Chrysler Sebring Warning Lights and Problem Codes
124»
    larry271larry271 Member Posts: 1
    i have the same problem with my 2010 sebring and the dealer is saying it is a senor under the dash and it will cost 280.00 to fix
    akadienakadien Member Posts: 1
    I HAVE A CHRYSLER SEBRING 07 WITH A 2.7L AND 41TE TRANSMISSION, I HAVE CODE P0765 UD SOLENOID CIRCUIT , CHECK AND THE SOLENOIDE PACK AND RESISTANCE FOR THE FOUR SOLENOID IS 1.7 OHMS AND THE PRESSURE SWITCH 300 OHMS, SO I TAKE THE WIRRING OUT AND CHECK IT FIND NOTHING BAD WITH IT , SO AFTER THAT DECIDE TO CHANGE THE SOLENOID PACK ON IT , SAME PROBLEM , ON THE SCANNER MY TEMP FOR THE TRANSMISSION STAY AT -19.4 , SO WITH THE SCANNER ON A UNPLUG THE TRANSMISSION RANGE SENSOR THAT THE TEMPS SENSOR IS IN IT AND NO CHANGE STILL -19.4 , AFTER THAT I DECIDE TO GO A THE JUNK YARD AND BUY A USE PCM , PUT THE PCM IT IN GOT THE SAME PROBLEM NOTHING CHANGE , DO SOME BUDDY HAVE AND IDEA WHAT IS THE PROBLEM????
