Cadillac STS/STS-V: Electrical System
                    My 99 STS Cadillac just quit with the dash lights and power windows.  I could still drive the car.  I got it home and it still started.  I continued to start but later it wouldn't.  It did not sound like a battery run down.  Anyway, I couldn't even find the battery in this car and if it isn't the battery, could someone give me an idea of what it might be.  HELLLPPPP!!!!!!
This has happened 3 times since I bought the car 2 months ago.
I've had it serviced twice so far. The first service guy who came on roadside assistance to deal with it said the car may have had a lose connection somewhere on the electricals, or maybe something was jarred loose when I drove over a bump. I've just had the 2nd adjustment at the dealership and now it feels like i don't have any shock absorbers and the car bumps up and down like crazy.
I am very unhappy with this car.
I have had 8 cadillacs devilles over the past 20 years and this is model year is a real loser.
Never buy a car from a company that is in the process of going bankrupt.
very very annoyed :mad:
Supposedly the ground is sometimes removed so that only the dealer can diagnose it.
With Cadillac mechanics charging $150/h to diagnose I would rather do it myself.
Can the terminal be grounded to any ground...or must it be to the connector ground.
The Tech 1 tool cannot be used with OBD1 Cadillacs. Another reason to own a Caddy!
Anyways, I have acquired a fault tree and hopefully can find the problem.
The code T061 for "Motor Pump Relay Fault" is present.
I'll post with more info. Anyone have any suggestions?
what needs to be remove to do so!
wouldn't touch the motor home, you got your work cut out on that one. GOOD LUCK! let me know how you make out on that
rdrags
What ever happened with your car? Did they find out what was the problem?? I have a 2001 STS that has been in twice for the very same reason. I could be doing 60 miles an hour on the Parkway and the car will completely turn off - no power steering, no brakes... or I could be idling at a light and it does the same thing. I heard some STS's were recalled because of this. HELP ! I don't want to get rearended becasue the car shuts off. Can Anyone advise me?
The fan was grounded with a piece of wire to the battery.
The information center displayed,"Cooling Fan Fault."
I used the car as is.Then the "Gear selection fault" was also displayed.
After that,the digital display slowly started to flash on and off.
Now the instrument panel is mostly off.
In the morning's it's on for awhile and everything on the panel is working.
Then the display shuts off.
The car is still running as normal but I can't read any of the functions.
The self diagnostic shows the codes:
B120-B127-B441 current
E052 History
B552 History
It is very difficult to drive the car without seeing the instrument functions.
Please help me locate the source of the problem.
You need to have the crankshaft postition sensor replaced.
