loose when it has gotten warm outside. I wonder what will happen when it hits 100' outside...
The one good thing is that with the engine surge, I now feel like I have the power in the engine that I was lacking before. When I accelerated up a hill, there would be a hesitation in the engine. Kind of like hiccups as the engine was straining to go up the hill. They performed flashed updated per TSB 18-032-04 for DTC code P0266 and now my Pac accelerates the same way as my parents Spedial Edition.
Any input or suggestion that anyone has on what some of these continuing problems could be, I would greatly appreciate it. Right now the car is at the dealership yet again and I told them I am not picking it up until they fix all the problems. Thanks for your input
Also check door edges for paint peeling. I have several areas of peeling paint.
Good luck. K
Actually I have clunks, but suspension related ! My dealership never found out why my Pac (and the other Pacs I test drove) have that clunking noise when driving at low speeds (5 - 15 mph) over minor road imperfections.
I began to loose hope I would ever have a perfectly silent suspension. It's the only complaint I have about my Pacifica.
Is it rocket science to manufacture perfect bushings ? I doubt it's something else. By the way, I got a perfect brand new headlight ! The service manager in person put it on my Pac ! What an honor !
Me, I drove four Pacificas (mine included), different ages, and all four exhibited that loose feeling.
Please let us know if they can fix yours. I am very interested.
I went on a road test with the technician and the noise happened intermittently, mostly after car warmed up. He put the car on the lift and found nothing and the dealership's 'front end specialist' came up dry as well. At least I got this on the service history in the event that it worsens or causes other problems.
Vehicle manufacture date is 11/03, so none of the TSBs regarding the front end apply. They did, however, lubricate the bushing under warranty, so I got about $1250 worth of work for free (including a rental car for two days).
If there is one lesson I took away from this experience it was to approach them with information (i.e., specific TSBs) and to be rational, not ranting, when talking about the problem.
CUSTOMER STATES THAT STEERING MAKING A NOISE: LEAKING and MAKING NOISE- Replaced Rack and Pinion, test OK
CUSTOMER STATES A KNOCKING NOISE GOING OVER BUMPS: NOISY- Replaced Lower Control Arms and Links, test OK.
Customer STATES AIR CONDITIONER BLOWING WARM: Low on Coolant- Evacuate and Recharge, TEST OK
RENTAL CAR N/C
This repair seems to have corrected the noise and loose steering feeling at 7468 miles on my 2005 Pacifica we took delivery of in November 2004. Your mileage and repairs may vary. Just to keep you posted. Good luck with yours.
Mike :sick:
Ray
Ray
I have had my 2005 Pacifica for 1 month and it is in the shop today for the clicking/knocking noise. I am devastated to read about all the problems with this car!! Would you mind briefly telling me the history on your Pacifica which led Chrysler to take it back? I am ready to turn mine in already after just reading about all the problems!! I just got rid of a car because of all it's noises and problems so I can't bear to think that my BRAND NEW CAR will give me the same problems.
Thanks!!!
Lauren Camardo
Happy owners are too busy driving to their vacation spot this summer to email the "i'm happy" message.
Since your car is brand new, take the loaner they give you and go! I received an almost new Dodge Durango for my loaner , got to keep it for the weekend, and just hauled some stuff around with it..............
Anyone have a similar problem???
Must have been a heck of a party that quarter....
I am in the middle of trading my beautiful magnesium 2005 pac out :lemon: for another b/c of all of the annoying things that have gone wrong. But I am... buying another, but with a mfg date later than Sept 04.
Good Luck with your front end.
My 2005 Pac is being :lemon: 'd b/c I have had it in shop quite a bit, I have had my car 45 days, see post 1251. I can not fault the dealership, it came out of the factory this way. My pac is beautiful in and out, it is just mechanically a bit, well testy... I am actually getting another one to replace this one. It will have a build date of later than Sept 04. I have visited may Pac forums to help me find out what to do. I have read many many happy replies... with everything... there is always a few things that can go wrong... Don't be discourage... This Knocking, clicking problem is common from what I can see, and the TSB on it was 02-11-04 for the Power Transfer Unit. Mine was fixed, and did not have any more issues with that, my next straw was the tran cooling lines on the 4th of July.
Good LUck with yours... once that fix is done, you should be golden - I hope... Brandy
Sorry to hear about your 05 PAC. I need to buy a new car in the near future and the PAC was one of the cars on the list for consideration. Is just to bad because it is the right size for a family car.
Kev
Thanks for the information, oddly enough I JUST got my vehicle back today and the CLUNK came with it. I just don't understand it? They've replaced sway bars, crow bars, mars bars along with other things and it's just not right.
I have contacted Chrysler concerning this and explained to them my situation and my interest in them repurchasing my vehicle. I signed the arbitration postcard that was in the manual and mailed it in. The rep told me that I should be receiving further materials from Chrysler concerning this.
As you mentioned, I am going to print a copy of your posting along with many others to show chrysler that this is a GLOBAL issue and non-weather dependent! Unfortunately, I will hate the see the Pacifica go (if that happens), but I just don't have time to spend chasing issues and enjoying the luxury of having a different rental car all the time (geesh.. wonder what the neighbors think?). I have already begun my search for a very very very reliable vehicle.
I narrowed my choice down to three: VW Toureg V-8, Infiniti QX56, Lexus GX470 After doing research on these models and test driving them, it looks as if I am going to lean towards the Lexus. It has raving reviews on the forums and very little information concerning problems and solutions (look at the edmunds forum and there's just a handful of people posting to the "Problems and Solutions" section for the Lexus).
Well.. at this point, my fate lies in the hands of Chrysler, so I will keep you all posted concerning the outcome.
