Cadillac CTS/CTS-V Tires and Wheels
The original Goodyears on my 3.6 2004 CTS are about ready for replacement at 23,000 miles. I was very happy with the Yokohama Avids I had on my wife's Buick. They looked almost new after about 25,000 miles so I'm considering them for the CTS. I've heard the only tire that "looks right" on the car is the Goodyear. I want a quiet ride and performance capability as well. Anyone riding on Avids? Happy with some other brand? Appreciate any response.
Check my past posts/replies on tires for the CTS. I am very happy with the replacement tires on my '03 CTS - they are not Goodyear.
Before replacing the second time I had the Cadillac Dealer do an alignment on the car to current spec's. They are close but not dead nuts. They won't tell me what the allowable tolerance is. They won't realign and reset it closer. They say it is closed enough. So who buys the next set of tires? Cadillac Customer Service says it should be realined at no cost to me. Dealer is refusing. This could get interesting.
The Avid V is a performance rated tire so you can enjoy the power and handling of your CTS as I certainly do...
all service departments are not alike.......so no...dealerships dont necessarily know what they are doing either....
I don't feel that the rest of the tires are holding up very well the car seems very low so I probably be back at the dealership again!
I have a 2008 CTS with 1200 miles and I experience a vibration from 40 through 65 MPH, it is worse when on an incline (slight or steep) it is worse at 40-42 MPH. Vehicle also vibrates in reverse when backing out of my garage (slight downward slope) with basically no accelerator applied.
Anyone having this problem please reply.
Cj
Im betting that will solve your problem....not all tire shops or dealers have this machine...
Please post the bulletin # you wrote of in item # 31. I'm having vibration and rumbling noises at speeds between 40-65 MPH. Dealer want's me to let the tires run in for 7-8,000 miles. The vibration is worse at 42-43 MPH and in a slight pull or trying to maintain that speed straight and level.
Help!
Cj
I had the same issue as you are describing. Totally resolved after applying this TSB by my dealer. There is a warning with the TSB that the mpg may go down. Haven't noticed anything significant sofar.
It made all the difference to me. Highly recommend the solution. My CTS is once again just one great car. Wouldn't trade it for anything else.
