Acura CL Tires and Wheels
They're quieter, cheaper, better handling.
Any particular model? What's on your car?
On my Impala, I immediately chucked the Goodyears that came with it for some Yokohama AVS dB's. They're Z-rated Ultra Performace tires that are also ultra quiet, which is usually a contradiction. However, the tread life ain't too high, maybe 24-36K miles, if you're lucky. Yokohama has some nice Super Touring tires called Avids, that are even cheaper and get around double the tread life.
Take care.
Joe W.
Those of you on 'Premiums' with 16s, does it seem quieter than a Type-S?
thanks,vinny
I wouldn't quite call this group "active"! ;-)) Every so often it rises from the dead when I post that my 2001 CL-S is the best car I have ever owned! Then, I get "blasted" because I also forget to say that I have about 18 coats of Zaino on it too! http://www.zainobros.com
My car is 15 months old. 15,500+ miles and not ONE problem! Overdue now for oil/filter change and another tire rotation/balance. Compared to the 99 "Motor Trend Car of the Year" (Chrysler 300M) that I owned before this car, I feel like I died and went to Acura heaven! LOL....
Not much snow here this winter in So. CT- 4 inches- but the car was fine. No problems in rain either. Plenty of that lately. Grips the road like a mountain lion!
For an ACTIVE CL group- go here http://www.acura-cl.com VERY active and very helpful.
fastdriver
who have had to do it? thanks.
Has anyone replaced their 17" CL-S tires with a 225-50, instead of a 215-50? I'm interested in the Pilot Sport-AS, but it doesn't come in 215 size.
The 225's are .3 inches wider at the tread, and .3 taller from the axle. But optimum rim width matches the 7" rims on the type-s, so I'm guessing that handling should remain as good as the tire. I'm going to try them... if clearance is a problem, I'll go back to the originals.
I too am looking to soon replace my tires and was told by several people to maintain the correct sizes. I have found a tire that seems to get outstanding reviews, and costs 1/2 the price of the stock tires. They are Sumitomo tires at the tire rack. www.tirerack.com Please check it out and give us your opinion. Thanks, Lee in Miami FLA.
01 CL-S 39,902miles.
According to several Acura dealers (service dept's) they know this is a problem on this model. Acura's position is, they will cover the brake job under warranty if you have less than 50% wear on the pads. I had 60% wear, but with enough squalking, I got them to concess the job entirely for customer satisfaction. You should be able to do the same.
Would love to hear your opinion of the Sumitomos. I got a good deal on the Michelin Pilot Sport-AS... but still expensive. The 225-50-17 fits great in that tire. Not true for all 225's.
Be very careful when installing oversize tires, even by one size, the speedo, cruise and all speed/mileage related items are calibrated to this exact diameter tire. Changing or altering this deminsion will cause the readouts to all go out of calibration.
Do you use Synthetic Oil?? It is the best thing I ever did, Lee in Miami look at www.amsoil.com
There is a definite improvement in wet traction... the original tires would spin and hydroplane easily after approx 50% wear. And FORGET any snow traction with the originals. I didn't get them in time to test snow traction, but written reports are good. These tires do have a different feel to them... and an almost "oversensitive" reaction to minute movements of the steering wheel. (maybe I was just used to crappy tires?) I haven't really pushed them hard in any corners yet, but have started to on highway ramps and the few curvy roads I drive... I'm still learning their feel, but am definitely impressed so far. Road noise is different, but good on most surfaces. Ride comfort is fair... new tread obviously better than worn tires. You can't expect too much ride improvement on a W-rated tire.
The CL-S is very competent in almost all respects, and my only other complaints are the grabby clutch and the hopelessly bland styling.
Also... if you were referring to my Civic Si comments (did I even mention that here?), you should try driving one. It may be a homely little hatchback, but it handled pretty darn well.
First they look really agressive. The tread pattern is gigantic compared to the MX4. The ride is VERY smooth, but you can still maintain feel of the road. At 100 mph, smooth with a firm road grip. Cornering was agressive but again firm. I was truly leery of tires for so much less than all the other brands. However I am convinced that quality can be had for a reasonable price. The tires are the Sumitomo HTR+. Warrantees apply too. Check them out at www.tirerack.com, Lee in Miami
Now after many months of vibration they seem to be rolling alot smoother, but not perfect.
In the meantime I did contact Tire Rack to complain and finally received 2 new tires for the front. I have to get them mounted and return the originals to be pro-rated. Now they're half worn so I won't be getting much of a refund.
The owner of the service center who originally mounted them said he's seen nothing but trouble with these tires and did not recommend buying them again. I sure won't. Maybe it was my bad luck.
I carefully read all the reviews and I dedcided that these were good tires and a great value too. I'm sorry to hear you had problems. You may also want to check the rim runout too. An out of round rim can foul up almost any balance job.
Good Luck, Lee in Miami
I live in Texas Fort Worth area, took my CLS to this place called Sam&Joes for wheel/tires rotation, they overtorqued them & even damaged one of the tires around the side wall, I also felt shimmy afterwards. Just a caution note, if anyone of you are living in Fort Worth/Dallas, stay away from them....
All the best,
AL.
I placed a message here when I bought the tires (see msg# 1546). I've driven them 9k miles since and remain impressed. They corner very well, and I feel a WORLD of difference on wet roads, compared to originals. Also, I still notice the more-sensitive steering response of these tires. One slight negative to consider - you will still have a firm ride... so if you are looking for a "softer" tire for pure comfort don't go with a W rated tire. I'm anxious to see if I like them this much after another 20k miles!
regards,
kyfdx
I've heard good things about Kumos
1st, the factory tires are CRAP in snow (and rain after 50% wear). I say that based on first-hand experience, but you will see the same if you check comparisons on tirerack.com or other tire sites.
2nd, the engine torque and throttle response, just as you go off-idle, gives way to immediate spin. The CL (not type-S) might be a little better.
3rd, there is no way to pull away from a stop in 2nd gear. The tranny will start off in that torquey 1st gear regardless of where you put the shifter. Some cars start in 2nd gear when you put the shifter in 2nd, or have a "snow" button (toyota) which disables tranny from using 1st gear. On the 6-speed you obviously won't have this issue.
I've been using the Michelin Sport AS tires for about a year now, and love them. We've had a few snows this year (2-4 inches) and they were FAR better than the originals. Same for wet driving. However, even with the great tires, my sons' old 4cyl Camry & Accord are much better.
WOW! I have a 2001 CL-S auto with the original tires and 30,000(almost) miles and we had a TON of snow in CT this winter and I had NO problem whatsoever. I'm not too sure what the yearly snowfall is in Raleigh, but if 2-4 is all you got, maybe you're just not used to driving in snow. Then again, is Raleigh the town that got hit by a "blizzard"?
I just kept mine in D and never got stuck once. Funny how different people can have extremely different situations with the same car. Then again, when I had my Motor Trend "Car of the Year 99 Chrysler 300M", I had a ton of problems while others with the same car had none. Go figure.
fastdriver
