Chevrolet Cobalt: Climate Control/AC
I'm considering buying a new 2007 Cobalt. I rented one recently and liked the car. One thing I noticed is the A/C is somewhat anemic, and the fan speed doesn't seem too powerfull even on high. I didn't notice if there was a Maximum A/C button setting.
Anyone else notice this with their Cobalts?
Thanks for the update. The 2006 Cobalt sales brochure shows the middle button activates the rear glass defogger and the far right button engaging/disengaging cabin air recirculation. I guess that's wrong.
Is there something special? :mad: Time delay?
She bought the car new from a Chevy dealer. She said no one has ever serviced the air conditioning system prior to its failure.
I changed the compressor for her, and there was about 2 ounces of oil in the old compressor. I thought this was causing the problem and led to the compressor failure. I evacuated the system and charged it with three and a half 12 ounce cans of r-134a refrigerant.
With an ambient temperature of 93 degrees and the engine running at 2000 rpm's, the the pressure fluctuated quickly. The compressor would cycle off and on again every few seconds. The low side had a pressure from about 45 to 60 pounds, and the high side had a pressure jumping from about 90 pounds to 450 pounds.
It is obvious to me there is an obstruction. But, it seems that the obstruction could only be in the expansion valve.
My question is:
Is the expansion valve the problem.
Is the problem something else? If so what?
The quantity of oil in the new compressor needs to be verified.
The system needs to be evacuated.
The system needs to have 0.9 lb (14.4 oz) of R134a as a full charge. You put in 3 times the amount.
Because of the compressor failure, a qualified tech should know if some kind of filter needs to be put into the system to catch particles from a compressor depending on how it broke up. A particle may have partly blocked the expansion valve. But hte system is so overcharged it would be hard to tell.
