Subaru B9 Tribeca Brake Problems
I just test drove 3 different Tribecas and all of them had very soft, mushy brake pedals. The pedal would go down about 3 inches when coming to a stop. My 03 LLBean has a hard brake pedal that moves very little. Anyone care to comment about the brakes?? I want to buy the B9, but not with a brake problem. Had a 96 Outback that the pedal was similar and at times would touch the floorboard.
But it has excellent braking characteristics.It's stops are short, smooth and controlled. It just takes a little getting used to the pedal.
I found the pedal firmer than my Forester, a little less touchy than my Miata.
So in Goldilocks style, I find it "just right".
-juice
thanks,
Solomon
Anyway, check your brake fluid level as the brake light will come on when the fluid level is low, when you are depressing the brakes it may be creating enough vacum that it's tricking the light into thinking there is enough fluid.
I would doubt that you should need fluid unless you have 20k miles or more on the car, or there is a leak somewhere in the system.
-mike
The dealer said that getting 52k out of the brakes was better than average. Anyone else out there with a similar experience, get it done at the dealer, or elsewhere?
-mike
anyway just the front with turning the rotors (they would not skip turning the rotors) :-( was $140 after coupon for $50 off.
I would not suggest using engine braking to save pads. An automatic trans or clutch is ALOT more than pads.
Oh and pads provide more braking power
-mike
Pat
If it's pads only you should just need a 14mm wrench and a set of brake clamps or a U-Clamp to compress the caliper pistons, 15 min max.
If you are also doing the rotors, you'll need a 17mm wrench as well, should take 30 min max.
-mike
Motorsports and Modifications Host
I do recommend the tool that pushes the pistons back in, though. I had trouble finding a good place to put my c-clamp.
-mike
See you there!
I had the same problem. Not only that, I also hear a continuously high pitch noise (not loud but definitely audible) between two clicks (pressing to releasing the brake paddle). I was told by the dealer the clicking sound is the "characteristic" of the model (2009 Tribeca Ltd.), and the best mechanic in this dealership could not "duplicate" the high pitch noise! Also bear in mind, all these started to happen couple months after I purchase this brand new vehicle!
I am going to contact Subaru Canada or America to verify this issue. Would you mind sharing the status of your complaint?
I took it to teh dealer, but was told the clicking sound is the "characteristic" of this particular model, and the best mechanic in this dealership could not "duplicate" the high pitch noise! Bearing in mind, all these started to happen couple months after I purchase this brand new vehicle!
I am going to contact Subaru Canada or America to verify this issue. Would you mind sharing any suggestions?
