Chevrolet Malibu Maxx Brake Questions
I purchased a 2004 Malibu Maxx one year ago, brand new. I love the car. I travel a lot for work and live in Washington State where the weather is wet and inclement in the winter. Highway driving is fantastic... it handles great on wet roadways. I love this car.
I noticed some shimmy when I break so I took it into to the shop. The rotors all around the car need to be machined (they are warped...) Three of the pads are at approx. 80% wear and one of the rear brakes is at about 30%. GM warranty will not cover brake repair if any of the brakes are over 50% worn... this is what the dealership told me. I have the 800 number and will address this issue with the warranty folks directly. It is obvious to me that the dramatically worn brake is defective in some way (and hopefully not indicative of some other problem). At this point in time the dealership is telling me the car needs a $275 brake job at my cost. This is the pits because I like the car so much and what a drag if my 72K warranty isn't going to help out with this. I will stay in touch. Please post if anyone has input or similar experiences. :confuse:
I have a question, though. My breaks make a lot of noise in the morning when I start from cold but they sounds fine after a while. I wonder if anyone (e2helper?) can tell if this is normal or if I should report it. My 36,000 warranty will be up after 200 more miles.
As far as the clunking, GM is replacing the steering box on my Maxx for similar clunking, under warranty.
This is just one more example of why Honda, Toyota and Hyundai are selling so many more cars than American manufacturers - the engineering on American cars just plain sucks!
It hurts me to admit it, because I've always been a supporter of American cars, but my next ride will probably be a Honda - they hold their value and remain reliable for years and years.
careful on toyota...lots of problems with their transmissions now...check out the new camry and rav4......think they have gotten complacent with their position here in the US.....all makes and models have problems...with a mass produced item.....
I recently made the mistake of allowing my dealer to do the brake job and was charged 5 hours labor @ $99.00/hr. I think this is excessive.
Dealer vs. Independent Shop
Dealer Dis-Service Horror Stories
The torquing had ranged from 60 to 140 Psi on the same wheels bolts. One shop supposedly used a "torque stick", but the wheels were torqued no better there than elsewhere.
Apparently there is enough elasticity in the rotor metal to recover from overtightening, provided the retorquing is done before uneven wear develops on the rotors.
Pao: at what mileage did you get your brakes switched out?
I also plan on going with an after market rotor when the time comes; give something else a try instead of going with these paper thin GM rotors.
Any comment on this subject will be greatly appreciated. Eroni.
I personally have replaced my pads twice already, once with new rotors and once with "turned" rotors and the mileage is only at 53k. I bought it used at 22k in April 07.
I am wondering what caused this. And, shouldn't a safety system on a vehicle be expected to last more than 5.5 years?
I had my car in to the dealer in April for brake work. They replaced the front and said the rear was fine. Is the caliper for the rear brakes the same as the e-brake system? If so, how was it fine just 3 months ago and seized to the point of destroying the system now?
I am going to talk to the dealer more tomorrow about this and any advice would be great. Thanks!
04 Maxx LT here with 148K on it...and havent had any problems yet...knock on wood....
I always use the parking brake. I had many std trans cars and it's just habit.
My car has only the odd problems - this, and the trunk latch needs to be replaced for the 2nd time. I have to use the emergency trunk release to open my trunk from the inside now. Fun stuff.
Thanks for the input.
Dealer said it was a problem with dirt getting into the pads because of the new style hubs - open. About every six months or so they would clean the brake pads and rotors and the sound would go away only to return a few weeks later. Dealer would do the same fix. The car is now four years old and problem has never gone away.
Anyone have this experience and do they agree with the dealer? I'm sure if I tried to sell the car - only has 40,000 miles on it - and the prospective buyer heard this noise he/she wouldn't be impressed.
The car was under warranty - why wouldn't they think to replace the pads?
Thanks so much for your assistance. You've been a great help.
Billym
So, any particular make or part number for replacement pads? As someone noted, the dealer wants to put in GM pads and they appearf to be the problem.
--Tom in Ohio
Go to Autozone's web site and search on part number DGC1028 and see what you think. Here's the description:
Features & Benefits
Cmax advanced technology formula is free of environmentally harmful heavy metals such as antimony, cadmium and lead per new OE formulations. Cmax friction is positive molded to ensure a smooth progressive braking along with excellent stability and fade characteristics as well as superior stopping distance. Cmax friction has excellent life and performance with lower traces of dusting while remaining super quiet.
The calipers appear to be working, the hoses appear to be fine. I have heard from someone that there is an electronic part in the engine that controls the fluid to each caliper. First off, what is the name of this part? Second, is this a possible culprit to this problem? Third, what else could be causing this? Thanks for any help you might have!
Joe
(did you also notice the piston in the calipers screws out, not compresses like the old days. did you also pay attention to not set the wrond pad on the inner piston side. there's an hourglass cutout on this "screw piston that could hang up on one of the protruding pad pins.)
good luck, just some thoughts. D
Nice call on the pad pins- that was part of the problem. Since they were not placed in the grooves on the piston, the pads were pushed onto the rotor. While they were fixing that, they realized that the left caliper needed to be replaced. All seems to be working fine now. I'm glad it was something relatively minor! Thanks for your help.
Joe
I apologize I am not a mechanic and cannot diagnosis your vehicle. I would recommend taking your vehicle to your local dealer of choice. They will be able to assist you with your concerns. Please keep me updated on your progress; Thanks!
Christina
GM Customer Service
I've twisted the piston down as far as it will go but the caliper still won't fit over the pads--same pads as the left side. The emergency brake is off so I don't think that's the problem. Like I said, it worked fine on the left rear.
Short of replacing the caliper, what can I do? Do you think greasing the piston will help? I read on this forum that someone lubricated the emergency brake cable. I'm not sure I like that idea but could that help?
Thanks...
I don't quite get how the parking brake is connected to the rear brake pads being worn, but that's what they told me at the dealership. Is this correct? I wound up having to have rear brakes done & rotors turned -- but I never heard the "squealing" sound that signals the brake are low! Any advice would be appreciated.
