Chevrolet Malibu Maxx Interior and Passenger Comfort Concerns
You can also add a small piece of WEB filter mesh (plastic mesh with 1" holes) under the filter if you are worried about it possibly being sucked into the HVAC fan.
Provide back model year and interior color and I can give you some suggested part numbers. It looks like there was a design change for 2006 model at some point as well after ...6F286778 there was a new design. So look at your VIN if you have a 2006
This is true for my '04 Maxx, and I have seen similar clearance problems in newer ones.
RH 22736395
I don't know what kind of price you can get. List price is $17-18 each.
Happy new year to you pao, and to all my Bu-Maxx cyber friends.
I bought a used 05' Maxx in December and have been very pleased with it's performance. Now that it's warmed up, I've started to use the A/C. At first, I didn't notice any problems. As the weather got warmer and I used the A/C more, I noticed a funk coming out of the vents. I took it to the dealer (out of warranty) and they told me that there was mold in the A/C system and that it is usually cause by recirculating the air. He said that I should avoid using it if I could. This may or may not be true but it is the answer I received.
I have had the vent system cleaned and deodorized twice since then (almost July now) and I can still smell it when I turn on the A/C. Ant information on how to get the funk out would be appreciated. Everyone I've talked to say it is now part of the car. :mad:
P.S. Msgs 27, 29, 30 - Thanks for the advice on installing and getting cabin air filters for the Maxx. I will try those tips out.
http://www.car-part.com/
Otherwise we love the car, 13,000 miles and no problems (fingers crossed).
Had a Dodge Intrepid with auto climate, but you could shut it off totally.
Best bet is to take it to a mechanic you trust and have them take a look at it. A functioning speedometer/odometer is usually a required item to pass inspection (I know it is here in PA) so you're going to have to get this fixed at some point.
on the right side of the page.
Just select Buick Park Avenue and you'll find yourself at a page full of Park Ave discussions.
Symptoms are:
recirculate mode(hot and cold):noise
air in mode: less noise(almost none)
defroster mode: noise
fans off:less noise(almost none)
I poked around a little online, someone suggested it might be one of the following:
check belt tensioner
and/or alternator
or clutch on the ac compressor
Anybody has the same problem?
If it just never gets cool and the compressor is running, it sounds like you developed a leak in the system somewhere and you'll need to have it looked at.
If by playing with the control for a bit it does not return to normal function, try following vacuum hoses from the control.
In one of my stepdaughters former cars (Corsica) the hose was plastic (not rubber) and broke where it was routed under the battery. (If someone else hadn't reported the exact same problem on a web site I never would have thought to look under there)
I'm surprised they are not covered under GMPP Major Guard. I don't see what category of non-covered parts this would fall under.
You might want to call the GMPP and ask them if it is a covered part. And if it is not covered, where does it fall on the non-covered list.
In the end, if not covered, I would just cut them off with a razor.
It looks like the rubber (or whatever type of material it is) boot on the end of the strut came off. Is there a way to replace just the end part, or do I have to replace the whole strut? If the whole strut, can I get the part at any parts store or does it have to be the original GM strut from a Chevy dealership?
Craig
