Ford Fusion/Mercury Milan Traction Control
Traction Control uses the ABS computer and sensors to
monitor wheel slippage at any speed. It helps improve traction
on slippery or loose driving surfaces by using engine controls
to reduce the amount of torque being sent to the drive wheels.
Engine controls are:
• Fuel injection cutoff
• Ignition spark retard
Traction Control helps provide a confident driving experience
under adverse road conditions — improving vehicle traction
and steering control — without sacrificing dry pavement
performance:
• When the lane is slippery on one or both sides
• As the vehicle pulls out from icy parking lots or
highway shoulders
• During acceleration when cornering
Mark
performance:
highway shoulders
Mark
More sophisticated TC, widely available even in the Fusion's competition, breaks the spinning wheels before throttling power.
Not quite. Ford's new system, which is in the Fusion, uses the vehicle's PCM to control traction wheras the "cheap" systems you are referring to use a separate sensor and/or processor which can be slow and annoying to live with.
This link is the only one I could find quickly that goes into it but I have read others like it. One was on Edmunds IIRC. Scroll about half way down to read it or just read the quote below.
"May 30, 2006
Ford's New Traction Control System Among the Best Performers
DEARBORN, MI – Ford Motor Company began rolling out its patented traction control system last year as an option on the 2006 F-150, Ford Fusion, Mercury Milan, and as standard on the Lincoln Zephyr and 4x2 Lincoln Mark LT. The innovative traction control system, among the best performing systems on the road, works by momentarily decreasing engine power to help regain traction at the tires.
The system is particularly helpful while accelerating on a slippery surface. Using signals from the vehicle’s anti-lock brakes, a computer algorithm — embedded in the Powertrain Control Module — detects if the drive wheels are slipping. Then, within milliseconds, the system adjusts the engine power to allow the tires to regain traction. The system is unique in that it was developed to operate using the vehicle’s engine computer processor, rather than a standalone module."
An Audi A3, which uses Haldex and wheel braking, can plow through 10 inches of snow without breathing hard (so say a couple of reviews). But in that vehicle, you get a mandantory sports suspension and lo pro tires; good handling, lousy ride.
Sometimes raction control varies on the model itself. The Malibu, for example, has the engine power only version, but its SS variants get engine power and brake application version. Of course, none of these have AWD.
I have to agree with the others. Show me where Ford's new system is worse than one with the additional braking mechanism. You're trying to compare their new quicker reacting system to an older, slower system which isn't really fair.
If the only reason some other manufacturers add the braking mech is to back-up the power cut system then doesn't it stand to reason that a better power cut system will be just as effective if not better? Plus, having only one system reduces complexity and cost.
The TC that retards ignition does so for longer than necessary. Whereas the TC that breaks only the wheel spinning can allow a wheel with traction to pull with full power. That's a major difference whose advantage should be quite clear to anyone.
I think the point some of us are missing is that the Ford system is new and unique. If you haven't driven a vehicle with it then you can't compare it to an older system from another manufacturer. Everything offered here so far has just been speculation and mis-information. I own two vehicles with the new Ford system but have never driven, to the best of my knowledge anyway, one with the dual system. Therefore I will not praise one and bash another.
I don't see anything happening other than power being shifted to the wheels
that have traction. Maybe if all the wheels lose traction?
But yes - it's plenty of power.
Traction Control System — All Wheel Drive (AWD)
The ABS module [ The 4WD control module also provides the brake system with its current clutch duty cycle and whether or not the brake system may take command of the clutch duty cycle ] communicates with the powertrain control module (PCM) to assist with traction control. When the drive wheels lose traction and begin to spin, with vehicle speed under 100 km/h (62 mph), the ABS module requests the PCM to reduce engine torque while simultaneously applying and releasing the appropriate brake caliper(s) to maintain traction. The PCM accomplishes this by minor incremental timing changes and fewer fuel injector pulses until the ABS module ends the request. The request ends when the driven wheel speed returns to the desired speed. After the vehicle speed exceeds 100 km/h (62 mph), the traction control is accomplished only through the PCM torque control. The traction control system can be disabled by pressing the traction control switch and is indicated by the traction control light in the instrument cluster. The traction control system will reset and return to normal operation when the ignition switch is cycled, or when the traction control switch is pressed and released a second time during the same ignition cycle.
Now the reason I am posting. I have the 2010 Fusion Sport, not the AWD version, the FWD version, and we just had a major snow storm here, at least 2" fell in under an hour from the time I got in my car to the time I got home, and the traction control on this car is great, it reduces power, not cuts it, and it applies braking as needed. The car comes stock with goodyear tires which have not had good reviews, and I was skeptical that they would have any traction in snow, but they actually have very good traction. The roads this morning were ice, not just icy, but layers of ice, and when the tires couldnt bite, the TC pulled it through with hardly any effort. The Ford system on the Fusion to me so far has been the best TC system I have had on a car, much better than what Toyota has.
