Can you help me? I have a 2002 Safari with the same vent issue. Would you kindly send me the instructions and the diagram to fix it?
Thank you so much!
Donald e-mail me... dwlj_dj@yahoo.com
Sorry for the delay in responding. I have been out of town and completely forgot to respond. Could you post your email address so I can email you the vacuum diagram? I will post the explanation on how to fix the problem below, but I am not sure how to send attachments through the forum.
I have the vacuum Diagram for a 97' Chevy Astro and from what I understand it should be the same for all the upper model astros/GMC Safaris. If you are having the air come out from the defrost and not from the vents, you should check 3 critical areas. So I will try to explain it to you as best as I can. So if you are standing in front of the Astro and open the hood, you would look to your left hand side first. There is a big black box like thing all the way to the left (and that is the ac blower fan). Right beside that, there is a medium size silver canister that should have tubes coming out from it. That is the AC condenser and that is where you would recharge Freon to the car. Right next to the canister (on the right side, tucked in a little) you should find some sort of a t-connector with three vacuum hoses connected to it, Once should be going into the firewall (the wall of the car going into the vehicle, one should be going down towards the bottom of the car, and the other should be going to the right. Most likely, the one going to the right is the one that is broken. That one passes to the right by the alternator and other things on its way to the engine manifold where it connects in. That area is extremely hot (when the car is on) and that is why those vacuum lines tend to break down quickly (Thank Chevy for their stupid designs, LOL). It may take some bending and moving with your hand to get into those tight spaces to reach the other end of the vacuum hose. They sell replacement vacuum hose/tubing at Napa Auto Parts by the foot, and they have vacuum connector heads in multi-packs at Auto Zone. Basically, you will have to build your own new vacuum tube with a head on each end, one to connect into the t-connector and one to connect on the engine manifold. I would make the tube a bit longer so you can position it away from the hotter parts of the car and you can use plastic strapping ties to secure it so that it doesn't get caught in any gears belts, etc.
That should solve the problem. If it doesn't, I would check the second line from the t-connector going down to the bottom of the car. That line connects into the vacuum ball underneath the car. The vaccum ball is located underneath the car by the right front tire (in the same area as directly underneath the condenser. So you would have to get on the ground and slide underneath the car (Head first) and look with a flashlight underneath the front and you will find the vacuum ball. It is a round plastic ball thing and it should have a vacuum line connected to it. Check the line and also check the ball for any cracks, etc. If the line is bad, change the line and then if the ball is bad, you can get a new one from the dealer and I also think AutoZone has them (Check their website). The ball clips on with two clips/screws to the metal of the car and you would have to pull away the plastic flap of the wheel wall to see those two screws. On the Diagram, the areas that I mentioned are numbers 11. 12, 16, 34. Try that out and you have any questions, just email message me back.
Well, I would assume that your issue of the air coming out of the defrost in the back is related to the vacuum lines in the front, but I am not sure as I do not have any experience working with the Astro's back AC as my Astro does not have rear AC (I wish it did, LOL). BUT, since you've stated that you can hear vacuum in the front, then that leads me to believe that you are having a vaccuum leak in the front because you should never hear the vacuum sound unless your lines are broken or cracked. I will post my explanation on how to fix it from the front, and maybe that will help (And I think it should because you are hearing the vacuum in the front and shouldn't be). Please post your email address and I will send you the vacuum diagram.
I decided that I would post my email address on here for future posters to see. Many people have come on here requesting help with the Chevy Astro Vacuum Problem, and I am always ready to help everyone. However, I am not on the forum too much, but the way that I respond is that Edmunds usually sends me an email notification when someone posts in the forum. I just logged in and noticed that there have been a few posts where I didn't get a notification about the posts. So, I will post my email address below and if you need help, instructions, and/or the vacuum diagram, just send me an email and I will be glad to help. I know how horrible and irritating this problem is (especially in the height of the summer and winter seasons) and there is no reason to suffer with it as it can easily be fixed!
Take Care,
BDar
adarwish69@bellsouth.net
Thanks Bob
bdar, if you read this, I have watched you ask for vacuum diagrams, but the only one I had was for my old '92 GMC, which I think I got from you. I wasn't just leaving you hangin buddy!!
This is what you need to check.
When you have the hood open and you are looking at the engine, to the left is the plastic windshield and overflow reservoir. You will need to remove it, take the overflow hose off the radiator that goes to the reservoir, take the two screws out and when you are lifting the reservoir out, be careful because the washer fluid pump is on the front of the reservoir. You can take the pump out of the reservoir and then remove the reservoir. Behind where the reservoir was, you will see a cable plugged into a socket which this will be the blower motor resister. There may be a strip of plastic that you will need to pull and then you will need to take the cable out of the socket. Look inside the socket and on the right side of the socket may be burnt. If not, this is a good sign that the blower motor resister is the problem. There will be two screws holding the blower motor resister and there will be a cable running from the blower motor resister going to the blower motor to the left. You will have to unplug it from the blower motor. You can go to any parts store and pick it up for about $40-60. The blower motor resister will look different than the one you take out but it will be the replacement for it. You may have to modify the opening to make it fit. I had to file the top and bottom of the hole to make the blower motor resister to fit. Put it back in reverse of what you just did to take it out. This does not take very long to do, I believe it may take you about one hour to do if you have the basic tools. I hope that this will solve your high end not working and you will be able to enjoy the ac/heat once again. If you still have problems, write me back and I will do my best to help. If I do not have the answer, I will research it and try to find one. Knowledge is all about sharing it and pay it forward.
Donald
This topic has gotten a bit extensive and so I am not sure who originally had the problem and who was replying to help with it. So, to the forum member who asked the question/has the problem, this problem is with the fan's blower motor and it is specificaly the resistor setup on the motor. Post #s315 and 314 do a very good job of detailing what you need to do to fix this problem. In the past, I have had this problem with my 97 Chevy Astro, but I had it in the repair shop for other issues (nothing related to the AC) and so the shop had fixed it for me (it was actually at the Chevy Dealership) and they replaced both the resistor array and the blower motor. I would have done the repair myself, but I was traveling at the time and so I had to get it fixed ASAP because I couldn't drive around with not being able to have the AC on Hi.
However, I had this problem another time, and when it happened again, it was the actual key for the fan that had gone bad. The key is the one that you use to turn it from low to hi. I guess over the years the panel had gotten worn out from changing the setting so much, and the internal metal pieces of the key went bad, so when you set it to hi, there was no contact inside the key and so the blower wouldn't go to hi. I ended up changing the selector panel (Basically all three keys) and the HI setting was working again. I don't know how often that has happened to others, but usually went ot won't go to hi, it is either the resistors or the selector key itself. Wish I could offer more info but that's all the experience I've had with that problem. Good Luck!
BDar
Also, the air from my heater is not as hot as it used to be.
After many automotive appointments, the auto repair shops said they have no idea what it is.
A friend of mine said the engine could be old/worn and not creating the pressure needed (not sure if this is true).
I flushed-out my heater core a few different times and it seems to have helped my air get hotter when my heater is on.
would really appreciate it thanks so much it seems like we are having same problem ac works fine but air coming out of the defrost vent
Can you email me a copy of the vacuum system that you have for the GMC 2000 Safari? jjrudy65@aol.com
If you could please send me that diagram for the 97 Safari/Astro vacuum tube routing I would greatly appreciate it.
Tim
Miekym2@yahoo.com
Hope someone can give me some help on this issue and maybe someone has a vacuum diagram they could email me.
I do see a broken vacuum line as you describe but where is it connected too??
Their is a couple lines coming through the fire wall and the broken one is attached to like a 90 degree ell but where is the other end???
Can you give me a little more info on what I am feeling around for?
A pic would be great.
If you know how to remove the engine cover, you'll have better access to the manifold. The manifold is right on top of the valve cover. If it is broken off, it's a little tough to see it. Just keep looking for a black vaccume that has one hose coming from the valve cover about 1/2" into the unit. The other side has the fitting. Be very careful taking off the hose, you don't want to break off that fitting. I took the fitting off and cleaned out the broken part. I then used a small piece of hard tubbing and joined it with the tubing I bought at the auto store. I bought about 6" more then I needed so I could move the line away from the heat.
The other way. If you can reach the air cleaner screw, remove the air cleaner assembly. Look for the aluminum tube running in front of the vlave cover. Right behind that you'll see the vaccume. The line has a right angle on it. If you can pop off the vaccume line, you will be able to repair the line. I used a section of the hard vaccume line as a coupler. it worked just fine. I hope this helps. I know I had a difficult time becuse I did not know where the vaccume was located. Once I found it, It took about 10 minutes to fix it. The car is blowing through all vents in all settings.
One other note. I did have to change out the resistor located in the blower housing. The number one plug was burned up. I figured the vaccume line failed which caused the resistor to overheat. That was a $65 part. Not to difficult to change and located behind the wiper and coolent tanks. Just pry the plastic plugs up from the top. You'll see a small groove. The black plug comes all the way out and just lift out the tanks after making a few disconnections. Remove the two screws holding the hoses, then the two screws holding the resistor. You just have to disconnect the wire on the left. It resistor will comes right out after taking off the two screws.
I've searched all the threads..seen some reference to rear heater not blowing hot....but found no solutions.
Symptoms:
Rear heater and AC blowers\speeds work fine, heater does not blow hot and AC does not blow cold. Front heat is all good on speeds and functions, etc.
Any suggestions on how to troubleshoot and fix rear heat problem would be appreciated.
Cheers
I have a 96 chevy astro van that has a climate control without a/c. The interior knob broke off
so I went and got a replacement controller, but it also has an a/c turn on it. I got it installed but
it is not working. Do I have to get a climate control without the ac attachment or should it still work. Any advice would be great. Going to take apart and give it another shot. Thanks
I posted a query back in November about the rear heater blowing air fine on all speeds, but the air is cold. I flushed the rear heater core, but still just cold air. Would there be a vacuum-controlled valve that regulates the ratio of hot coolant to the rear core somewhere?? Any info or ideas would be greatly appreciated.
Cheers
So I disconnected the two hoses and connected them directly with a 90 degree 5/32 connector. I now have hot coolant going to the rear heater core all the time which can be regulated with the rear heater fan switch. Van is a 97 GMC Safari AWD, but I believe this would work for all model years.
Cheers
My email is rwideloc@hotmail.com
A vacuum hose diagram would be most helpful!
Ed
Have been away from the Forum for a while and I do apologize for not being able to help everyone. Have created a link on my site with all the Chevy Astro Vacuum Line Info and Vacuum Diagram. Do check it out and feel free to email me at adarwish69@bellsouth.net if you have any questions.
www.basemdarwish.com/Astrov.htm
Take Care,
Basem D.
Thanks again,
Ed
Well, when I pulled the fitting off the throttle body, the small tube disintegrated in my hand! So, I got a piece of 5/32" vacuum hose and replaced the small one with that, and now have functional AC/heat controls!
