Chevrolet Malibu Maxx Audio/XM/MP3
First of all, very interesting and informative message board.
I just bought a used 05' Maxx LS. The radio is NOT XM ready. I was wondering if it was possible to buy an upgraded factory radio that is XM ready (and maybe with an MP3 player) and have it installed. I'd prefer not to deal with aftermarket radios or those satellite radio receivers. I have talked to the parts department of two different dealers here and neither could answer that question. I was hoping someone here might know. Thanks!
How do you scroll through the RDS messages on my '04 Maxx LS 6 disc changer XM radio? It will read a phone number and cut off the last few digits. Thanks.
For OnStar phone number display I think it displays 10 digits which only covers a basic U.S. number with area code
Also, I have a noise that sounds like a rattle in the passenger mirror, the dealer was also unable to fix this under warranty so I'm on my own. Any ideas to what the problem is?
Thanks for the help.
Knob kit for 2004 Malibu radio is 22690637. Should be a cost of $5-$6 from dealer. Likely hard to get cheaper anywhere else due to shipping charges. Might just be one knob in kit because it is actually a couple pieces (inner pushbutton and outer knob). Don't know if both knobs on radio are the same - this one mentioned Power specifically.
I was unsure about your comment on the mirror. I don't really have a suggestion anyways but was it something dealer thought they could fix - just not under warranty?
FYI - the fact that your vehicle has XM option doesn't have much directly to do with the radio head itself. The XM receiver function is done by a separate electronic module in trunk. All but the base level radio in Malibu is compatible with this XM receiver.
I've had really good and really bad service out of the dealer. I still have an oil leak, probably from the rear main seal as the pan has been done. I do have GMPP, but was told I may be responsible for the repair costs if they determine the oil brand is the culprit. I think that's nonsense but will think about that next time I purchase a vehicle.
Has anybody experienced poor AM reception on their Maxx. The Dealership said the problem seemed to be intermittent and they couldn't find any problem. They reprogrammed the XM, but that has nothing to do with the AM.
Oil brand and warranty coverage?
They have no business under Magnusson-Moss specifying any brand as long as the oil is SM and 5w30. The GM oil life monitor is calibrated for dino not synthetic oil. If you were running 20w50 racing oil or 10w40 in there and blew something out you've got another problem, but brands is brands: whether Pennzoil or SuperTech. Goodwrench oil is the same as Mobil 5000-- I think, although the formula may be slightly changed.
There was an underlying GM spec for pumpability that still occasionally shows up on SM bottles but the SM spec. itself includes this performance. There were SL oils that could fail to meet this spec.
Thanks for any help on this subject.
Can anyone help with more advice about this issue? The cost isn't really a factor. I just need to know which way to go, if there is one at all.
We already own one of the higher priced FM transmitters, and its performance leaves something to be desired. I have even contemplated, in the event that no other options are available, a disruption in the signal from the stereo to the exterior antenna. This would allow the FM transmitter to have a better and more consistent signal. However, this would have to be something that could be turned on and off, and I don't know enough about it to ponder if this would even be possible...
Thanks in advance for any help or suggestions!!! I listen to audiobooks constantly, and would love to be able to listen to them via the stereo.
I want to be sure and get the correct one if possible. Thanks for your response!!!!
My display screen on my radio is not working. I just bought the car (2004 Maxx). I have bought a salvage radio from a 2005, will it be compatible?
Thanx.
Now it keeps telling me to set the time. I set it but everytime I push any button, it still wants the time set. Any ideas?
It looks like the Mag mount antenna disc can be placed in front of the rear moonroof
and routed under the gasket channel back to the cable through connector rubber grommet for the hatch brake light into the cabin. The FM antenna location should be the passenger rear quarter window (or hidden under that pillar to be closest proximity to the factory FM antenna)
Has anyone removed the dash around the radio (I'd like to mount the pod next to the 4 way flasher and route the power and Sat and FM cables under the dash). Any hint on removing he radio area panel and rear panels would be helpful before trying to figure it out the hard way.
Anybody have the service manual that can quote the steps for the panel removal?
(end dash panels, lower dash panels, chrome like divider strip panels, glove box, etc)
A number of screws are involved with those panels before you take the final step to yank the radio surround panel. Be prepared to spend time to analyze first or otherwise I'd farm it out to an expert.
Heres a link to get one stated, but remember the other panels need removal first.
http://www.chevroletforum.com/archive/threads/2006-malibu-radio-removal-42672-1.- - - - html
BTW: I found the self adhesive strip for the Sirius mount wont stick to the panel plastic (I have it mounted near the 4 way flasher button and removed the Malibu insert to feed my cables through (the flasher cable is a pain when removing the surround panel). I guess if one wanted to mount in the same area without removing everything you might be able to drill a large hole in the upper vent near the Malibu label and try fishing things down, but it might take some time. The location I feel is the best for the Sirius Radio dock (It's a Stratus 4, not Sportster as I originally wrote) I'm using the audio out to a Y connector feeding and external FM modulator for both the Stratus 4 and MP3 player (the internal FM modulator is poor and can be turned off if you use the audio out) I can still see and use the 4 way flasher button with the Sirius dock justified to the right on the "shelf" in front of the Malibu label.
http://www.siriusmerger.com/
I've searched searched the forums (and the net), but couldn't find the answer. All I want to do is unhook the car antenna. Simple to do? Like in a Caravan for example, its right behing the glovebox..takes seconds. I have a Sirius radio and I want to unhook the antenna so the other channels don't interfere. I don't care that I will be missing regular FM/AM...I could never go back to terestrial radio.
i found that there is 12-pin connect on the back of the headunit, and i have found the funtion of each pin.
ANYBODY KNOW HOW TO ACTIVE THE AUX OF THE HEADUNIT?
1.AUX MON +
2.AUX MON -
3.AUX ST COM
4.L AUX IN
5.R AUX IN
6.AUX ST SHIELD
7.AUX MON MUTE
8.NC
9.AUX ST COM
10.L AUX IN
11.R AUX IN
12.AUX ST SHIELD
Is there any dvd/cd/gps players out there that are compatible with the computer functions of the maxx? I need to be able to switch back and forth between miles and kilometers as I live near the border.
I know there is an aftermarket dash kit with display you can buy for around 150, but that looks terrible and with bad reviews regarding its function.
If theres any way to avoid that I would greatly appreciate it. Thanks! -Nick
I don't think I phrased my question properly.
I'm looking to get a NEW stereo for my maxx, one that has an indash dvd/navigation, but I don't want to lose the computer functions of the maxx (changing km to miles etc), and I don't want to get this thing..
http://cgi.ebay.com/2004-2007-CHEVROLET-MALIBU%2F-MAXX-DASH-KIT-COMBO-99-3303_W0- QQitemZ200446024245QQcmdZViewItemQQimsxZ20100306?IMSfp=TL100306173002r17974
So, what I'm trying to find out is if there is a stereo receiver available aftermarket that will do dvd/cd's/navigation and STILL retain the ability to change settings on the maxx.
Any advice will be much appreciated!
-Nick
Did you ever find how to remove the radio on you Malibu Maxx? I have a CD stuck on the CD player (single CD) and have not been able to take the CD out. The "No CD" message comes up. I thought that if I could remove the radio I might be able to take the CD out. Any advice?
ot sure if you go through the interior or if you access through the wheel well??
http://cgi.ebay.com/ebaymotors/2004-Chevy-Malibu-MAXX-OEM-DVD-Player-Screen-LKQ-- _W0QQcmdZViewItemQQhashZitem20b6631b83QQitemZ140498901891QQptZCarQ5fAudioQ5fVide- o
I just want to throw this out there to help anyone I can.
I recently lost the display on my stock stereo in my '05 Maxx. This is the 6 disc changer, the car also has the rear seat DVD if that makes any difference.
After going through all the research to find out how to replace the stereo and get the new one reprogrammed for the vin , I spent the whole day to do it and failed! At this point I took the stereo out and took it apart.
There are several basic parts to this stereo:
1-faceplate- includes screen and buttons
2-cd changer/player
3-large circuit board-likely the radio
4-small circuit board (half the size of a pack of cigarettes)- this board is mounted on the inside wall of the radio case. the connections between this and the rest of the radio had slipped. I tightened it up and put the radio back together and the display worked perfectly.
two different size screws so beware!
Very poor design by Delphi!
Hope this helps somebody
