Hyundai Sonata Rear Thump
silverfox1
Member Posts: 91
Have a 06 Sonata LX. Chasing above average rear body/ chassis thumping when going over a bump or step in the pavement. Have relocated the spare and tighten the holding mount. Re adjusted the two trunk stops. Securing the spare helped but still have some thumping. Is it possible that some added padding to the trunk floor will help? Anyone have the same problem and a solution?
I have a 2006 Sonata GLS 4 cyl. I hear a slight knock or bang (I think coming from the undercarriage) often times when I first accelerate. Does anyone else have this?
Switching to a different gas station / higher octane may solve the problem... Old gas stations sometimes have storage tank problems (water/contamination...).
I always try to get Gas at the newest gas station around.
I also read, that some new 4cyl cars require Premium (i think i read that in a Civic Si review!!
If I understand you correctly the noise is coming from the rear suspension when you go over a sharp bump or step? Sounds like rear hub noise to me. Tell your dealer service that you suspect you have rear hub noise and that you may need your e-brakes adjusted. At least sitting here that may be the issue.
Hyundai road tests all cars thoroughly for noises, quality and safety issues.
The service department said everything was working to Hyundai specs (they had a "Hyundai engineer" test drive it with me and he said it was normal road noise - baloney), and the general manager said he is trying to get Hyundai to address the issue, but to no avail.
It occurs on bumps and dips usually below 30 mph. It is especially loud under 5 mph when you go over a bump or dip.
There is also a constant droning/resonating hum noise when the car hits about 30 mph and higher, which is most noticeable on concrete.
:mad:
-Keith
The latest info published, unofficially though, is that the cause of the noise is the REAR SUSPENSION, and that Hyundai is now working on a fix that's suppose to be in the shape of a RUBBER seal that needs to be added to the rear shocks. Stay tuned.
http://www.hyundai-forums.com/t12502-azera...nsion-noise.htm
Could this be the solution for the sonata's k-thunk problem too? - If they share components.
also from :
http://townhall-talk.edmunds.com/direct/view/.f0f43c4
"Well I just took my Azera out for a drive and the noise is completely gone. It was great I did not feel like I had to dodge every pavement irregularity My dealer, Green Hyundai is located in Springfield, IL. The part number for the struts are 54611-3K050 and the insulator assemblies are 54630-3K000. I hope this helps, it sure did the trick on mine. "
That URL only addresses front end clunking noises in the Azera.
NO :lemon: Pure Pleasure. The Award Winning new Hyundai Sonata. Take the Hyundai Challenge :shades:
Here is a copy of my email just sent to Hyundai Consumer Affairs. I will post any response as soon as I get one. I will be following up with a phone call.
Don
I am the owner of two(2) 2006 Hyundai vehicles purchased during the past 9 months from Hyundai of Westchester in Yonkers, NY. I own a Sonata LX (3500 miles) and an Azera Limited (1600 miles).
I am sure that you are aware of the Azera's front suspension noise and the Sonata's rear suspension noise. I am an active participant on the Hyundai-Forum's board and the Edmund's board. There are many disgruntled owners of these cars because of the apparent suspension "defects". Firstly you must understand that I have been a strong advocate for the 2 vehicles that I own and have even offered to act as a "good will ambassador" so to speak for my dealer's prospective Azera customers, as a very savvy and satisfied customer, so to speak, so I don't send this communication in an adversarial capacity. You should be aware that there are owners, of Azeras in particular, who are about ready to expand their dissatisfaction with going so far as recommending a class action lawsuit.
In any case I am certain that Hyundai is most intent in emphasizing the quality and value of its product, because I see the references to the JD Power Initial Quality awards. of which Hyundai vehicles are high up on the list, and which are prominently displayed in the dealer showrooms and in the media.
All of the owners are certain that you know this problem exists and all are awaiting your acknowledgement of this instead of the apparent silence that has enveloped this major customer concern. Many of us have had acknowledgement from service managers at the dealerships and even from regional tech reps but no word from "above".
Please, in the interest of keeping the owners of your top of the line vehicles happy and contented, I would urge you to at least acknowledge this communication and indicate that your engineers are at work to effect a "fix" for this problem. As you may be aware that almost all of us who are Azera owners and Sonata owners absolutely are enamored of these cars, so please don't destroy what can become a long-term relationship.
I do expect to hear from you in a timely fashion so that I can post the answer on the message boards so that you can avoid a massive disenchantment with 2 very fine cars, Azera and Sonata.
Sincerely,
Donald Scharoff
I hope you get a response that says a fix is coming. I do
not want to have to trade in the car. I know Hyundai had a bad reputation years ago and I decided to give them a try now, but I am not happy with that annoying noise. Can't believe I missed that noise during the test drive.
Ed_G
Thanks for taking the lead on this problem. I can't add anything additional to what you have said. I hope that the Hyundai Consumer Affairs people monitor this site and realize that this is a widespread problem and not isolated. I think that most of us would be satisfied temporarily if Hyundai would acknowledge to the owners that they are addressing the issue. I can't believe the rear suspension noise would be much of an engineering challenge, but it might be more of a financial issue.
Perhaps it is the dual exhaust pipes. I know mine feel loose, however thankfully I have no Thunk!
75 of 75 Re: The Dreaded Clunk [roadkingtc88] by drdonrs Oct 25, 2006 (3:13 pm)
Bookmark | Reply | Edit | Delete | E-mail Msg
Replying to: roadkingtc88 (Oct 25, 2006 11:17 am)
As I have suggested, the moderators of this board as well as the Hyundai Forums should put together an electronic petition that all of us can sign indicating our displeasure with the lack of response and acknowledgment on the part of Hyundai USA. By hinting a joint action I do believe that we will get their attention. It might not be a bad idea to indicate that we, jointly, will be in touch with the automotive publications as well as Consumer Reports. It is necessary to show that there is joint concern and that it could trigger a joint negative reaction that will not serve Hyundai well
My dealer informed me Hyundai has released an official fix kit that includes new struts and mounts. The service mgr learned of the "unbroadcast" fix and had to have the regional manager approve the request and delivery. Apparently Hyundai has not yet released the fix but somehow is releasing it under certain conditions (?). They received the "kit" today and are just as curious as we are - they did say it appears to be an official "kit", not just some parts. The service mgr reported that this is a problem on Sonatas mfr before Sep 06 - look on your driver door jam. The car should be ready tomorrow. I will milk him for all info possible and post here later in the week. Hopin this is it!
thanks,
Ed_G
I should have said the question was for #33.
Ed_G
Thanks for your help.
Ed_G
Talked with Hyundai Customer Affairs office today. They know of the problem in the 2006 model, but I was the first to complain with a 2007 model. They have no plans to fix it as of now because it is not a safety issue.
They told me to have the dealer put the car on a lift and check it out to make sure it is nothing else other then the familiar thumping. They told me to keep pursuing it and they could end up fixing it some day. Anything is possible. It is hard to believe they keep manufacturing the same problem into next year model which I bought. I guess they are consistant.
I went under my car. One thing I did notice was the stabilizer is made from a thin steel. My other cars have much heaftier steel. Wonder if that could be it. They cut the size to make it cheaper.
Ed G
Picked up my car today with the newly installed "kit". Definately a stiffer response through the wheel. The rear seems to be quieter, but my preliminary feeling is only a 50% improvement. I do notice more front suspension noise, probably revealed by the quieter back end! Will drive more this weekend and give a conclusive response. No parts # yet, the Service Mgr said it was suppose to "not be released". Believe it or not, take it for what it is worth. Will post more later. :confuse:
I am surprise too that if they knew the problem was in the 2006 why it wasn't fixed in the 2007 model. Unless the real fix would have reduced their profits enough to not bother.
Let's just wait and see how you feel about it.
Thanks again,
Ed_G
I noticed yesterday I had a car full of luggage and 5 passengers. It sounded like I would expect. Much better.
Maybe the shocks are too stiff. It may be a matter of putting in some better shocks. No one makes them for a 2007 yet.
Ed G
Ed G
