Acura CL Care and Maintenance
Hello all. I have a 99 black 3.0 and I can't stop praising the thing to my friends. There is one thing I want to ask about: Ever since I got my windows tinted there is the smallest hint of wind noise coming through the passenger door when going over 65mph. I've taken it to the dealer and they keep saying its just the car breaking in, but that noise doesn't exist on my side. I'm sure that they just don't want to do some laborious task like changing the rubber seal which I suspect is wrong. What recourse do I have to get them to make it right? Just curious because I don't want to have to get nasty with my service guy.
I have almost 7500mi on my 99CL 2.3 Manual Black and am about to take it in for a tire rotation and "visual" inspection --am taking it elsewhere than the dealership --they wanted ~140$ vs. 40$ some place else ---- Id like to hear more comments about the first generation CLs --there is somuch about the 2001 --but on some other message board i saw a post about the 2002 CL so theyll get thiers soon too ---what sort of problems have you all run into with your CLs , if any, what are you doing, paying for maintenance.... etc..
MMAL -- you could go for a highway drive with the service manager and point out the noise
Also, I spoke to a person who has sold cars for 16 years and read a report saying that U.S. Honda/Acura products have had less problems than their Japanese counterparts. However, I don't know where he got that info.
Plus, I really need to wax my car, but it is white and I fear I won't be able to see the wax to get it completely off. Suggestions?
Obi
For skip barber I went to Lime Rock, Ct also. I am surprised they didn't let you take it on the Autocross.
The course I drove on was where you do the timed run with the Neon's and Viper's on the 2nd day.
I did a two day course and they let us drive our cars at the very end of the day.
Did you take the one day course, if so, that maybe why they didn't let you take the car out.
How did you like that skidpad with the pick-up's. That was awesome, I loved doing the power slides.
Obi,
Don't worry, you will notice the waxbecause it leaves a haze on the car when it dry's, you can't miss it.
Also, my Brother decided not to buy my CL after all so I am trading it in, Would you believe the dealer is only giving me $17,800 for the trade in ? I know the depreciation for the first year or two is hard, but I expected a little more. It's actually $500. under the wholesale book value. There reason was that Acura was giving huge discounts on them towards the end of the model year and because my car is in such great condition and the color is right, they are giving me a good number.
Originally they offered me $17,000 even, there was no way I was taking that ! ! !
Prior postings suggest amber bulbs, Platinum halogens, etc.
I believe the way to go is 55W white halogens but I'm concerned the lamp housing/reflector/and lens might not be able to take the heat and may melt/distort. Also will the wiring take the current demand for the halogens? Anyone have any first hand experience or thoughts on this?
Hal2001
I just had my 97 3.0CL in for maintenance and they changed the coolant and brake fluid. How much did they charge you? I would ask to see a revised maintenance schedule if it's changed.
Touch Up Paint and, having never touched up before, there were also very easy online instructions that made me confident I can easily do it.
It is possible (sorry don't know your exact car's configuration) that this secondary fan (if you have one) is not kicking in with the AC on (easy for you to check), or that the regular fan isn't working with the AC on---also easy for you to check.
Given that overheating can be caused by a myriad of complex issues, this is the first place to start looking.
If that checks out, come back and we'll go from there.
Mr Shiftright
Visiting Host
I have AN Acura 3.0 Cl 1997. Two years ago, I had a very tiny rust came fron the inside rear wheel well. I spent $400 to fix it. The body garage tech. told me to remove the rubber protection strips on both rear wheel wells and put in the protection clear tape on the rea wheel well lips instead to prvent from the rust comes back. He said that all Honda, Acura 3.0 CL had the rust problem on the rear wheel well s.
Now 2 years later, I have 2 more tiny rust spots on the same rear wheel well . I broughr my car back to the body shop, they said that I'd rather buy another car b/c Acura 3.0 CL has very known rust problem on the rear wheel wells. Do not waste money to fiz them since the rust come back. it is very sad to hear this.
My car is 11 years old now. almost 86K miles. The car looks so new. I had no trouble with my car b/c I maintained it very well. It goes so smoothly. It is broken my heart to get another car and not guarantee that the other car has the rusty problem or not.
CAN ANY ONE GIVE M,E AN ADVICE ON HOW TO PRVENT RUST FROM COMING BACK ON THE REAR WHEEL WELLS?.
I AM LOOKING FORWARD TO YOU GUYS' ANSWERS.
THANKS A LOT
You should take your car to a trusted auto repair shop. It saves you a lot of money. Do not go to the dealer. You should buy certified used car and have a auto. tech. to check the car before buying it. This is the reason why I will spend money to fix the rust than buy a used car.
Has anyone else had a similar problem and if so, was it a major repair? Clearly, I don't want to but a lot of money into my car as I planned to buy a new TL this fall.
FYI: This is really the only issue I have had with my car after my transmission was replaced by Acura at around 30,000 miles. It is still driving and riding fine.
I have a 02 Acura CL. When the air conditioning is put to cold i get this clicking sound. I have located the motor that is causing the problem. It is under the right hand side of the dash. Any help would be great. Thanks
